Replacing the Carpet - should i go OEM?
porterbrown
porterbrown is offline
PostPosted: Thu Jul 28, 2005 7:14 pm    Post subject: Replacing the Carpet - should i go OEM? Reply with quote
all of my carpet must be replaced and i've been struggling with the decision, whether to buy a good-used OEM carpet kit (that IS available) or have it done by a vanagon interior specialist (sewfine interiors).
i'd instantly go w/ sewfine if they didn't glue the carpet down - oppose to the easily removable OEM molded carpet. these carpets are no longer manufactured. any ideas???
thanks for the help!
r39o
Samba Polizei
r39o is offline
PostPosted: Thu Jul 28, 2005 7:24 pm    Post subject: Reply with quote
Depending on your needs, you have options. In my van we yanked the carpets and cleaned them. Pretty easy in this hot weather.
Or you could pull some out of a parts van at a bone yard. Or get a few pieces here and there until you get what you like.
Typically, the aftermarket ones in kit form only fit so, so. One that is made and installed by a shop is better. Sometimes, they do not work out as well as the OE ones. Pedals hang, bludges and so on.
In my case we also have a set of carpets that were made like matts to cover the OE carpet. On top of that I use the OE "Vanagon" rubber mats.
porterbrown
PostPosted: Thu Jul 28, 2005 7:34 pm    Post subject: Reply with quote
only cleaning the carpet isn't really an option - i'm trying to replace some carpets that were burned in an electrical short. i've found a guy that will ship me good-used OE carpet. i'd love to let sewfine do it, but i just can't get past the glueing part. i'm sure that i'll eventually need to get under there...
supplicationjam
supplicationjam is offline
PostPosted: Thu Jul 28, 2005 7:44 pm    Post subject: Reply with quote
I put a sewfine kit in mine. I think I went through 2 cans of 3M carpet glue. It took me a full day but there aint nothing better than driving barefoot in a VW bus with nice new carpet. This winter I'm going to rip it all out and put soundproofing down so consider that and see mightyarts post on soundproofing.
I got some butcher paper and layed down my pieces on the floor of my garage and then layed them in. I also sprayed both the back of the carpet and the area the carpet was adhering to. Watch for overspray when spraying inside the van. Use butcher paper or masking tape to mask areas you don't want glue on. Once you glue down a few pieces you'll get the hang of it. I think it's way better than the formed OE piece. More plush!
87 Westy, DiscoII
Gunny, CO.
porterbrown
PostPosted: Thu Jul 28, 2005 7:55 pm    Post subject: Reply with quote
supplicationjam, tell me more about sewfine. i was initially very excited about using these guys because they work on show cars and do beautiful work. but, now i'm worried about their kit's functionality - what happens when you need to access the firewall, etc...? i was told by sewfine that you CAN'T peel this stuff up and still salvage the carpet.
just today, the OE kit started to sound the most attractive, especially since i've decided against sewfine's carpet mats because they don't use a real backing...........it's mostly cut and bound carpet.
i'm torn on the decision. i'm NOT concerned about price - this was from fire-damage, so it's being payed for by my insurance company.
supplicationjam
PostPosted: Fri Jul 29, 2005 4:23 am    Post subject: Reply with quote
The kit doesn't cover anything that you need to gain access to. I've read about some of the crazy glues and formica cements that some people use and that might prohibit getting the carpet back up easily but if you'll use the 3M carpet glue you can take it back up and put it back down. The 3M glue is kind of gummy and on several pieces I had to lift and reapply and it wasn't a problem. In my line of work I work with tons of different adhesives from metal glues like they use to build airplanes to very high bond tapes etc. and I was real impressed with this carpet glue. Also if your insurance company is paying for it go see a carpet guy and get an estimate from him to install it for you!!! Then if you decide to do it yourself you can rightfully pocket that amount of money.
87 Westy, DiscoII
Gunny, CO.
DanJReed
DanJReed is offline
PostPosted: Fri Jul 29, 2005 5:20 am    Post subject: Reply with quote
I got a GoWesty carpet kit two years ago.
A little less than OEM quality, but fits well, and looks great!!
Much better than the 200K miles of spilled drinks and food the van came with!!!
I used double sided carpet tape and "heads up" interior spray. Stuff sticks well.
-Dan
(87 Westy Vanagon, 98 Jetta GLS 2.0, 95 Golf Sport) VW Logo
mightyart
mightyart is offline
PostPosted: Fri Jul 29, 2005 8:01 am    Post subject: Reply with quote
I've heard good things about sewfine. I need new carpent myself.
I think I'll just go the Gowesty way like Dan did.
