theKbStockpiler Samba Member
Joined: July 07, 2012 Posts: 2316 Location: Rust Belt
Posted: Thu Mar 22, 2018 7:54 am Post subject: Re: Rust Prevention Product Testing |
You must have a few rust buckets on your hands as well Evil! I should ask the samba to rename this forum ,'the rust and dent forum'.
I'm using Arm and Hammer powdered laundry detergent.
I'm using it to neutralize the massive flash rusting from Muriatic acid though.
The issue I have with Muriatic acid is it's not much better than vinegar, it adds as much rust as it takes off unless you neutralize it somehow and don't let it dry out. You can't leave it unattended ,let it dry and no one wants to watch acid work on rust for very long.
I'm trying to supersede sandblasting if I have the time to wait for the acid to work as effectively as possible. _________________ My beetle is not competing with your beetle. I have the yellow beetle in my town. There is a red one, a green one ......
Use all safety devices including a mask. |
Evil_Fiz Samba Member
Joined: May 06, 2011 Posts: 1063 Location: Jacksonville, FL
Posted: Thu Mar 22, 2018 9:29 am Post subject: Re: Rust Prevention Product Testing |
theKbStockpiler wrote: |
You must have a few rust buckets on your hands as well... |
Nope, just one Ghia with less rust than most. I am mainly treating the hardware with the vinegar dip. The bigger parts I an blasting to A) clean them and B) profile the metal for better MasterSeries adhesion.
The issue I have with Muriatic acid is it's not much better than vinegar, it adds as much rust as it takes off unless you neutralize it somehow and don't let it dry out. |
I have found that even if I just rinse the parts I dipped in vinegar and leave then sitting out, they don't tend to develope too much flash rust.
Thanks for the detergent info. The Eastwood After Blast Cleans the de-rusted parts, converts any microscopic rust, and leaves behind a Zinc coating. It claims to promote paint adhesion; that is yet to be determined.
Cheers,
Emil _________________ “…It's not just about what's interesting. It's also about what's helpful, and it's helpful even if it helps just one other guy working on a Ghia.”
kiwighia68
See my build on TheSamba at:
The K_R_A_K_E_N_N : a 70 Ghia Convertible reinterpreted |
c21darrel Samba Member
Joined: January 22, 2009 Posts: 8213 Location: San Dimas
Posted: Thu Mar 22, 2018 7:51 pm Post subject: Re: Rust Prevention Product Testing |
Right now I'm mixing my own acid blend and don't see any benefits for more than %30 muriatic acid. Usually I cut phosphoric acid with a little vinager and or muriatic acid which seems to work the best. When it stops being effective I wash it off ,let it dry and go at it again. _________________ My beetle is not competing with your beetle. I have the yellow beetle in my town. There is a red one, a green one ......
scrivyscriv Samba Electrician
Joined: October 04, 2011 Posts: 2935 Location: Memphis
Posted: Sat Jul 14, 2018 12:39 am Post subject: Re: Rust Prevention Product Testing |
c21darrel wrote: |
I have used muriatic acid and dont like it for a couple reasons. Unlike phos acid I cant add water to dilute and pour it out on the ground... |
Add baking soda to it until it stops fizzing.. then it's safe to pour out on the ground. _________________ Robert in Memphis
Engine rebuild thread
If you're ever in the Memphis area, you are welcome to stop by for advice and help. |
rodeking Samba Member
Joined: October 09, 2017 Posts: 369 Location: near Buffalo NY
Posted: Sun Feb 03, 2019 9:30 am Post subject: Re: Rust Prevention Product Testing |
After reading this whole thread all I can say is that the very best rust preventive coating, bar none, is hot dip galvanizing. Nothing else compares.
I rebuilt a 1990 F150 4x4 and I disassembled and blasted the complete frame and had it hot dipped for $250 about 8 years ago. Then I shot it with epoxy and black urethane, it will last pretty much forever.
Not sure if that would be possible on a bug pan without it warping though.. the hot dip tank is about 800F. |
fubar1962 Samba Member
Joined: June 13, 2016 Posts: 1 Location: Portland Oregon
Posted: Thu May 02, 2019 11:39 am Post subject: Re: Rust Prevention Product Testing |
I was browsing through the helpful posts about rust proofing. Has anyone used the sealant where the guy cuts the boat in half and reseals it with the product? I have used just the rattle can product for my wheel wells of my 71 Bay Window. Seems to work fine...so far. I also used the 'fat mat' for the entire interior panels, when we completed the ground up. It really cut the road noise a bunch.
