End-play shims
mitcharvey
mitcharvey is offline
PostPosted: Thu Nov 03, 2005 12:14 am    Post subject: End-play shims Reply with quote
I HAVE searched and read all the old posts so don't nail me for that, BUT NO ONE SEEMS TO AGREE!
with .010" and .013" shims my endplay is .004" but thats only with two shims.
To get the right amount of endplay, with three shims, i would need two .008" shims and a .007" shim, but the pack of shims sold for setting end-play are no less than .095", which i'm guessing is because they would not be strong enough.
Adaze1 wrote:
Did everyone forget about the steel and paper shim that comes in the gasket kit? I had to use the paper shim to get the correct endplay I was after.
I have an 8 dowel crank so I would have to cut the paper gasket or drill the metal gasket and both ways would be sloppy at best. But if it worked it would put me in the ball park.
but...
danimal wrote:
you should never use those shims with an o-ringed flywheel.
turboblue wrote:
The proper way to resolve this problem is to have the shim surface of the flywheel machined slightly to allow three shims.
I really don't want to do that, but if I must then i have no choice but to dish out the cash.
or i could stay with two
[email protected] wrote:
No problem with two. I have to do that sometimes with brand new flywheels and brand new cranks.
but there are those that disagree..
mharney wrote:
Three is to keep the net friction on each shim surface down. If they're working right, they share the rotation fractions. Two have to rotate more per revolution and theoretically will wear out sooner
bugnut68 wrote:
I had an engine once that was built by a local shop using only two shims for the end play and it ended up spinning the thrust bearing.
stay with two shims or have it machined?
and why don't they make thinner shims?
who else has had a problem from using 2 shims?
View user's profile Send private message Yahoo Messenger MSN Messenger Classifieds Feedback
Muffler Mike
Muffler Mike is offline
PostPosted: Thu Nov 03, 2005 8:03 am    Post subject: Reply with quote
its all about friction and speed of the shims passing each other.
An example of no shims. Flanged crank that we use for racing. No shims, BUT we need to have .010" of end play to keep the expanding bearing from grabbing the crank because we have developed heat on it when whe stepped on the clutch pedal.
I think if you want to run 2 shims, you need to add in extra end play.
If you want to do it right and want a small end play, you need to get that flywheel surface cut down a little.
My old race/street motor was cut down quite a bit and i ran 4 shims. but i could also get away with .003" end play on a heavily abused configuration with out developing too much heat in the bearing.
thats how you can look at it.
why they are not thinner? imagine trying to put in aluminim foil for a shim... just to thin to suppport it self after a while.
Muffler Mike
http://MufflerMike.com
gears
gears is offline
PostPosted: Thu Nov 03, 2005 8:09 am    Post subject: Reply with quote
This illustrates the reason for figuring the shim selection on the work bench, before even installing the crank in the case. That way you can clearly see the #1 bearing/flywheel clearance from every possible angle.
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Thu Nov 03, 2005 9:01 am    Post subject: Reply with quote
Agreed...
I like doing it before so I can use a low tech feeler gauge.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
keifernet
Samba Search & Rescue
keifernet is offline
PostPosted: Thu Nov 03, 2005 12:33 pm    Post subject: Reply with quote
You don't state if your crank is counterweighted aftermarket or just a stock VW that is 8 dowelled.
I have found that the aftermarket cranks need some minor clearancing as the cheeks can rub against the main bearing webbing in the case just a bit and when you assemble ( even if you checked the end play on the bench with the crank, rear main and flywheel) the crank does not have the lateral movement and your calculations are off.
Another reason to always assemble just the crank and mains and rotate and check for signs of the crank rubbing inside the case.
turboblue
turboblue is offline
PostPosted: Thu Nov 03, 2005 2:11 pm    Post subject: Reply with quote
Along the lines that keifernet pointed about about crankshafts, Scat cast cranks are notorious for the large radius at the thrust bearing.
I've had to machine the thrust bearing at the inside radius to clear that huge radius.
If the bearing hits the radius before all the endplay is pulled out your readings will be off too.
Gary
Turbo VW Sand Drag Buggy
"If you don't run into the Devil every once in awhile, you must be going in the same direction!"
mitcharvey
PostPosted: Thu Nov 03, 2005 3:30 pm    Post subject: Reply with quote
12.5 lbs lightened from brazil.
they sell 8 dowel flywheel gaskets for setting endplay. why shouldn't these shims be used with an o-ring flywheel?
turboblue
PostPosted: Thu Nov 03, 2005 3:34 pm    Post subject: Reply with quote
I'd bet that's a cast steel flywheel.
Notorious for being out of spec.
Got a good way to measure it?
Check it from the surface the crankshaft bottoms out on to the surface the shims ride on.
Gary
mitcharvey
PostPosted: Thu Nov 03, 2005 3:55 pm    Post subject: Reply with quote
.325 all the way around
mitcharvey
PostPosted: Thu Nov 03, 2005 6:46 pm    Post subject: Reply with quote
anyone know why the flywheel gaskets shouldn't be used?
turboblue
PostPosted: Fri Nov 04, 2005 7:59 am    Post subject: Reply with quote
Well I just measured 3 and got .322, .323 and .325.
The first two were OEM German and the last one was a chromoly aftermarket. Confused
You never did say what your crank type was.
Gary
mitcharvey
PostPosted: Fri Nov 04, 2005 12:15 pm    Post subject: Reply with quote
hey thanks a lot turboblue for going out of your way to help me out on this.
product discription.
74mm cast stroker crankshaft with VW rod journals.
Manufacturer: QUALITY CHIRCO PRODUCTS
http://www.chirco.com/cgi-bin/chirco.storefront/43.../CPR105168
turboblue
PostPosted: Fri Nov 04, 2005 12:19 pm    Post subject: Reply with quote
Not a problem mitch.
Are you checking the endplay without the piston/cylinders installed?
Can you take your engine back apart?
Got something I want you to check.
Gary
mitcharvey
PostPosted: Fri Nov 04, 2005 12:23 pm    Post subject: Reply with quote
Shocked
i've got everything assembled... its only waiting for pushrods and what ever will set the endplay correctly until it goes in. how important is it?
turboblue
PostPosted: Fri Nov 04, 2005 1:12 pm    Post subject: Reply with quote
I'm worried the thrust bearing is not seating against the crank properly.
I've got an engine torn down that I can send you a picture of where my concerns are.
Endplay should always be set without the pistons and cylinders installed.
Maybe that is causing the problem.
Gary
mitcharvey
PostPosted: Fri Nov 04, 2005 1:23 pm    Post subject: Reply with quote
I assembled top end after measuring endplay...
could you send that pic? i would really like to see it
Its a new crank and flywheel, do you really think it is the thrust bearing?
turboblue
PostPosted: Fri Nov 04, 2005 1:34 pm    Post subject: Reply with quote
You have a PM
Gary
