payin_vw Samba Member
Joined: November 27, 2012 Posts: 117 Location: Colorado USA
Posted: Sun Apr 20, 2014 3:47 pm Post subject: Beetle engine air compressor based ! |
I have been thinking about this for a long time, im sure someone
Has done it already.
I want to build a high output compressor using a beetle engine,
My idea involves the two front piston/cylinders, rears will be
Taking out and using just the cylinders to help holding the heads
. Using a electric motor hook to the pulley to run the monster.
Any input is greatly appreciated even if us only to chew my rear end. _________________ 61 work in progress restoration, more work than progress actually. |
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7801 Location: Big Wonderful WYO 82401
Posted: Sun Apr 20, 2014 3:50 pm Post subject: |
http://www.dunnrightinc.com/ _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked  |
johnnypan Samba Member
Joined: October 24, 2007 Posts: 7431 Location: sackamenna
Posted: Sun Apr 20, 2014 5:40 pm Post subject: |
Grimmer Schmidt did ford v8's for years.. |
morymob Samba Member
Posted: Mon Apr 21, 2014 4:30 am Post subject: |
Could be done but not very practical. A co called 'Dunrite'or something like that in So Carolina makes A turn key with 2 cyls 4 pwr & 2 large cyls with modded pistons(did use stock earlier) 4 compressor function. Big diff is a special grind cam with double lobes 4 comp pistons, lobes 180 each other which made each stroke a compression stroke,I bought a cam awhile back to build me one but never really needed it, was intended to sand blast & 94's 4 compressor 2 cyls. This co also sold kits to convert an eng . |
*Darren Samba Member
Posted: Mon Apr 21, 2014 3:22 pm Post subject: |
Holly Guacamole !!!
those are great ideas, i was thinking in powering the engine/compressor with a electric motor, to make it simple, removing the rear pistons to help the electric motor with the moving mass, not flywheel neither no oil cooler and so on, yes oil pump to help with lubrication. _________________ 61 work in progress restoration, more work than progress actually. |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15600 Location: Deep in the 405
Posted: Mon Apr 21, 2014 5:52 pm Post subject: |
Although the VolksAir is a neat ideal, you would be far better off buying a standard air compressor with a gas engine. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
