Breather box install
Page: Previous  1, 2, 3  Next
mynameistory
mynameistory is offline
PostPosted: Tue Apr 15, 2008 7:13 am    Post subject: Reply with quote
While we're all showing off Laughing -
neil68
neil68 is offline
PostPosted: Tue Apr 15, 2008 5:32 pm    Post subject: breather tower Reply with quote
I have the Latest Rage Porsche-style breather tower. It also fits with the CB hex linkage. I've since re-routed the #1/2 valve cover hose and also use a filter vent on the other outlet:
Neil.
Der Kleiner Rennwagens
‘68 Beetle 2332 cc, 204 WHP
12.5 seconds @ 108 mph
Dynojet Test: https://www.youtube.com/watch?v=M9B_H3eklAo
Joel
Joel is offline
PostPosted: Tue Apr 15, 2008 10:46 pm    Post subject: Reply with quote
if ur gonna mount it to the firewall make sure to offset it so its not in the center
i found out originally when i put it there the decklid spring hits it
Quick little bug, you got a Porsche motor in that?
1974 Germanlook 1303 2.5 Suba-Beetle
madmike
madmike is offline
PostPosted: Wed Apr 16, 2008 5:51 am    Post subject: Reply with quote
Thanks for the pix Neil68,I was wondering if the Latest Rage would fit with hex bar linkage,I had a Custum box made for the drag Bug 3" exhast pipe 18" long with bungs welded to it 2 on the ends mounted high and two more top and bottom for a drain and cheap little filter/breather up top all mounted on the firewall, works great,Madmike
'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
"If I'm ever on Life Support,UNPLUG Me, Then Plug me back In see if that Works"
redhot
redhot is offline
PostPosted: Mon Apr 28, 2008 7:03 am    Post subject: Reply with quote
Hi,
Would this work?
Thinking of using a canister like this (have one spare from an old tractor), routing the hose from the oil-filler into an welded on tube-end and into the canister.
Put foam inside to collect the oil, and drill the top lid as to ventilate it.
Would it work? It will be for looks mostly. And because I don`t think the tube going down through the tin adequate, and I won`t vent it to a carb.
Hotrodvw
Hotrodvw is offline
PostPosted: Mon Apr 28, 2008 7:37 am    Post subject: Reply with quote
I wouldn't. It needs baffles to separate the oil from the air.
'67 Sunroof
Eric
78x94 with IDA's....oober fun
Horsepower is an addiction........Addictions cost
lots of money!
Hose & Fittings
redhot
redhot is offline
PostPosted: Mon Apr 28, 2008 9:46 am    Post subject: Reply with quote
What exactly is baffles? Sorry for my English, not my native language Smile
How does those small breather tanks that Jaz etc sell look like inside?
57 Rag
57 Rag is offline
PostPosted: Mon Apr 28, 2008 12:35 pm    Post subject: Reply with quote
Okay, figured it out again. Laughing
57 Ragtop
84x94 86C
IDAs
redhot
redhot is offline
PostPosted: Thu May 01, 2008 10:44 am    Post subject: Reply with quote
Anyone?
Same concept, different container.
akokarski
akokarski is offline
PostPosted: Thu May 01, 2008 12:02 pm    Post subject: Reply with quote
borrowed breather pic from
http://www.thesamba.com/vw/classifieds/detail.php?id=432954
If you look at the box inside you will see plates at 45 deg pointing into the flow.
as air containing oil vapors makes it's way around the baffles, air is forced to make turns. Anything in the air, in this case oil droplets cannot make those turns as easy and ends up flying into the baffle plates. Then droplets will collect and drain back into the engine.
The more turns air has to make, the better the breather. In the old days folks would stuff copper steel wool looking things. Same idea as oil bath breather, where coconut husks provided labyrinth for air to snake through while dirt particles would get separated out of the air.
You could make your own breather by taking a pipe and cutting at 45degrees into it and slide plates into the cuts then weld them from outside. Cap both sides of the pipe with fittings and you got in and out.
You could also find a baffle right under the generator stand. Ever wonder why it's so important to install it the right way? Smile with baffles pointing down forward.
Anton
lugnuts
lugnuts is offline
PostPosted: Thu May 01, 2008 12:04 pm    Post subject: Reply with quote
baffle,plate, board,screen or other device,used to hinder or control the flow of a gas a liquid or sound through an inlet or outlet.End of quote Laughing
RIS
RIS is offline
PostPosted: Thu May 01, 2008 4:49 pm    Post subject: Reply with quote
Buggin_74 wrote:
Nice!
Richard Sedoris - VW Performance & Machine - Youngstown, OH
http://rismachine.tumblr.com/
YouTube: https://m.youtube.com/channel/UCfTBCG4I61iVm_ROc8OAuOQ
Instagram: @rismachine
bugninva
bugninva is offline
PostPosted: Thu May 01, 2008 8:03 pm    Post subject: Reply with quote
akokarski wrote:
[ You could also find a baffle right under the generator stand. Ever wonder why it's so important to install it the right way? Smile with baffles pointing down forward.
Anton
louvers down, open to the right...
[email protected] wrote:
With a show of hands, who has built over 1000 engines in the last 25 years? Anyone?
GEX has. Just sayin
Jimmy111
Jimmy111 is offline
PostPosted: Thu May 01, 2008 8:11 pm    Post subject: Reply with quote
Redhot.
Your Idea is fine. You dont need the slats. The foam is fine or you can use a steel scrubbing pad that you can find at the supermarket. The whole Idea is to give the oil someplace to hit, reduce velocity then filter back down to the crankcase. Just make sure you have either multi holes or a hole of at lease 1.5" in diameter in the top of the can.
Congratulations for trying to try something yourself instead of just buying a part.
akokarski
PostPosted: Thu May 01, 2008 11:54 pm    Post subject: Reply with quote
bugninva wrote:
Anton
Embarassed
Hotrodvw
Hotrodvw is offline
PostPosted: Fri May 02, 2008 6:39 am    Post subject: Reply with quote
Jimmy111 wrote:
Redhot.
Don't forget, you want to have good air volume/flow, not restricted. I would think to use something out of the ordinary, the ports fo the hose attachmnets should be enlarged.
'67 Sunroof
Eric
lots of money!
Hose & Fittings
akokarski
PostPosted: Fri May 02, 2008 11:05 am    Post subject: Reply with quote
this is what I've been looking for!
http://bobhooversblog.blogspot.com/2007/02/blow-by.html
golde60
golde60 is offline
PostPosted: Fri Sep 12, 2008 6:28 am    Post subject: Reply with quote
has anyone had any experience using a gwd breather (see pic)
these will fit into the space in my spyder a bit better, as the engine is reverse (mid engined)
I am concerned about the lack of baffles. Thinking that I will connect to each of the carb tops, each of the heads and to a connection at the oil filler
no vent to atmosphere, thinking that the slight vacuum from the carbs can take care of that
what do you guys think?
rkeller
rkeller is offline
PostPosted: Mon Mar 16, 2009 12:36 pm    Post subject: Reply with quote
This was an afterthought, but it seems to work well. Didn't spend a fortune and it came out OK. Thought about mounting behind the shroud but the foam does need to be cleaned from time to time and it's easy to get to here.
BelialConsummation
BelialConsummation is offline
PostPosted: Thu Mar 26, 2009 8:25 am    Post subject: Reply with quote
This is a pretty cool thread, keep it going!
There are two obvious ways you can plumb these which is to the carb and to the valve covers.
I've only used the carb because its been easier but have always been interested if the valve cover way would have more success.
Corey
Page 2 of 3
