shorepig Samba Member
Joined: November 30, 2005 Posts: 516 Location: Vancouver, B.C.
Posted: Wed Feb 08, 2006 9:00 pm Post subject: leaking full after a fill up |
Whenever I fill up to the top of my tank (all the way until the pump shuts off), fuel immediately leaks out of a) the fuel filler hole, and spills down my paint, and b) leaks out somewhere underneath the van in the proximity of the filler neck. Is this common? Or is this deadly???? It continues to leak for about 5 minutes, I guess until it reaches a certain level... |
cloudbaseracer Samba Member
Joined: September 29, 2005 Posts: 154 Location: Dalton, GA
Posted: Wed Feb 08, 2006 9:52 pm Post subject: |
Can't answer if this is common or not but I have something similar happening. When I fill up I can only fill until the first time the pump shuts itself off. Any more than that and fuel will leak out of the filler tube. I do smell gas for several hours after I feel up as well, even if it has not spilled down the side. I have not noticed any fuel leaking out from underneath athough it may be. Does not seam to be. Maybe there is some type of "relief valve" on the vehicle.
James |
Silkworm Samba Member
Joined: October 12, 2005 Posts: 78 Location: Sarasota, FL
Posted: Wed Feb 08, 2006 10:10 pm Post subject: |
this seems to be a fiarly comon problem. Something to do with the various rubber seals in the filler neck/top of the tank i believe. use the search as i know this has ben discussed before.
http://www.busdepot.com/details.jsp?partnumber=TANKKIT1
I think this is the kit used to fix your problem.
that link is for 86 and above vanagons, not sure if it would be diferent for older
I seem to remember reading recently that at least one piece of the parts usualy replaced in cases like yours has ben discontinued, and i would asume can be hard to find.
Of course any of this could be wrong, as ive never had to deal with this issue.
Use the search _________________ 86 vanagon GL
When evil rises in it's full power, it surpasses truth and may wear the guise of good without fear
Mercy for the guilty is treason to the innocent
RichBenn Samba Member
Joined: November 16, 2005 Posts: 703 Location: Lake Tahoe, NV
Posted: Wed Feb 08, 2006 10:11 pm Post subject: |
I appear to have the same problem. Checking behind the filler, it appears the hoses are deteriorating. I saw someplace that had a complete kit with all the hoses.
As I just went through this on my son's 71 bug, you have to replace all the old fuel and vent hoses. Most everything was cracked.
So the answer is to replace all the tubing and gaskets to the tank (this includes right around the filler, as well). They just get old and crack over time.
-Rich |
Phil G Samba Member
Posted: Wed Feb 08, 2006 10:33 pm Post subject: |
| Also, the kits out there generally provide grommets for the vent crossover tube, sometimes the crossover tube itself - which there is a nationwide shortage of at the moment, the small 4mm bulk hose to cut for vent lines, their clamps and the fill tube grommet (large grommet where fill tube enters side of tank). These kits do not include the plastic fill tube ($150 at the dealer), the plastic 'burp' hose that runs parallel to the fill tube, or it's rubber sleeve that seals that tube to the fill manifold (flanged top part of fill tube that the gas cap screws onto). So it is best to look closely and see if one of these has a problem before investing in a kit that replaces parts that are not the problem. Sometimes the problem you are describing happens as a result of a pinched 'burp' hose or damaged metal 'flapper' in the fill orifice that was originally there to keep people from fitting the larger diameter leaded gas triggers into their non-leaded car's fill neck. Not a problem anymore, but back in the day those things caused a lot of spills. Most folks have pried the trap door out and chucked it long ago, but yours may still be there. Just some thoughts . . |
mightyart Samba Member
Joined: March 24, 2004 Posts: 6188 Location: Portland, Oregon
pocvw Samba Member
Posted: Thu Feb 09, 2006 10:35 am Post subject: |
Not to hijack your forum, but I have a question for everyone: I have heard that it isn't good to fill the tank up more after the pump has automatically clicked off. Any truth to this? _________________ Life is a garden - dig it!
1980 VW Westfalia |
panic Samba Member
Joined: July 18, 2005 Posts: 59 Location: Portland, OR
Posted: Thu Feb 09, 2006 11:44 am Post subject: |
| I can't rely on the automatic shut off of the pump. It causes a spill every time. This seems to be a common problem because here in Oregon, where there is no self service, many attendants are already aware of this problem. |
seans67 Samba Member
Joined: October 06, 2004 Posts: 453 Location: End of the Road, Alaska
Posted: Thu Feb 09, 2006 1:13 pm Post subject: |
| pocvw wrote: |
| Not to hijack your forum, but I have a question for everyone: I have heard that it isn't good to fill the tank up more after the pump has automatically clicked off. Any truth to this? |
I think this is done more to prevent fuel spills than anything.
I hate those hoses around the nosel that some states have to catch the fumes, PITA. _________________ Sean
'71 Squareback '71 Porsche 914 ‘80 Camper '87 Syncro Weekender 1.8T '87 Wolfsburg Weekender '97 Toyota Land Cruiser ‘03 Audi A6 Quattro 3.0 ‘04 Audi A4 Avant Quattro 1.8T ‘05 Audi A4 Quattro 3.0
‘06 Porsche Cayenne Turbo S |
vandukw Samba Member
Posted: Fri Feb 10, 2006 6:37 pm Post subject: |
| Just had the tank down in my 84, I got the reseal kit without the cross-over tube (thats the part on national backorder) was not a problem re-using old crossover tube, its rigid plastic and doesnt deteriorate like the soft rubber grommets and vent hoses. The kit without the tube is around $50 less too. Before you drop tank reach behind front wheels inbetween floor pan and subframe, you can feel the croossover tube where it plugs into tee that fits into tank grommet , mine had just popped off, I really didnt need all the new seals and could have just reached one hand in their to push tube back into tee- maybe thats all you need- good luck |
captainpartytime Samba Member
Joined: December 04, 2005 Posts: 721 Location: Mission Viejo, CA
Posted: Fri Feb 10, 2006 6:54 pm Post subject: |
| This is a common problem with vanagons. It has become even more of a problem ever since MTBE has been used as a fuel additive. Apparently it eats away at the seals in the filler neck/tank. I have used the go westy gas tank re-seal kit on all three of my vanagons and none of them have leaked since. I also try and use gas with an ethanol additive instead of MTBE because it is not as corrosive to gaskets ( I think shell and 76 use ethanol instead of MTBE). |
