full flow vs adapter
mitcharvey
mitcharvey is offline
PostPosted: Sun Oct 09, 2005 1:12 pm    Post subject: full flow vs adapter Reply with quote
does it really make a difference if you use an adapter with an oil filter and cooler instead of full flow with oil filter and cooler? it's the same thing but in a different place, right? do people full flow so they can keep a stock oil cooler?
View user's profile Send private message Yahoo Messenger MSN Messenger Classifieds Feedback
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Sun Oct 09, 2005 1:16 pm    Post subject: Reply with quote
The filter cover keep the filter next to the muffler where it stays HOT.
The in/out pumps have restricted passages.
The best way is to use a true FF cover and tap the case for the return.
It's a really bad idea to remove the stock cooler.
After re-reading you post are you asking about removing the stock cooler and using an adapter to run a remote filter and cooler? If you that was a bad idea 30 years ago and is still a bad idea.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
mitcharvey
PostPosted: Sun Oct 09, 2005 1:44 pm    Post subject: Reply with quote
Are you asking about removing the stock cooler and using an adapter to run a remote filter and cooler?
yeah thats what i meant..
i'm sorry, i don't understand what you mean..
Mr. 010
Glenn is offline
PostPosted: Sun Oct 09, 2005 1:49 pm    Post subject: Reply with quote
That's a really bad idea.
If you get a oil pump that has an intergrated oil filter the filter is right next to the muffler.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
