keifernet Samba Search & Rescue
Joined: May 11, 2002 Posts: 19395 Location: Samba Center for Behavioral Science
Posted: Tue Jul 07, 2009 9:26 am Post subject: |
| Gariack wrote: |
| Anyone know the diameter of the different size holes in the throttle plate on the 34 pict carbs. |
The DVDA is approx 5/32" and SVDA is 1/8".
Hard to believe that difference does anything but trust me... it makes a big difference in the way the carb runs/tunes when your using a DVDA flange # German carb meant to be timed at 5 ATDC with an SVDA timed at 7.5 or an 009 timed at 10 BTDC.
I find the pop rivet easier than taking the plate out and soldering the hole shut, grinding it flush and re drilling it but that's a personal choice. It can also be "undone" in a matter of minutes if someone wants to go back to a DVDA and does not alter the carb in any other way. |
Gariack Samba Member
Joined: April 18, 2006 Posts: 61 Location: San Diego, CA
Posted: Tue Jul 07, 2009 9:58 am Post subject: |
| Thanks Keith that is exactly what I was looking for. |
webwalker Samba Member
Joined: January 26, 2006 Posts: 2803 Location: Mount Laurel, NJ
Posted: Tue Jul 07, 2009 9:59 am Post subject: |
Keith,
Is there a punchlist of flange ## to applications? This is something I didn't check when you helped me dial in my Solex about 18 months ago, and I AM running DVDA. (though the state of the diaphram is unknown.)
M _________________ "Consistent maintenance with quality products is the cheapest warranty you'll ever need."
1977 CE1 Transporter Deluxe, Subaru EJ22, Skills Cooling, Steedle HD 091 w/ GuardT .82 4th
Click to view image |
Posted: Tue Jul 07, 2009 10:07 am Post subject: |
| webwalker wrote: |
Keith,
M |
Andy has posted various charts many times. Here's one with just 34 pict 3 German info.
I probably asked you when I built your carb what distributor your running.
If you need some help with it just PM or email me.
glutamodo  The Android
Joined: July 13, 2004 Posts: 26634 Location: Douglas, WY
Posted: Tue Jul 07, 2009 1:43 pm Post subject: |
Perfect! And thanks.
Keith,
You kindly offered me advice that got my Solex going without a rebuild. I'm actually looking forward to having a problem bad enough that I need to pay you to help me.  _________________ "Consistent maintenance with quality products is the cheapest warranty you'll ever need."
Towel Rail Horizontally Opposed
Joined: April 15, 2005 Posts: 4622 Location: SE CR IA US NA PE
Posted: Tue Jul 07, 2009 3:34 pm Post subject: |
That's pretty awesome. _________________ 1974 Thing -- under the knife
1967 Beetle -- spring/summer/fall driver
1996 Subaru OBW (EJ22, 5-speed, AWD) -- winter car, 3-seasons "don't feel like biking today" car
049 > 070 > 053 > 009 |
Czarlxxvii Samba Member
Joined: April 05, 2009 Posts: 164 Location: Greenville, SC
Posted: Thu Jul 09, 2009 8:52 pm Post subject: |
Here's a cut and paste from a different thread that I incorrectly posted in the wrong place.
I hate to piggyback a thread, but my question is related to the same problem. I have a 74 super with AH engine code. It has a 34 pict 3 carb (Bocar) and an 034 distributor that has just recently been added. The Muir book says I should time it at 5 degrees ATDC . Old volks says a 74 Cali is 5 ATDC. A Federal 74 is 7.5 BTDC.
My issue is that my car has a blocked off EGR, but I believe has been owned in SC since it was new. I recently switched to an 034 dizzy from an 009. I had the 009 pretty well tuned considering the setup. It was at 7.5 BTDC. I have the 034 now, and I am trying to set it to 7.5 as well, but am I completely wrong? My quick setup seemed a little rough and it is overheating. I'm dialing it in a more precisely now, but I am wondering if I'm headed in the wrong direction. Someone please help, I have a roadtrip planned for Saturday.
Thanks in advance,
McCay
Edit: I just got back from a test drive with the timing set at 7.5 BTDC. It seems to run pretty well. We'll find out if it overheats when I drive out and back to work tomorrow. How do I tell I tell if the Bocar was meant for an SVDA or a DVDA? I'm assuming from this thread that if it was meant for DVDA then I could benefit from the pop rivet. _________________ McCay
1974 Super Beetle
Daily Driver |
Posted: Thu Jul 09, 2009 8:54 pm Post subject: |
Another question was that when I was adjusting the carb after setting the timing I couldn't seem to lean it out. Regardless of how much I turn the screw it didn't seem to make a difference. Should I wind it all the way in and then back it out? _________________ McCay
1974 Super Beetle
Daily Driver |
Posted: Thu Jul 09, 2009 9:01 pm Post subject: |
| Czarlxxvii wrote: |
Thanks in advance,
McCay
Edit: I just got back from a test drive with the timing set at 7.5 BTDC. It seems to run pretty well. We'll find out if it overheats when I drive out and back to work tomorrow. How do I tell I tell if the Bocar was meant for an SVDA or a DVDA? I'm assuming from this thread that if it was meant for DVDA then I could benefit from the pop rivet. |
Bocar's all have the smaller hole in the throttle plate BUT still have the fitting for the DVDA... I guess they are supposed to be an "all purpose fit" but who can tell... As long as you have unused vac ports plugged and the advance for your SVDA going to the correct port on the LH side of the carb you should be fine.
