Install distributor drive shaft
mitcharvey
mitcharvey is offline
PostPosted: Thu Oct 27, 2005 6:22 pm    Post subject: Install distributor drive shaft Reply with quote
will someone be sure i'm doing this right...
*put shaft in with groove perpendicular to case split
*off-set towards pully
*lowered crank in at TDC
*merged gears in the same positions
this is as close as I could get it. looking at the groove, it seems a little off. To get the groove to be straight up and down (perpendicular to split) the degree pully is at 30*..
Honestly it looks off to me and it is as close as I can get it.
View user's profile Send private message Yahoo Messenger MSN Messenger Classifieds Feedback
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Thu Oct 27, 2005 6:25 pm    Post subject: Reply with quote
Looks good to me.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
mharney
mharney is offline
PostPosted: Thu Oct 27, 2005 6:28 pm    Post subject: Reply with quote
You just put it where it makes things fit best. If that does not let you orient your wires and vacuum can (if you have a vacuum equipped distributor) the way you want to, then you just reposition it so that you can.
mitcharvey
PostPosted: Thu Oct 27, 2005 6:30 pm    Post subject: Reply with quote
does it matter how the shaft gear and the crank distributor gear mate?
mharney
mharney is offline
PostPosted: Thu Oct 27, 2005 6:34 pm    Post subject: Reply with quote
If you mean orientation, not really. They must mesh correctly, in other words, the drive gear must sit all the way down in the bore, so that it sits right on top of the two washers that are under it - other than that orientation means nothing here.
Mr. 010
Glenn is offline
PostPosted: Thu Oct 27, 2005 6:35 pm    Post subject: Reply with quote
I usually drop the drive in and then bolt the dristirbutor in. Then i set the crank up to TDC on #1 and finally the cam. If you don't like the way the distributor is in... you can easily change it.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
mitcharvey
PostPosted: Thu Oct 27, 2005 6:37 pm    Post subject: Reply with quote
gotcha!! thanks!
Mr. 010
Glenn is offline
PostPosted: Thu Oct 27, 2005 6:44 pm    Post subject: Reply with quote
I forgot to mention that I have a degree wheel that I machined the opening a bit larger so it's easy on/off. That ensures I have the crank at TDC.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
