OTTO 1303 Samba Member
Joined: March 17, 2020 Posts: 655 Location: Louisiana
Posted: Sat Mar 16, 2024 3:10 pm Post subject: Re: What did you do to your Bug Today? |
Removed the fuel tank and released the upper steering joint to remove the steering box.
Appears to have leaked a long time ago and has probably been lacking lubricant for years.
Now for cleanup and rebuild. _________________ 74 Super Sun Bug - OTTO
74 Super - DANZIG
74 Super - HERZOG |
Posted: Sun Mar 24, 2024 2:29 pm Post subject: Re: What did you do to your Bug Today? |
Completed steering and front suspension removal.
Everything will be reconditioned and/or replaced as needed, including strut rebuild. _________________ 74 Super Sun Bug - OTTO
74 Super - DANZIG
74 Super - HERZOG |
Ajros Samba Member
Joined: December 08, 2023 Posts: 6 Location: Waterbury, Connecticut
Posted: Sat Mar 30, 2024 5:07 pm Post subject: Re: What did you do to your Bug Today? |
Power washed the engine bay. Degreased, wiped and rinsed it. Definitely need to give it another pass, but this was my first try after picking up the 74 Super back in December.
While the pressure washer was on I gave it a good exterior wash before driving it around the block.
_________________ 1974 Super Beetle |
Lost69Convertible Samba Member
Joined: July 29, 2020 Posts: 453 Location: Rhode Island
Posted: Mon Apr 01, 2024 6:28 am Post subject: Re: What did you do to your Bug Today? |
Today I tuned my antenna to improve radio reception from 91 to 104 MHz
_________________ 1956 Beetle Ragtop: My Father's car
1969 Beetle Convertible: My first car. I loved it, I lost it, and I never got over it.
1979 Super Beetle Convertible |
stagewex Samba Member
Joined: November 17, 2021 Posts: 170 Location: New Rochelle, New York
Posted: Tue Apr 02, 2024 6:55 am Post subject: Re: What did you do to your Bug Today? |
Ha, Good One. |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31509 Location: Hot Arizona
Cusser Samba Member
Posted: Wed Apr 10, 2024 2:04 pm Post subject: Re: What did you do to your Bug Today? |
1971 Super Beetle Convertible, mine since 1976.
Today I drove to the $4 self-serve car wash, washed off the transmission (original, has never been out of the car or had its drive axles unbolted), and scraped off 53 years of hardened gear oil and dirt (safety goggles absolutely necessary). Then I tightened all the transmission case nuts I could find. Of course I knocked off the wire to the starter solenoid, but noticed it and re-connected it). What a mess !!!
Then I added GL-4 gear oil, last topped off in 2008.
_________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Gman73 Samba Member
Joined: April 25, 2018 Posts: 80 Location: Spotsylvania, VA
Posted: Sat Apr 13, 2024 6:25 pm Post subject: Re: What did you do to your Bug Today? |
I cut my frunk handle off of my 79 and replaced the extremely wallowed out latch (due to an accident with one of the previous owners.) also ran a choke cable trough the fender as a last result frunk opener upper. realised the spring was collapsed on the part that goes into the latch. will be looking for a stronger spring in the morning. |
Gman73 Samba Member
Posted: Sat Apr 13, 2024 6:31 pm Post subject: Re: What did you do to your Bug Today? |
oh yeah... also fitted a bus shifter in the SB. its ridiculous
Posted: Sun Apr 14, 2024 7:04 am Post subject: Re: What did you do to your Bug Today? |
I adjusted my valves this weekend.
Any valve that needed adjustment, I completely removed the adjuster screw and lock nut. I cleaned the threads and coated them with engine oil. I also dabbed engine oil into the internal threads of the rocker arm. This makes the final valve adjustment a lot easier for me. No binding. _________________ 1956 Beetle Ragtop: My Father's car
swede-german2 Samba Member
Posted: Sun Apr 14, 2024 11:15 am Post subject: Re: What did you do to your Bug Today? |
Halfway done replacing the seals on both of my pop outs. After that it will be time for a wash, then a drive around the lake! _________________ '69 Bug (stock daily driver)
'66 Bug (a field rescue nightmare)
'65 Bug (in a state of disarray!)
