New Brazilian Case Inspection and Prep?
SeventyWesty
SeventyWesty is offline
PostPosted: Tue Oct 16, 2012 9:14 am    Post subject: New Brazilian Case Inspection and Prep? Reply with quote
Any recommendations as far as inspection and assembly preparation for the new OEM VW Brazilian cases currently available? Are there any reasons to avoid them?
theastronaut
theastronaut is offline
PostPosted: Tue Oct 16, 2012 11:35 am    Post subject: Reply with quote
Check and make sure that the crank bore is centered with the cylinder deck surfaces- it was off center .013" on one of my blocks. I'll have to have the block decked to get even a compression ratio side to side.
Also check that the cam bearing thrust flanges are supported by the block. In another block of mine the cam bearings were free to move fore/aft .020" since the block didn't support the flanges tightly. This one seems to be a rare problem, I've only seen one other example posted here. Still wouldn't hurt to check though.
Make sure that the oil holes in the bearings and oil pump line up with the oil passages in the block.
I'm sure others will chime in and post more things to check.
Strive for perfection in everything. Take the best that exist and make it better. If it doesn't exist, create it. Accept nothing nearly right or good enough."
-Sir Henry Royce, co-founder of Rolls-Royce
'64 Beetle Sunroof OG Bahama Blue
'63 Beetle Vert
'66 Beetle
'66 Chevy C10
Too many '88-93 Festivas to count
kreemoweet
kreemoweet is offline
PostPosted: Tue Oct 16, 2012 11:48 am    Post subject: Reply with quote
Check that the fuel pump flange will seat properly on the case. I have a new VW Brazil case
where the hole in the shelf where the end of the flange goes was machined crooked, and the
flange can not sit flat on the case.
'67 bug: seized by the authorities
[email protected]
roy@mofoco.com is offline
PostPosted: Tue Oct 16, 2012 12:16 pm    Post subject: Reply with quote
I have had to align bore most of the recent ones back to standard. Yes, it cuts all the way around the entire bore. Machine the pressure relief sealing surface flat. Make sure the inserts don't stick too far out of the case, they can hang up on shims or the cylinder sometimes. Take the oil pick up out and clean it. They install it with cosmoline on it which likes to keep metal shavings attached.
Clatter
Clatter is offline
PostPosted: Tue Oct 16, 2012 1:55 pm    Post subject: Reply with quote
X2 on checking the main saddles.
They can be small or not round.
Also have seen the cam bearing tunnel too small and not round.
Bus Motor Build
It does not exist!
AlteWagen
Troll
AlteWagen is offline
PostPosted: Tue Oct 16, 2012 4:12 pm    Post subject: Reply with quote
Are these problems with the new Rima cases?
http://www.thesamba.com/vw/forum/viewtopic.php?p=5338155
Howard 111
Howard 111 is offline
PostPosted: Tue Oct 16, 2012 6:21 pm    Post subject: Reply with quote
But isn't it amazing, we are driving these cars, 60 years after they were invented!
uglyduck
uglyduck is offline
PostPosted: Tue Oct 16, 2012 9:11 pm    Post subject: Reply with quote
Check oil relief bores,had one stick on a new build once.
SeventyWesty
PostPosted: Wed Oct 17, 2012 2:52 am    Post subject: Reply with quote
Thanks for all the replies everyone, will surely save me some cussing.
[email protected]
PostPosted: Wed Oct 17, 2012 7:59 am    Post subject: Reply with quote
YES