New carpet is one of the last things I'm getting. I'm still doing some messy work on her. I've already knocked a bottle of brake fluid over on the old carpet. I wasn't happy about it but if it
had been spilled on a new carpet I'd just put in, then I would have looked
like this poor chap here- Crying or Very sad
My Art:
http://www.instagram.com/flynn8552/
r39o
Samba Polizei
r39o is offline
PostPosted: Fri Jul 29, 2005 8:21 am    Post subject: Reply with quote
I recently took some of the carpet out of my Westy before we painted it. It looks like it was glued down with something very similiar to the 3M glue. Unless it is very worn (falling apart) or very heavily stained, I have found you can oft times make the OE materials (not just carpet) look really really good and clean. You have to take it out and you have to apply a lot of elbow grease but it turns out nice, usually. On seats we even take a pressure washer to them and then let them sit outside for a few days. In the Summer it works out well. Ditto the carpets. But, if you carpets are smoked, then, of course, you need to replace them.
Since they do not contribute to the performance of the van, ditch them, you'll get better gas milage! Smile Smile Smile
supplicationjam
PostPosted: Fri Jul 29, 2005 8:52 am    Post subject: Reply with quote
I ordered my kit from Gowesty too but it shipped directly from the sewfine factory.
87 Westy, DiscoII
Gunny, CO.
DanJReed
DanJReed is offline
PostPosted: Sat Jul 30, 2005 4:34 am    Post subject: Reply with quote
Same here.
-Dan
porterbrown
PostPosted: Sat Jul 30, 2005 6:27 pm    Post subject: Reply with quote
oh, really??? so, gowesty sells the "sewfine" kit........hmmmmmm......interesting. Wink
man, i'm seriously torn on this decision - especially since i told my mechanic what my choices were. he highly recommended that i NOT get a glue-down kit installed, since it's pretty likely that i'll need to get back under the carpet sometime.
so, it sounds like some of you have had success installing yourself in a fashion that you feel confident that you could peel it back and re-glue when needed, but i specifically asked sewfine about this and they said that "most-likely, if you peel it back or have to break the carpet from the glue, then it's gone......meaning that you would need a new carpet piece for that section". i don't know...
Connie
Connie is offline
PostPosted: Sun Jul 31, 2005 10:13 am    Post subject: Reply with quote
My 81 westie came with brand new carpet from West Coast Metrics. I have a child and we go to the beach a lot, so i have been thinking about an alternative. I spoke to an old guy here, with a 80, ivory westy, and he installed some wood flooring in his. The kind that snaps together, that they use in houses. Looks awesome and spills and sand are just swept up or wiped clean. I am seriously thinking of installing some in the future. Said it costs about 30 bucks!!
supplicationjam
PostPosted: Sun Jul 31, 2005 10:51 am    Post subject: Reply with quote
I don't know why you would need under the carpet again..... Even so if you use the 3M glue it should be as easy to get up as the OE you pulled out. I'lll take the plush kit anyday over used OE. Maybe sewfine is assuming you're going to use contact cement or something. I think it's a non issue.
87 Westy, DiscoII
Gunny, CO.
DanJReed
DanJReed is offline
PostPosted: Sun Jul 31, 2005 2:36 pm    Post subject: Reply with quote
Yea, the stuff I used can come off if you need it to. I didn't use a lot of it, and its held up well.
EVERYTHING comes off with enough force! Laughing
-Dan
McHuntley
McHuntley is offline
PostPosted: Sun Jul 31, 2005 4:15 pm    Post subject: Reply with quote
anybody tried putting wood in?
Just for the cargo section, like in a westy?
Any opinions stated here are my own, otherwise someone else would have said them.
bigdood
bigdood is offline
PostPosted: Mon Aug 01, 2005 4:01 pm    Post subject: Reply with quote
yup, i put some wood in the cargo area. ridiculously easy to do, and looks pretty damn good. pic below from before i put the rubber trim on. planning to do a little bit more in wood (between seats, but keep carpet in front) when i get some time.
[img]http://www.thesamba.com/vw/forum/album_page.php?pic_id=218798[/img]
bigdood
bigdood is offline
PostPosted: Mon Aug 01, 2005 4:02 pm    Post subject: Reply with quote
DOH!!!!! image linkin' didn't work. cut/paste, or check my gallery, to see it.
CF
CF is offline
PostPosted: Tue Aug 02, 2005 4:24 am    Post subject: Reply with quote
I just pulled the carpet from my eurovan. A gallon of coolant spilled on the floor. I am considering the wood floor. Qt. how difficult, and I have a center seat.
DanJReed
DanJReed is offline
PostPosted: Tue Aug 02, 2005 5:42 pm    Post subject: Reply with quote
Wow, that looks really nice!!!
-Dan
