pocvw Samba Member
Posted: Mon Aug 22, 2005 5:05 pm Post subject: Tire Differences |
Ok, keep in mind that I am poor...
...in taking a closer look at my tires, I noticed that the two front tires are sized at 185, and the two back tires are sized at 195. Also, there are three different brands of tires on there, and only one tire 'seems' to be what the heavy Westy needs as the max. tire pressure is 55 psi for that tire.
I pretty much only do in-town driving, so, my question is this - am I safe, for now, in keeping these tires, or do I need to spend the approx. $400 to get the correct ones now (don't forget the first line of this forum)?
Thank you! _________________ Life is a garden - dig it!
1980 VW Westfalia |
r39o Samba Polizei
Posted: Mon Aug 22, 2005 5:18 pm Post subject: |
185 in the front and 195 in the rear is a pretty neat combo for the tail heavy, high reving Vanagon. If the tires are rated for the load and you are not going too fast or far they should be OK *IF* they are not cracking. If they handle OK for you fine. If not, do something. _________________ "Use the SEARCH, Luke" But first visit the Vanagon FAQ!
pocvw Samba Member
Posted: Mon Aug 22, 2005 5:36 pm Post subject: |
Only one of the tires seems to have the correct load - the other three are not the correct tires. And since I don't know the difference between having the better tires for a better ride and not having them, I am fine with how the van rides. I will keep my eyes on the tires, though. I noticed that the sidewall on one of the back tires has a couple of waves in them, which I know can't be good, but I figure since I am only doing in-town driving, hopefully I'll be good until I can scrape up $350-400. _________________ Life is a garden - dig it!
1980 VW Westfalia |
DanJReed Samba Member
Joined: July 30, 2004 Posts: 548 Location: Riverton NJ
Posted: Mon Aug 22, 2005 6:57 pm Post subject: |
What's your life worth.
I think its worth at least $400.00
Do the right thing and at least be able to sleep at night with the right tires! _________________ -Dan
(87 Westy Vanagon, 98 Jetta GLS 2.0, 95 Golf Sport)  |
r39o Samba Polizei
Posted: Mon Aug 22, 2005 7:03 pm Post subject: |
Buy the tires on 90 days same as cash and pay one third per month and with the third payment you are done. I've done that.
Use a credit union credit card with a low interest rate.
You MUST have the correct load rating with a Westy.
You do not want to have a tire failure. It can be real bad in that heavy van.
You can go cheap too. I thought I saw Vanco 8s in 185 for $52 or $56 each. GOOD TIRE for the Westy. _________________ "Use the SEARCH, Luke" But first visit the Vanagon FAQ!
r39o Samba Polizei
Posted: Mon Aug 22, 2005 7:07 pm Post subject: |
I did a quick check. The correct tire: Vanco 8 in 185 is $52 from Discount Tire. Plus tax and $10 per tire mounting and balance. Then there are a few dollars to toss you old ones away.
So that is:
$208+tax+$40+$20=$268+tax or less than $300
Got to be worth that, right? _________________ "Use the SEARCH, Luke" But first visit the Vanagon FAQ!
pocvw Samba Member
Posted: Mon Aug 22, 2005 7:33 pm Post subject: |
Thanks for the great advice....you guys are right. Ok, so, the Discount Tire place is on-line? Do I just order the tires and take them to a tire place? Also, what is the price difference for the 195s? How well are those tires in the snow? Thanks guys! _________________ Life is a garden - dig it!
1980 VW Westfalia |
pocvw Samba Member
Posted: Mon Aug 22, 2005 8:03 pm Post subject: |
Ok, so I have gone to the Discount Tire website. After punching in where I live and the tire size (195 70 14), they came back with tires that I haven't heard as being recommended for the heavy Westy. Also, when I do a search by brand, there are no Agilis (by Michelin) or Vanco 8s (by Continental). Am I on the wrong website or is it because of where I live that they don't have the right tires for the Vanagon? _________________ Life is a garden - dig it!
1980 VW Westfalia |
levi Samba Member
Joined: February 11, 2005 Posts: 5522 Location: Las Vegas
Posted: Mon Aug 22, 2005 9:32 pm Post subject: |
which great american city are you in?? |
Karl Samba Member
Joined: January 29, 2001 Posts: 6170 Location: Coos Bay, Oregon
Posted: Mon Aug 22, 2005 10:00 pm Post subject: |
pocvw wrote: |
Ok, so I have gone to the Discount Tire website. After punching in where I live and the tire size (195 70 14), they came back with tires that I haven't heard as being recommended for the heavy Westy. Also, when I do a search by brand, there are no Agilis (by Michelin) or Vanco 8s (by Continental). Am I on the wrong website or is it because of where I live that they don't have the right tires for the Vanagon? |
Tire Rack has them. But your correct size is 185R14. Look on your door post or by the steering column for the correct tire size.
