JEECOMAN Samba Member
Posted: Mon Jun 27, 2005 8:48 am Post subject: Avis adjuster install ??'s |
I have a 65 bug I'm installing avis adjusters in. The problem I'm having is removing the original center support for the torsion leaves. My beam has 2 gooves stamped for holding the center section.
Is there an easy way to remove the center section? I already did one of the beams but it wasn't easy. I only cut out one of the grooves and beat the center section out with a pipe. Are you supposed to cut out both grooves and weld a plate over the other groove that doesn't take the adjuster?
I've done the search and it seems there are different factory ways of retaining the center support. Does the "other" groove have to be removed to get the new center support in? It seems that by cutting out both grooves the beam strength would loose some of it's integrity.
Any body have any tricks or tips? |
RareAir Samba Member
Joined: May 11, 2002 Posts: 14577 Location: 18 miles North of the border
Posted: Mon Jun 27, 2005 9:30 am Post subject: |
Those grooves you're referring to are the dimples that lock the center bearing in place. An easier method to remove them might be if you drill both ends of the football dimple out with a 1/2-inch drill bit. Then use a die grinder to remove the remaining center section.
You do NOT need to remove the center bearing. You only need to break it loose so that it will move freely up & down. That's how the Berg instructions describe the process. Hope that helps. _________________ 1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241 |
Posted: Mon Jun 27, 2005 9:40 am Post subject: |
Are you supposed to leave the original center support in and not use the one that comes with the new adjusters?  |
bill may Samba Member
Joined: August 27, 2003 Posts: 14160 Location: san diego,ca
Posted: Tue Jun 28, 2005 6:07 am Post subject: |
The kit comes with a new center support that goes inside the tube, 2 "toothed" pieces (one to weld on and one to adjust), a bolt, and 2 nuts. The dimples in my beam are about 1" long on both sides of the beam. The new center support is a round collar that fits inside the tube and accepts the torsion leaves like the original collar. The original center support is the same except it has grooves machined in the outside edge of it on both sides where the dimples hold it in place.
I think you have to remove both dimples (1" long on both sides of the beam) to get the center support to move. |
Posted: Tue Jun 28, 2005 6:51 am Post subject: |
This is a schematic of the center bushing inside a beam.
You're trying to tell Bill & I that your Avis adjuster kit came with a replacement piece for it? Here what an Avis adjuster looks like when installed.
The center bushing remains intact. No need to remove or replace it. it just has to move freely up & down. _________________ 1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241 |
jps1145 Samba Member
Joined: March 16, 2005 Posts: 654 Location: Tehachapi, CA
Posted: Tue Jun 28, 2005 7:11 am Post subject: |
The easiest way to do it, may be to cut a section out of each tube, like you would with a select-a-drop adjuster, and weld in a new piece with a slot in it. Then weld the avis adjuster on to that.
The only drawback that these adjusters have is that you can't adjust the ride hieght with the weight of the car on the ground. There's a bit more trial and error. In the case of off road cars, you can't "preload" the springs easily either.
-J _________________ Tehachapi, CA
'69 Baja
Vintage Funco single seater
My Baja |
Posted: Tue Jun 28, 2005 8:00 am Post subject: |
Yes the kit comes with a new center support. In order to make the old center support work the dimples/creases in the beam must be removed |
jspbtown Samba Member
Posted: Tue Jun 28, 2005 11:43 am Post subject: |
| I agree, the Avis adjusters I purchased (Moore Racing?) came with a new center section. I ended up drilling and grinding those dimples out, and then after I welded the adjuster in, I added a piece of flat stock around the tube. This may be hard to explain...I took a 1 inch wide piece of flat stock (1/8" thick?) and tacked it onto the upper edge of the part of the adjuster I had welded onto the beam. Then I was able (by keeping the flat stock peice extra long) to bend the stock around the beam, tacking as I went along. When I was at the bottom part of the adjusted, I used my angle grinder to cut it off, and used a large c clamp to pull the end down tight to the tube. I then finished welding both sides. |
Posted: Tue Jun 28, 2005 1:02 pm Post subject: |
| Thank you! I knew I wasn't the only one having trouble. |
