Mbechmann Samba Member
Posted: Tue Sep 27, 2005 7:16 am Post subject: Saxomat transmission |
I am looking for some pictures of a complete saxomat transmission. All the parts incl converter and fluid holders and so on. The more the better. I am this weekend going to pick up one of these, and wants to make sure, that EVERYTHING is there.
The transmission comes from a Karman Ghia 69 and will be fittet on a Bettle 1300 from 72.
I am fairly green when it comes to all these parts. I build my first car last year. Actually it was also the first time I changed oil on a car. It is a Beetle from 69. Right now I am planing my second build. A Beetle from 72 with automatic transmission and maybe a roaster kit. Something like that anyway.
Thanks for the help. |
Bookwus Samba Member
Joined: August 30, 2003 Posts: 1786 Location: City of Roses
Posted: Tue Sep 27, 2005 8:24 am Post subject: |
Hiya M,
We may be dealing with a semantics problem here..............
Saxomat is a term used to describe a mechanical semi-automatic transmission VW marketed (almost exclusively in Europe) in the early sixties. It is a precursor to the Automatic Stick Shift (AutoStick) transmission which made its debut in 1968.
The problem occurs because of how this term is used on the different sides of the Atlantic. Over in Europe, any VW semi-automatic transmission (be it AutoStick or Saxomat) is often referred to as a Saxomat.
Assuming that you are in Europe, can you be a bit more specific for the guys on this side of the pond? I'm guessing that you are actually referring to an AutoStick, but one can never tell when dealing with a car that's almost 40 years old.
Mike
1970 AS Bug |
DrDarby Samba Member
Joined: May 12, 2004 Posts: 6544 Location: Northern Illinois
Posted: Tue Sep 27, 2005 11:45 am Post subject: |
A Saxomat is a regular 4 speed manual transaxle coupled to a electromagnetic clutch with a centrifical clutch used for idle. The Automatic stick shift (Autostick) is a 3 speed manual coupled to an electromatic clutch AND torque converter.
I thoght the Saxomat was discontinued in 1965 - 1966 ? _________________ Midwest Autosavers, Inc. Crystal Lake, IL |
Posted: Wed Sep 28, 2005 6:17 am Post subject: |
I think you are right about the different names for it.
I am from Denmark, Europe, so I guess the correct name for it would be called autostick. It is the semi-automatic gearbox. The one where you still need to change gear, but dont have a clutch. It does have a converter (or is suppose to have it anyway).
I am not sure if the one I will be getting is 3 or 4 speed. |
Posted: Wed Sep 28, 2005 11:37 am Post subject: |
Hiya M,
We are talking about the AutoStick.
Do know that the AutoStick does have both a torque converter AND a clutch. The vacuum/electrical operated shift system does away with the need for a clutch pedal.
All AutoSticks were three speed transmissions. Later (starting in 1973, I think) AutoSticks had a nuetral slot. Earlier ones did not.
For a good outline of what all is in an AutoStick system you need to get a copy of Robert Bentley's Official VW Service Manual. You can get one hot off the press from Amazon.com for about $30 US. It will not only outline the differing parts of the system, but will also give you the most complete information on servicing and maintaining that system.
Additionally, I would suggest that you point your browser at www.vwar.org which is the Volkswagen Automatic Registry - a good online source for AutoStick information.
Mike
1970 AS Bug |
GüteAndTite Early Convertible Güru
Joined: June 16, 2005 Posts: 2144 Location: Low So Cal
Posted: Mon Jul 25, 2011 1:54 pm Post subject: |
| DrDarby wrote: |
I thoght the Saxomat was discontinued in 1965 - 1966 ? |
um no
theres a centrifugal roller weight starting clutch
and theres a regular clutch for gear shifting with a small
160mm clutch disc _________________ Official 58-60 "Early Big Window" Convertible Thread & Registry
http://www.thesamba.com/vw/forum/viewtopic.php?t=426481
F&S Saxomat Automatic Clutch System Thread
http://www.thesamba.com/vw/forum/viewtopic.php?t=462533
61-67 Delanair Air conditioning Thread
http://www.thesamba.com/vw/forum/viewtopic.php?t=457944&highlight=air+conditioning
PUNCTUATION CHANGES THE WORLD: "I need to help my uncle, Jack, off a horse" is way better than, "I need to help my uncle jack off a horse" |
