Bruce Samba Member
Joined: May 16, 2003 Posts: 17546 Location: Left coast, Canada
Posted: Sun Jan 03, 2010 1:25 pm Post subject: |
MichaelBrenner wrote: |
So, I stripped down my AT case that had a 3.88 in it and swapped the pinion bearing/shims onto my 4.12. At the same time I installed a superdiff. I measured the turning force to determine the diff bearing preload, got 14 in lbs. spec is 5-7 for used bearings......
Where do I get diff shims to set the bearing preload correctly? I took out the races from the diff cover and the case, they had 0.70mm and 0.55mm shims respectively.
Where do I go from here? What can I do? I know I need to get my diff preload fixed to 5-7 in lbs. Then I'm shooting for about 0.005-0.007" backlash. |
Take the pinion shaft out and set it aside. You aren't ready for it yet.
The shim you have under the diff bearing race that is 0.55mm should be made from a 0.4mm shim and a 0.15mm shim. Remove the 0.15mm shim and see what the turning torque is then. (install the 0.7mm shim on the removeable sidecover, the .4mm shim on the starter side) _________________
MichaelBrenner Samba Member
Joined: July 16, 2008 Posts: 137 Location: Costa Mesa, CA
Posted: Sun Jan 03, 2010 1:31 pm Post subject: |
maybe I didn't measure it very well, my dad bunged it up a bit getting it out, I think it was actually a 0.60mm or maybe a 0.50mm. Anyway, I will do that, I need a 0.40mm or so to get me into the right range. Then the pinion drama next. _________________ Brenner Racing
SNORE 1179 |
Posted: Tue Jan 05, 2010 6:25 pm Post subject: |
Does anyone know what I need to do to adapt the 091 first gear idler for use in my transmission? What do I need to have machined? is it as simple as cutting it down to the same width as the stock 1st gear idler? _________________ Brenner Racing
SNORE 1179 |
Joined: May 17, 2003 Posts: 4873 Location: Harmony, PA
Posted: Tue Jan 05, 2010 10:47 pm Post subject: |
Does anyone know what I need to do to adapt the 091 first gear idler for use in my transmission? What do I need to have machined? is it as simple as cutting it down to the same width as the stock 1st gear idler? |
You'll need the 091 slider that has the reverse teeth on it as well. Some have taken the 002 slider, and machined the 1st gear side of it down to narrow it like the 091 slider, but most I've spoken with just use the 091 slider. And, yes you will need to slightly narrow the 091 gear on the syncro side to get proper 1st gear sideplay. You will also need the 091 syncro to go with the gear.
As for your 1.32 third gear modification, I'm sure Weddle could fix you up. |
Posted: Wed Jan 06, 2010 8:39 am Post subject: |
Steve at Weddle didn't know what I was talking about.
So do i need just the slider outside or the inside too? _________________ Brenner Racing
SNORE 1179 |
Posted: Wed Jan 06, 2010 10:58 am Post subject: |
You'll need the later splined inner hub portion, and the early outer slider portion. The issue is that the center of the keyed hub that fits the keyed gears is quite a bit smaller in diameter than the center of the splined hub. You could simply turn down the inside of the splined hub to the size of the keyed one, but this doesn't leave too much material on the hub. I'v talked with some that will turn down the hub some, then either narrow the early gear without the syncro hub to clear the modified mainshaft hub before welding them together, or turn down only a portion of the gear after it has been welded. The only time I have come in contact with this situation was when the 3.78 mainshaft was ground down to use the unmodified keyed hub, and gears. I received some good info about this over on the Ultimate Aircooled Forum.
http://ultimateaircooled.com/simplemachinesforum/index.php?topic=6256.0
Maybe you can contact some of the users that replied to the thread to get actual dimensions for the modification. |
Posted: Wed Jan 06, 2010 11:13 am Post subject: |
Hey John,
Thanks for all that! I just got a call back from weddle and they said to have the 091 cut to the same width as the stock gear from the engagement teeth side only.