'64 Bug (in progress)
'74 MILF (upgraded to MIF in '02) |
PiperFixer Samba Member
Posted: Sun Apr 14, 2024 4:21 pm Post subject: Re: What did you do to your Bug Today? |
Changed gear oil.
Replaced generator brushes.
Installed the WW de-smell kit.
Cleaned my back up fuse holder and replaced the fuse, still no reverse lights. Probably need to clean the contacts at the bulbs. |
Posted: Wed Apr 17, 2024 9:45 am Post subject: Re: What did you do to your Bug Today? |
Gman73 wrote: |
I’d like to do same
How do you like it? _________________ 74 Super Sun Bug - OTTO
74 Super - DANZIG
74 Super - HERZOG |
Posted: Fri Apr 19, 2024 4:14 pm Post subject: Re: What did you do to your Bug Today? |
I changed my transmission oil. And while doing the job, I could no longer ignore the quarter inch of dirt and oil caked on the transmission. In general I like the engine and transmission a little greasy and oily. But this was too much even for me. So I cleaned it.
BCE56 Samba Member
Posted: Fri Apr 19, 2024 7:48 pm Post subject: Re: What did you do to your Bug Today? |
Speedo went kaput yesterday.
Cable had disengaged from dustcover. E clip was AWOL...
Snaked the cable thru and snapped on a new E clip.
Found and fixed an annoying rattle in the passenger door.
Two for two! _________________ =BCE56=
'86 Syncro tintop
EJ22, OBD II early SC adapter plate conversion
Side project: '69 Frankenbug "It's alive!" |
unclewede Samba Member
Posted: Thu Apr 25, 2024 8:18 am Post subject: Re: What did you do to your Bug Today? |
Ordered a new car cover. The existing one seems to have seen too many sunny days. It wasn't designed for the bug, may actually have been from a pickup I no longer own. The other day, when I simply tried to move it more central on the top, split along the seams.
None of the replacements I found had a hole for the antenna. Even when I push it all the way down, it's up a bit and lifts the cover in that area. Rubber dohickey, grommet, ??? so I don't forget to pull up the antenna and can only listen to one station? |
Cusser Samba Member
Posted: Thu Apr 25, 2024 11:06 am Post subject: Re: What did you do to your Bug Today? |
Lost69Convertible wrote: |
I changed my transmission oil. And while doing the job, I could no longer ignore the quarter inch of dirt and oil caked on the transmission. So I cleaned it. |
You did a better job on yours than I did on my 1971's factory transmission a couple of weeks ago. While changing the gear oil, I used a putty knife and screwdriver to scrape off 53 years of gunk.
I also tightened every transmission case nut I could. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Thu Apr 25, 2024 5:04 pm Post subject: Re: What did you do to your Bug Today? |
Cusser wrote: |
You did a better job on yours than I did on my 1971's factory transmission |
I’m not so sure about that. I used degreaser and a wood dowel as a scraper. I didn’t wear any breathing protection - stupid. I got degreaser deep in my sinuses. It’s all I could smell for days! _________________ 1956 Beetle Ragtop: My Father's car
SemperVivus Samba Member
Posted: Sun Apr 28, 2024 10:51 am Post subject: Re: What did you do to your Bug Today? |
Installed this the other day. It’s a bit much (60% throw reduction). I think the 40% would be smoother. High quality part with tiny shift throws. |
Gman73 Samba Member
Posted: Sun Apr 28, 2024 12:22 pm Post subject: Re: What did you do to your Bug Today? |
OTTO 1303 wrote: |
Gman73 wrote: |
I’d like to do same
How do you like it? |
I'm okay with it. I takes a little getting used to it, the wife said she could get used to it. also has the short shifter spacer in it. |
