Empi's "Super-Cool" Tins
vintagemx0
vintagemx0 is offline
PostPosted: Fri Nov 25, 2005 3:17 pm    Post subject: Empi's "Super-Cool" Tins Reply with quote
Hello All,
I haven't exactly built a performance engine, but I did some mods and want to put it past some of you engine gurus to see if anyone can point-out any issues that could arise.
Here's the highlights:
-It's a '67 1500cc. I put on 1600cc Barrels/Pistons.
-I adapted some 36hp "shoe boxes" to make a stale-air heating system
-I added Empi "Cool-air" tins to the under sides of the barrels.
-It's a standard Non-Doghouse shroud
-Aside from the top-side cyinder tins and pulley shroud, no other tin peices are used
I converted to stale-air to replicate the system used on a Kubelwagen, which is what my repro project is. I acquired a thermostat with flaps for the shroud, but have not installed them.
So, my question is, is the Empi "Super-cool" tins an adequate modification to help ensure that I am cooling sufficiently?
Any advice or comments would be greatly appreciated.
Thanks in advance,
Ken
Where ever you go, there you are.
Miguel Arroyo
Miguel Arroyo is offline
PostPosted: Fri Nov 25, 2005 4:40 pm    Post subject: Reply with quote
That is a killer muffler! Where did you get it?
vintagemx0
PostPosted: Fri Nov 25, 2005 4:50 pm    Post subject: Reply with quote
I made them. A friend in the UK disected an original Kubel exhaust that was shot and made some detailed notes. It was pretty easy. Any advice or comments on the cooling tins?
bugnut68
bugnut68 is offline
PostPosted: Fri Nov 25, 2005 8:31 pm    Post subject: Reply with quote
The cool tins, as I'm to understand, were originally designed for Type 3 engines, not Type 1's...and the Type 3 has a "horizontal" (pancake) cooling system, whereas the Type 1 is vertically oriented. It's been a source of contention among builders, but I think the general verdict is that stock deflectors are best for Type 1's.
My only concern regarding the 36 horse heater boxes is I THINK--not positive, though--that the early exhausts were smaller diameter than 1-3/8" on the later cars. I thought I read somewhere that the exhaust diameter on the early cars was around 1-1/4", but I'm not sure of this. Can any vintage gurus back me up on this? My only thought, if this is the case, that those stale air boxes will be mighty restrictive for a later engine.
View user's profile Send private message AIM Address Yahoo Messenger MSN Messenger Gallery Classifieds Feedback
vintagemx0
PostPosted: Fri Nov 25, 2005 8:45 pm    Post subject: Reply with quote
Thanks Bugnut.
I've heard before about the type 3 origins. I was told that the type 3's had cooling issues and this tinware was the remedy. I heard Empi made aftermarkets because it was regarded to be a general improvement in the heating system tinware. ??? I can see where they would offer more resistance to flow, and therefore greater residence time of the cooling air. I wonder if the final verdict you mention was after much debate if there is not enough difference to be concerned?
I'm not using the J-Tubes from a 36hp. I made my own headers with 1-1/2" tubing and will route them through my own heat exchange boxes. I was worried about ample diameter too.
tuna
tuna is offline
PostPosted: Fri Nov 25, 2005 9:08 pm    Post subject: Reply with quote
I think that Jake Raby did some dyno testing and in-car testing with those tins and he found they didn't work as well as the stock ones with the upright cooling. You might not notice the difference with what is essentially a stock engine, but if you got an opportunity, I'd put the stock ones back in.
Tuna
The VDub Geek
Type 4: Secrets Revealed
1969 Bug - 2056cc Type 4 Cal-Look
bugnut68
bugnut68 is offline
PostPosted: Sat Nov 26, 2005 12:51 pm    Post subject: Reply with quote
vintagemx0 wrote:
Thanks Bugnut.
Another thing, too, is that Empi isn't the only one selling those tins...Bugpack also carries them as does Scat, I believe. Odds are they all come from the same (Chinese/Taiwanese) plant. Smile
BoredandStroked
BoredandStroked is offline
PostPosted: Sat Nov 26, 2005 11:22 pm    Post subject: Reply with quote
If you do not run the sled tins you MUST run type 3 lower tins. All the debate over these is silly. Obviously the stock tin works best together with all its original pieces AND A STOCK ENGINE. But when you can not run the sled tins, like with a high performance merged header, the stock type 1 cylinder diverters dont cut it. The improvement is then type 3 lower cylinder tins.
That little yellow box at the back of the car is the 330' timer
If the ocean were whiskey, and I was a Duck, I'd swim to the bottom and drink it all up. But the ocean ain't whiskey, and I ain't a Duck, so I'll just sit on the beach and watch Pelicans fuck...
bugnut68
bugnut68 is offline
PostPosted: Sun Nov 27, 2005 12:46 pm    Post subject: Reply with quote
How are they an "improvement?" Jake already said that they don't work as well as the stock Type 1 deflectors. And as far as merged headers, there are headers made that clear the stock tin as well as set ups that allow heater boxes and the use of stock tin, as well...though it doesn't come cheap.
Jake Raby
Jake Raby is offline
PostPosted: Mon Nov 28, 2005 11:02 am    Post subject: Reply with quote
There are a TON of variables with this and the results that are found with various tins..
First of all the cylinder heads that are used will impact the results as well as the cooling system that is used. I found that with some cooling systems using the TIII tins (A.K.A.Super cool tins) increased the INEFFICIENCY os some of the better cooling systems.. Then some of the cooling systems that sucked the worst did a tad better with the TIII tins or saw no impact from them.
I measured head/cylinder temps from 3 different head/cylinder locations on all 4 cylinders simultaneously. The results pointed toward the fact that the stock TI tins worked much better as a general rule than the TIII tins. The TIII tins also increased HP draw from the fan by a couple % and lowered the point where the HP draw became apparent by as much as 750 RPM.
This is why I recommend TI tins, but as I said results may vary due to all the variations of TI cylinder heads, cooling systems and etc.
Jake Raby
Raby Engine Development
www.rabyenginedevelopment.com
"I've never given anyone Hell, I just told them the truth and they thought it was Hell"
