Retired Samba Member
Joined: January 22, 2005 Posts: 10 Location: North Carolina
Posted: Sat Apr 23, 2005 8:21 pm Post subject: How to replace the wing vent |
| Driver side wing vent repair: The latch fell off the vent frame. A hole is now in the frame. Can it be repaired? I would like to know how to remove the vent window in the event I have to repace the entire unit. Any advise is to be appreciated. Thanks |
rjoerger Samba Member
Joined: March 26, 2008 Posts: 6 Location: richmond virginia
Posted: Sat Mar 29, 2008 11:34 am Post subject: |
| do you know how to remove the latch that needs replacement? |
Bugs'n'Pugs Samba Member
Joined: July 18, 2004 Posts: 1453 Location: Charleston, South Carolina USA
Posted: Sat Mar 29, 2008 7:49 pm Post subject: Re: How to replace the wing vent |
| Retired wrote: |
I believe that the latches are held on by rivets. So, yes, it can be repaired without replacing the entire assembly. _________________ 1978 Super Beetle Convertible (Project)
Post a Photo in the Forums
Rescue Man's Best Friend |
johneliot Samba Member
Joined: August 29, 2005 Posts: 2195 Location: Chico, CA
Posted: Sun Mar 30, 2008 10:35 am Post subject: |
Yes you can replace the vent wing latch but it entails taking out the wind wing from the door, removing the wing from the frame, removing the glass and then drilling out the rivets from the bottom of the latch and putting the new one in. Not a difficult job but time consuming. If you have access to a junk yard that has a few bugs, it might be easier and faster to find one that has a good latch and just replace the entire assembly.
John _________________ John
There is no distinctly American criminal class - except Congress.
Mark Twain
69 bug - "The Grey Ghost" |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25186 Location: Central Iowa
Posted: Sun Mar 30, 2008 4:56 pm Post subject: |
Open the vent wing all the way out, and look underneath. There are 2 rivets.
Drill out these rivets, and the complete latch assemble will come out from under the glass.
Get a new latch assembly from a parts supplier, and slide it back under the glass, and put it back into place with 2 - 1/8" pop rivets.
You are done. You do not have to pull the vent wing assembly out to replace the latch. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
Posted: Sun Mar 30, 2008 5:41 pm Post subject: |
Russ, I have never heard of it being done that way! What an incredible time saver. I have a latch to do and I'll give that a try. Learn something new everyday! Thanks.
Mark Twain
mnussbau Samba Member
Joined: August 26, 2006 Posts: 4610 Location: Central Maryland
Posted: Sun Mar 30, 2008 5:47 pm Post subject: |
I actually replaced the vent wing latch on my convertible using the same technique, although I did remove the glass (was easy due to the design of the wing). I pulled the rivet from above, and had to file down the top of the crushed portion a bit so everything would go back together, but it's nice and tight. _________________ Mike
‘74 bug vert
Parts... |