http://www.tirerack.com/tires/Sizes.jsp?make=Continental&model=VANCO-8 |
Crankey Samba Member
Posted: Mon Aug 22, 2005 10:06 pm Post subject: |
I'm not shure that you'd get a 'deal' on the mount and balance unless you go to a phisical store....maybe :shrug:
call a service station and ask what mount and balance for all 4 if you get 'em online.
there are plenty of hills around town (here anyway) and it's a seriously sick feeling sliding into someones rear end on a rainy day, if you hit them, it's way worse !!  |
pocvw Samba Member
Posted: Tue Aug 23, 2005 7:58 am Post subject: |
I know that the correct size is 185s, but I can go with the 195s, right? So, if I order these on-line, then I am going to have to find someone to mount them (I wonder what they'll charge me to mount them knowing that I didn't buy their tire?).
I live in Pocatello, Idaho, btw. Not much selection around here (Les Schwab, Big O, Commercial, Tire Factory, and some local places). Anyway, I like the 195s because they are just a bit wider. Are the Vanco 8s good in snow? _________________ Life is a garden - dig it!
1980 VW Westfalia |
r39o Samba Polizei
Posted: Tue Aug 23, 2005 8:16 am Post subject: |
I phoned the Discount Tire here. I understand it is also called America's Tire, too, elsewhere in the country. I knew Tirerack had them also.
The Vanco's are the same tire they put on the Mercedes ML SUVs. I live in a sunshine / no salt state of California. What's snow? You should go read the on line comments about them. I am fairly sure people have posted comments here too. Go to the Continental Tire website too.
Currently I have Cooper's on my van. Not the best, but I took them off a parts van I bought. They are OK, too. Load range D and are rated to 65 psi. I keep them at 55 and they don't squirm. I am still restoring my van and therefore better tires have not made it to the top of the list yet. _________________ "Use the SEARCH, Luke" But first visit the Vanagon FAQ!
brownbetty Samba Member
Posted: Tue Aug 23, 2005 11:21 am Post subject: les schwab |
I've used Les in Oregon, very quick and helpful. they put some Jupiter tires on my westy. they will also sipe the tires, helps them last longer, better traction too. they do it all in one stop, they have some good service garuntees too, i think flat protection, check em out... _________________ 1984 Vanagon Gl Wolfsburg camper
Look out! He's got a towel!! |
r39o Samba Polizei
Posted: Tue Aug 23, 2005 11:25 am Post subject: |
Somewhere (here) I read you can get awsome deals on tires at (of all places) Walmart by having them order them. I may check into that, too. Specifically, I recall, someone writing they got a superiour deal on Michelin Aegillis, if I am not mistaken. _________________ "Use the SEARCH, Luke" But first visit the Vanagon FAQ!
Ericthenorse Samba Member
Joined: October 03, 2004 Posts: 782 Location: Los Osos CA.
Posted: Tue Aug 23, 2005 11:28 am Post subject: |
Betty... What do you mean "sipe" the tires.... sounds like they were trying to sell you a muffler bearing or something(only exist on Rolls Royce)....  _________________ '69 bug--rusty as hell
'91 vanagon carrat-slammed,5 speed,4 wheel disks,17x8.5's |
panic Samba Member
Joined: July 18, 2005 Posts: 59 Location: Portland, OR
Posted: Tue Aug 23, 2005 1:26 pm Post subject: |
Sipe is where they make little cuts in the tire that supposedly gives them better traction, longer life, and quiter ride. Many people debate the effects and it can void the warantee of a tire.
http://www.lesschwab.com/Siping.html  |
Posted: Tue Aug 23, 2005 4:04 pm Post subject: |
panic wrote: |
Sipes are BS.
The tires on my Westy - Vanco 8's - look like they'd be good in snow, they are an "all season" tire.
I got them VIA tire rack back in the spring. They ride nice. I got the 185s.
I shoulda got the 205s..  _________________ -Dan
r39o Samba Polizei
Posted: Tue Aug 23, 2005 4:25 pm Post subject: |
Why the 205s? Will they fit?
I plan on the 195s because I want to reduce my high way RPMs. 4K PRMs at 70 MPH sure is buzzy. _________________ "Use the SEARCH, Luke" But first visit the Vanagon FAQ!
pocvw Samba Member
Posted: Tue Aug 23, 2005 5:30 pm Post subject: |
I like the 195s, too. I have heard that the 205s make it harder to steer (and since I don't have power steering, I think I'll stick with the 195s). Wal-mart, huh? I don't think the Michelin Agilis comes in a 195 though. I think they have 185 and 205. I'll have to check on the America Tire (probably don't have one). Didn't someone order some tires off the net here? Where did you go to have them mounted? Did they charge you an arm and a leg cuz u didn't buy their tires? _________________ Life is a garden - dig it!
1980 VW Westfalia |