And that your not using the screw ON THE THROTTLE ARM to try and set idle...
| Czarlxxvii wrote: |
| Another question was that when I was adjusting the carb after setting the timing I couldn't seem to lean it out. Regardless of how much I turn the screw it didn't seem to make a difference. Should I wind it all the way in and then back it out? |
This to me reeks of either a poorly tuned engine over all ( valve adjustment, plugs, point gap etc no vacuum leaks on intake or base of carb )
OR perhaps even too high of fuel pressure syndrome... making the carb hard to tune, small mixture screw useless in trying to tune the carb at idle. But as always there are several things you could have going wrong at once. |
Posted: Fri Jul 10, 2009 9:43 am Post subject: |
| keifernet wrote: |
And that your not using the screw ON THE THROTTLE ARM to try and set idle... |
The vac ports are plugged and I'm not using the screw on the throttle arm.
| keifernet wrote: |
I think the engine is turned well, but I'm still a noob so I could be wrong. The points are gapped at .016 and the dwell is dead on 50 degrees. The engine had just been rebuilt when I got the car in april. I adjusted the valves after about 200 miles. They were set at .006. I've probably driven it 500-600 miles since then. They may have tightened up though since the engine is still green. The plugs are new from the rebuild, and all the extra vac holes are plugged. What confused me is that the carb had no issues whatsoever with the 009 dizzy. It dialed right in when I timed it after the first valve adjustment. (Keith, can I get on the list for a Solex?)
After some more research, I'm even more confused about whether I should be at 7.5 BTDC or 5 ATDC. I'm assuming (big assumption on my part) that if it runs decently at 7.5 BTDC then it would run like crap at 5 ATDC.? [/quote] _________________ McCay
1974 Super Beetle
Daily Driver |
Posted: Fri Jul 10, 2009 10:21 am Post subject: |
| Czarlxxvii wrote: |
| keifernet wrote: |
| keifernet wrote: |
After some more research, I'm even more confused about whether I should be at 7.5 BTDC or 5 ATDC. I'm assuming (big assumption on my part) that if it runs decently at 7.5 BTDC then it would run like crap at 5 ATDC.? |
Correct, the only distributor that times retarded to 5 ATDC is the DVDA.... your SVDA "034" should time to 7.5 BTDC hose off at idle and should also stay at 7.5 at idle after you plug the hose back on. Should go to approx 30 revved up hose off and over to around 40 hose on (in the driveway under "no load" you will see it go that far if you have a degree pulley that is...it will not go that far when the car is driven/under load though) |
Posted: Fri Jul 10, 2009 11:30 am Post subject: |
Thanks for the help. I guess I need to play around with the carb to see what's up with it. It seems to be running well with the car, just a bit rich. _________________ McCay
1974 Super Beetle
Daily Driver |
Posted: Fri Jul 10, 2009 11:35 am Post subject: |
| Czarlxxvii wrote: |
| Thanks for the help. I guess I need to play around with the carb to see what's up with it. It seems to be running well with the car, just a bit rich. |
As I eluded to in an earlier post... get a gauge and check the fuel pressure. |
Posted: Fri Jul 10, 2009 12:50 pm Post subject: |
| keifernet wrote: |
I read right over that. Sorry  _________________ McCay
1974 Super Beetle
Daily Driver |
Orsocron Samba Member
Joined: August 29, 2003 Posts: 307 Location: Huntsville, AL
Posted: Wed Jul 22, 2009 2:58 am Post subject: |
Czar,
You can easily make a fuel pressure tester with some hose, a "T" fitting, and a $1.98 fuel pressure gauge from Autozone. Remind me and I'll send you a picture of the one I made.
Have you done the COMPLETE tune/reset of that Bocar? By that I mean the whole setting of the screw on the throttle arm, and setup of the two side screws to their "factory" setting? There's a decent writeup for that on this website as well as the vwresource site.
Joe _________________ 1964 1500s Notchback
Yes, always! |
g bags Samba Member
Joined: September 25, 2009 Posts: 1 Location: old lyme ct
Posted: Fri Sep 25, 2009 9:58 pm Post subject: |
| thanks for the carb tip! my 79 cab with carb runs and idles good!i jumped from the computer to the garage.........thanks g bags |
mnussbau Samba Member
Joined: August 26, 2006 Posts: 4610 Location: Central Maryland
Posted: Fri Apr 23, 2010 7:20 pm Post subject: |
| keifernet wrote: |
| Gariack wrote: |
Sorry to bring this old thread back, but my 34Pict3 and SVDA combination is stumbling and I think it's because the carb is meant for a DVDA. I'm going to try the rivet trick. What size rivet is the right one? Also, I assume I've got to remove the center of the rivet after installation? _________________ Mike
‘74 bug vert
Parts... |
Posted: Sat Apr 24, 2010 7:02 am Post subject: |
It could be that, or just general wear on the throttle shaft causing issues. Have you looked up your carb's base-flange number on the chart posted earlier in this thread? If you don't have one, then you'll just have to take it off and look at the throttle butterfly and see what size the hole is now, again, refer to pictures earlier in this thread.
-Andy |
Posted: Sun May 02, 2010 7:27 am Post subject: |
Keith rebushed the throttle shafts a couple years ago, they're good. The carb base number (281-1) indicates it's meant for a DVDA. Turns out there already was a rivet in the throttle plate but the center pin had not been knocked out. This morning I pulled the carb and knocked out that pin, warmed up the engine, tuned the carb, and BINGO, no more stumble!! What a difference! _________________ Mike
‘74 bug vert
Parts... |
