camshaft part numbers help needed
Page: Previous  1, 2
islandwesty
islandwesty is offline
PostPosted: Thu Jun 29, 2006 10:04 am    Post subject: Reply with quote
Thanks, guys, for further input. Just wanted to clarify that a bit before I suck it up Shocked and buy the hydo cam.
SlowLane, had visions of GEX running through my mind as well... Wink Maybe, they grabbed what was available from the shelf, like how they graft body parts together between model changes.. it rhymes with the company policy, somehow.
'80 VW Westfalia
'90 Ford Aerostar E4WD
'94 Ford Escort Wagon
Prejudice is an emotional commitment to ignorance.
rainierdeklark
rainierdeklark is offline
PostPosted: Fri Jan 08, 2010 6:44 pm    Post subject: Reply with quote
I'm just going to resurrect this thread, because it's all confusing.
I found out that the last two digets of the camshaft number determine the pitch of the gear. That pitch is also stamped into the edge of the gear.
The part number of the gear is always the same (either alloy or magnesium).
So why does the camshaft number changes with different pitches, while the gear number stays the same? The pitch is in the gear, not in the camshaft...
Does anybody knows if the valve timing of the GE camshaft (022 109 017 A) is the same as for the CV Vanagon camshaft (071 109 021)?
I need a new camshaft for my GE engine and the only hydro camshaft that is still for sale is the Vanagon one....
Here is what I found in factory literature:
021 109 015 M --- CA engine --- pitch -3
021 109 017 M --- CA engine --- pitch -2
021 109 019 M --- CA engine --- pitch -1
021 109 021 M --- CA engine --- pitch +/-0
021 109 023 M --- CA engine --- pitch +1
021 109 025 M --- CA engine --- pitch +2
021 109 027 M --- CA engine --- pitch +3
022 109 017 A --- GE engine --- pitch +/-0 (hydro, no rings)
071 109 015...025 --- (CU?) CV engine --- (Vanagon, hydro)
021 109 021 J --- 1700 auto, 1800 engine --- pitch -2 (two rings, one left and one right)
021 109 017 L --- CE, AP, CJ, GD engine --- pitch -2 (+/-0?)
021 109 101 F --- Z engine (VW 411 1700cc) + W, EA, EB, EC, AN, GA, GB (Porsche 914) >>>> ONE single ring
Modern cars are nothing but visual pollution !
www.klarkclassiccars.se
rainierdeklark
PostPosted: Sun Jan 17, 2010 3:40 pm    Post subject: Reply with quote
Removed the camshafts out of two GE engines (1977 and 1978).
The numbers on the camshafts are the same, namely: 022 109 101 A
The numbers on the gears are also the same, namely: 021 109 111 C
But after the VW sign on the gear, there is a difference:
1977 (pitch -3): 9H
1978 (pitch -2): 4H
So, the story of different camshaft numbers (last three digets) representing different pitches, counts for older camshafts, but not for GE (= hydro) camshafts.
Anybody with more info on this topic/removed a camshaft and wrote down the numbers?
JusBugs
JusBugs is offline
PostPosted: Wed May 23, 2018 11:44 am    Post subject: Re: camshaft part numbers help needed Reply with quote
i need help trying to see what a camshaft I have is worth. it is an original vw camshaft in a vw/Audi box part number is 021-109-015L Thanks
SGKent Premium Member
SGKent is offline
PostPosted: Wed May 23, 2018 12:12 pm    Post subject: Re: camshaft part numbers help needed Reply with quote
new or used
JusBugs
JusBugs is offline
PostPosted: Wed May 23, 2018 12:17 pm    Post subject: Re: camshaft part numbers help needed Reply with quote
new, still in vw/Audi box
SGKent is offline
PostPosted: Wed May 23, 2018 12:43 pm    Post subject: Re: camshaft part numbers help needed Reply with quote
I could not find that part number listed. I sold a new T4 914-4 GA cam (021.109.101K -3 gear), and new 914-4 lifters for about $250.
Page: Previous  1, 2
Page 2 of 2
