dual carbs or single?
jacobroger
jacobroger is offline
PostPosted: Sat Feb 18, 2006 2:28 pm    Post subject: dual carbs or single? Reply with quote
I have a 73 westy with a new 2 litre I have a set of 40mm kadrons and also a nice weber single. I am thinking about putting the single on the bus and putting the duals on my 69 beetle. Any suggestions?
Thanks
jacob
glutamodo Premium Member
The Android
glutamodo is offline
PostPosted: Sat Feb 18, 2006 3:10 pm    Post subject: Reply with quote
In my experinece, I've found that on Buses, duals always are better then single carbs. The long unheated manifolds that single carbs have on there often require that you over-jet the carb to make it run decently, which results in poor fuel economy - especially on the type 4 Bus motors. If you have the proper linkage for type 4, I'd put the duals on there.
-Andy
Schmoburger
Location: Under a Kombi in Tomerong, NSW, Australia... MATE!!!
Schmoburger is offline
PostPosted: Sat Feb 18, 2006 3:16 pm    Post subject: Reply with quote
Yep.. if it aint broke dont fixe it. Smile
A lot of peope on AVD seem to complain about Webbers being a pain in the clacker...Sad
View user's profile Send private message MSN Messenger Classifieds Feedback
barefootwestie
barefootwestie is offline
PostPosted: Sat Feb 18, 2006 6:19 pm    Post subject: Reply with quote
I have a single Weber on my '73 from the PO and I am going back to the dual Solex's. BTW, where in York do you live? I graduated in Rock Hill and worked in York for quite a few years.
My Bus Restoration Blog
https://myvolkswagenbus.com/
1973 Westfalia
"Getting better....one repair at a time."
Other VW's owned through the years, in no particular order:
'67 Beetle,
'67 Ghia Hardtop,
'72 Ghia Convertible,
'72 Westfalia
myk648
myk648 is offline
PostPosted: Sat Feb 18, 2006 8:12 pm    Post subject: Reply with quote
I too am swithching back to duals. The bus I just bought has a weber progressive on it. I'm going to a set of solex's.
TimGud
TimGud is offline
PostPosted: Sat Feb 18, 2006 8:25 pm    Post subject: Reply with quote
I've worked on a couple of buses with a weber single carb on them. Stick with the duals!
honeybus
honeybus is offline
PostPosted: Mon Feb 20, 2006 6:58 am    Post subject: Reply with quote
What is "AVD"
barry
More than I need -
'78 Westy ... purchased 11 Dec 06 ($9,000); sand blasted/primered 7 Jan 07 ($1,200); body shop 3 Apr 07 ($2,000); paint shop 7 Nov 07 ($6,000); home 22 Apr 08; started TLC 28 Aug 08; got very first sign of life 8 Jun 2010; Run about 1,000 miles in Florida in May 2011; 1,600 miles road trip Orlando-Key West-Aldie Virginia 10-26 Mar 2020 (COVID-19 started)
Thanks for all the fish.
The Android
PostPosted: Mon Feb 20, 2006 7:19 am    Post subject: Reply with quote
honeybus wrote:
What is "AVD"
http://www.aussieveedubbers.com/
clearsurf2001
Samba Vaccinator
clearsurf2001 is offline
PostPosted: Mon Feb 20, 2006 7:26 am    Post subject: Reply with quote
That about sums it up. Progressive or IDF ... centermount singles rank a distant second to almost any dual setup. Mileage, drivability, and power ... duals can't be beat (except with F.I.) ... so I guess singles rank a distant third ...
Get ready for the injection Smile
Make sure it is coherent. Rodney
mharney wrote:
I think Glenn has an EMPI crank in his engine.
MrBreeze
Samba Hitman
MrBreeze is offline
PostPosted: Mon Feb 20, 2006 7:29 am    Post subject: Reply with quote
Well, I guess I'll add to the common thinking....
My '73 had been converted to a single and I HATED it. I had bought duals to put on, but sold it before I got the chance.
Of course, we all know FI is the way to go anyways Twisted Evil
-=Rob
WTB: Bay Shore or Queensboro VW Frames
HBB 1984-2009
RW 1943-2011
ER 1964-2023
DurocShark
Location: Crappy town in a crappy state. But the beach is nearby, so I have that going for me.
DurocShark is offline
PostPosted: Mon Feb 20, 2006 8:15 am    Post subject: Reply with quote
jacobroger: I just emailed you
Keep the Kads! You'll be happier! I believe Bottomend is running the same carbs and is happy with them...
No boom today. Boom tomorrow. There's always a boom tomorrow.
pyrOman
Fire Master
pyrOman is offline
PostPosted: Mon Feb 20, 2006 9:33 am    Post subject: Reply with quote
The milage I get out of the 30pict "bicycle" carb on the Gutless Wonder is incredible! Shocked
But nothing beats the quick response of dual carbs, specially on a bus! Razz
Had a progressive Webber on the "million mile motor" while it was in the '70 bug. Did excellent, but that carb on the bus always left something to be desired. Confused
But how about this: go ahead and do the changes and experience for yourself the difference. Cool
Zeen
Zeen is offline
PostPosted: Mon Feb 20, 2006 9:37 am    Post subject: Reply with quote
Do a search on "icing" before you put a single on the bus. The Type 4 is wider, which means longer runners, which means more prone to icing. You'd be better off putting the single on the beetle engine.
The consequences of your decisions should not be confused with fate.
HereToGo
HereToGo is offline
PostPosted: Mon Feb 20, 2006 11:23 am    Post subject: Reply with quote
I keep reading that a single carb is generally bad news for a Type IV, but has anyone devised a carb heat box for the progressive, similar to an aviation engine setup? Leave one end open for intake air, put a flapper valve on it and a cable to regulate the heat from the dashboard.
For the exhaust end, I guess a box could be made to go around the muffler or just let the hose collect the heat like a type I setup.
Everett
fido
fido is offline
PostPosted: Tue Feb 21, 2006 6:03 am    Post subject: Reply with quote
nice link for that here:
http://crank.org.uk/carb/
I went from weber single to twin dells. Never looked back - world of difference.
73 Westy
Automatic trans
1700 W case
36 DRLA's
vanagon distributer / elecronic ignition
Thunderbird 4:1 / QP
lots of guages Smile
Duncwarw
Duncwarw is offline
PostPosted: Tue Feb 21, 2006 8:01 am    Post subject: Reply with quote
Fido, thanks for the link.
As for "Icing", I haven't personally found it to be much of a problem and it has been pretty cold here. At its very worst (about 18°), idle was tricky and it felt like it had a 009 on it. On the road though, not bad.
I have a progressive on a 2L with NO pre-heater and I didn't even fit the bar from the case.
I suspect, like anything else, people who have had real trouble with a progressive, have had other problems too.
No doubt the duals would be better, but the Progressive has a reputation it doesn't deserve. IMHO...
“To find yourself, think for yourself”
Socrates, 470 BC - 399 BC
This topic is locked: you cannot edit posts or make replies.    Forum Index -> Bay Window Bus All times are Mountain Standard Time/Pacific Daylight Savings Time