On another note, does anyone know where I can get a reman steering gear box for my 71 T2 Bay Window? The PO installed a TRW which is adjusted out to its max. I want 'power steering' back. Thank you in advance. Cheers. |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17978 Location: Eugene, OR
Posted: Mon May 06, 2019 8:44 am Post subject: Re: Rust Prevention Product Testing |
fubar1962 wrote: |
Place a WTB ad for a steering box in the Bay Window 'parts for sale' Classifieds. _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Ceckert64 Samba Member
Joined: September 16, 2015 Posts: 1988 Location: Auburn, NY
Posted: Thu Jun 27, 2019 8:55 pm Post subject: Re: Rust Prevention Product Testing |
Okay, I have read this whole thread, and now I’m more unsure of what to use than when I started. My situation is that I will be blasting the underside and wheel wells of my 64 while it’s upside down. My first question is should I use POR-15? The lower 8+ inches of my body had to be replaced, I will be using seam sealer, but I’m very paranoid about rust coming back. I’m using PPG paint 3 part system, epoxy primer, epoxy base coat, and urethane clear coat. My question is should I use this paint system and then put POR-15 over it, bare metal with POR-15 over it, or use the paint system I’m using and put a different type of undercoating on it (rust bullet, master series, etc)? Truck bed liner stuff? Also, what is a good seam sealer to use? I’m in Michigan and live on a gravel road so it needs to hold up to gravel and salt well. Any suggestions appreciated, thanks for the help! _________________ 1964 sunroof Beetle Restoration "Herbie"
1972 Sierra Yellow Tin Top Westfalia Camper
“Fitz” 1971 Westfalia Poptop |
Chickensoup Samba Member
Joined: January 06, 2018 Posts: 5368 Location: Good Hope, GA
Posted: Sun Feb 23, 2020 7:20 pm Post subject: Re: Rust Prevention Product Testing |
question,
so i want to use master series for my chassis but should i just use the silver or should i top coat it? anyone w/ experience?
thanks |
DurocShark Samba Member
Joined: April 05, 2004 Posts: 6624 Location: Crappy town in a crappy state. But the beach is nearby, so I have that going for me.
Posted: Sun Feb 23, 2020 8:44 pm Post subject: Re: Rust Prevention Product Testing |
Chickensoup wrote: |
question,
thanks |
I used it on interior and exterior rust. Even where exposed to the weather in the rain gutters it lasted several years (and Colorado weather as a daily!) until I sold my bus. So if you topcoat, it's because you don't like the silver look. It didn't need a topcoat in my experience. _________________ No boom today. Boom tomorrow. There's always a boom tomorrow. |
Posted: Mon Feb 24, 2020 5:04 am Post subject: Re: Rust Prevention Product Testing |
Ok cool, I happen to like the silver. But will it work well if it take my pan down to bare metal, then prep it with something like phosphoric acid?
Thanks |
Posted: Mon Feb 24, 2020 6:09 am Post subject: Re: Rust Prevention Product Testing |
I wire wheeled first, but yeah. Cat piss away! _________________ No boom today. Boom tomorrow. There's always a boom tomorrow. |
vwsplitman Samba Member
Joined: June 18, 2003 Posts: 322 Location: Plymouth, CT
Posted: Sun Mar 01, 2020 12:00 pm Post subject: Re: Rust Prevention Product Testing |
If you put the silver MS primer on new metal, I would either rough it up with a 220 grit sandpaper, or use a good metal prep(phosphoric acid) to etch the metal for good adhesion and to get any oils off. When using the MS silver primer by itself and no topcoat, we recommend 3 coats. It doesnt need a topcoat. UV wont affect it. Ive got pieces outside on a daily basis for over 14 years with no bad affects . To topcoat do it within a couple of days. If not then scuff everything down and then topcoat . Done testing and the MS silver by itself easily outlasts epoxy primers and etch primers as far as rusting. Chuck |