Then have the stock type 1 slider machined 0.020" off the first gear side.
You just have to talk to the right people, communication is so important.
If I come out to Vegas I have to visit you and talk some class 11...... I think my second transmission will be better, and simpler than this first one. _________________ Brenner Racing
SNORE 1179 |
Posted: Mon Jan 11, 2010 4:33 pm Post subject: |
Great news everyone that was helping me figure this out. I finally installed the diff, measured the bearing preload and it was HIGH, about 15 in lbs. I had about 0.120mm total shims. I reduced it to 0.100mm and it came in right at 7 in lbs turning torque on used bearings. PERFECT. Then I split the shims equally 50/50 and had Zero backlash, not good, changed to 0.70mm on the case side and 0.30 cover side, TA DA, I got 0.006" backlash measured with a tool I made that measures at the radius of the ring gear! For everyone that has helped me understand what to do THANK YOU! Now I'm just working on getting the gearstacks fixed up and that's taking a while since I need some surface grinding on my 091 idler and the 1-2 slider. Everyone wants a ton of money for a 10 minute job..... _________________ Brenner Racing
SNORE 1179 |
Bruce Samba Member
Posted: Mon Jan 11, 2010 10:55 pm Post subject: |
Everyone wants a ton of money for a 10 minute job..... |
How is the pinion depth? _________________
Posted: Tue Jan 12, 2010 9:28 am Post subject: |
The gear mesh pattern looked great, centered height and depth wise. I think I may have had a little luck doing this. I took it apart and put it together at least a half a dozen times. I used a heat gun to heat the pinion bearing area and it is nice and snug. Remember I'm not too worried about the noise that so many are, this is a race car.... _________________ Brenner Racing
SNORE 1179 |
Bruce Samba Member
Posted: Wed Jan 13, 2010 12:52 am Post subject: |
This is what's called "Beginner's Luck". Next time you'll pay the price.  _________________
Posted: Tue Jan 19, 2010 11:29 am Post subject: |
FYI. You need to surface 091 first gear idler 0.010"-0.015" depending on which end of the spec for side clearance you want to end up on..... The 1/2 slider needs to be surfaced 0.020" to fit the idler gear engagement teeth all the way......
Those details are HARD to find, I consider this transmission Karma that should come back to me some day in the form of more good tips or good luck.
A wise man once told me, 'You'd rather be lucky than good, believe me'... _________________ Brenner Racing
SNORE 1179 |
Posted: Tue Apr 12, 2011 9:11 am Post subject: |
For the transmission gurus like Bruce on here that really get it when it comes to advanced mechanics I wanted to say thanks for helping me. My dad and I have now built 3 good transmissions. The first you remember was an OK build but unfortunately had a gleeson R/P in 4.12 along with the 1.26 3rd gear and a keyed super beetle (9 tooth) mainshaft.....
Not ideal. Since then I have built another offset rib cased, 4.12 O r/p, with a modified 113 1.32 third gear (cut to fit the stock late mainshaft), it also has a weddle side cover (thick) and a weddle diff cover (nice) and a 300m input shaft. 4th gear is stock 0.93 fine tooth because it's just in there for the ride anyways. That transmission too I got 'lucky' and hit the backlash at 0.0055" on my first try after setting the diff preload to 8 in lbs using used bearings.......
For anyone interested in the 091 first gear idler conversion you simply take the gear (Weddle $14) and get a belt sander (80 grit) and grind it about 0.008-0.010". It will setup perfectly if you do that. On the clutch gear just grind the 1st gear side 0.020" so it engages fully. Don't forget you'll need the 091 1st gear syncro for this conversion as well.
My first transmission went approximately 600 race miles and I changed the gear oil every time to monitor how much of the r/p was coming off. Overall it looked very good each time.
Then we built this newest trans and it's got about 200 miles on it. The first transmission is sitting as a good spare incase we have a problem and we will upgrade some stuff in it soon using a 1.32 3rd, a 4.12K I have sitting around and probably a stock 4th gear all on a stock late mainshaft.
Overall I got a lot of good racing out of that first trans and I want to say big thanks to you guys. Racers kind of trip out when they see me passing them and know that I build our motor and trans.... My dad can't believe we do it all and I just tell him it's the power of the internet.... _________________ Brenner Racing
SNORE 1179 |
Posted: Tue Apr 12, 2011 6:36 pm Post subject: |
There is a lot of info on the internet, some good, and some bad. It's the people like Bruce that actually know what they are talking about, and are willing to help others, that makes it great. I've had one too many life situations in different forms of competition where I've eventually learned everything I needed to know by myself, but certian people around me could have made life so much easier by simply "throwing me a bone", but chose to be assholes keeping everything to themselves. I try and help any way I can. It's cool you've been able to find out how to rebuild a transaxle, but you're one of the few that have seen it through to the end. There are a lot of people that aren't as adventurous as yourself, and give up very easily when things don't work out. Now you can save a little bit on rebuild labor for the future, and have the satisfaction knowing you're the one that built the tranny. |
mcmscott Samba Member
Joined: March 12, 2010 Posts: 4917 Location: sanger ca
Posted: Tue Apr 12, 2011 8:05 pm Post subject: |
How many times have you passed Robert Johnsen? Or Erick Solorazano? I know who does there trans, keep it up, you will be an ace before you know it. GOOD LUCK |
Posted: Fri Apr 15, 2011 11:57 am Post subject: |
If you want evidence of me beating up on Robert and Eric just check out Laughlin and Primm from last year and this year..... I have GoPro video of Eric pulling over for me on the last lap at Laughlin day 1, never saw him on day 2. The first time I ever beat Eric/Robert they were actually having transmission issues, but I'm sure there's a story behind that too.
But I don't want to talk smack, those guys are cool guys. Eric shook my hand when I passed him at Laughlin and Robert is always nice to me too.
I don't know the metalcraft guys but I know some racers swear by them. I would love to touch base with those guys sometime, do you know them well? I'm sensing some tone there???
snoreracing.net _________________ Brenner Racing
SNORE 1179 |
Posted: Sat Apr 16, 2011 9:38 am Post subject: |
No tone just playful sarcasm, I enjoy building vw trannies and experimenting with different setups and such, if you ever have any questions on how I set them up feel free to ask, I'm always willing to help fellow racers. Btw the mcm in my avitar is for Metelcraft motorsports, I'm also the only central Cal. Mendeola dealer. Keep working on it, only experience will prove what works and what don't.  |
RockCrusher Samba Member
Joined: August 03, 2010 Posts: 4596 Location: Parkesburg, PA
Posted: Sat Apr 16, 2011 10:22 am Post subject: |
mcmscott wrote: |
Btw the mcm in my avitar is for Metelcraft motorsports |
Ahhhhh....I thought maybe it was for MCM electronics for whom I am a dealer in the home theater and communications business. Real crappy business right now except for the computer end. http://www.totalhomemediadesign.com/ _________________ [email protected] Please use email for all general inquiries.
I will be happy to speak to anyone who has a serious inquiry (meaning real potential business for RC enterprises) or a parts order. Due to machining noise causing missed calls all calls will be returned promptly. |
Posted: Sat Apr 16, 2011 3:24 pm Post subject: |
I just relized my spelling really sucks! Its MetalcraftMotorsports, not Metel , time for another beer!  |
Posted: Mon Apr 09, 2012 8:38 am Post subject: |
I have built two SSC transaxles with the 091 1st gear idler and adjust the gear by surface grinding the gear approximately 0.012" to get the proper side gear clearance. On the slider gear I have ground the 1st gear side 0.020". On the most recent transaxle, it won't go into first gear, it just grinds the engagement teeth. I was reading on shoptalk forums that the 091 slider is 0.940" wide and most sliders from a type 1 are 0.980" and that I could just use a 091 slider. Should I grind my slider another 0.020"? On the first transaxle it worked great with just 0.020" ground only. _________________ Brenner Racing
SNORE 1179 |
