73 Bus Dual Carb to Single (2 Barrel)
JGKoenig
JGKoenig is offline
PostPosted: Sun Feb 26, 2006 3:52 pm    Post subject: 73 Bus Dual Carb to Single (2 Barrel) Reply with quote
Hey I jsut baught a 73 Westflia with the stock dual Solex setup. I have had 2 buses with this setup in the past and it is always a hassle.
I am thinking about changing to a single Weber Progressive. I installed one on by 74 Bug and it runs great.
Is it an easy conversion in this case? I think I can get to everything without removing the engine.
Is there a better single carb solution for this application (everyday driver)?
steponmebbbboom
steponmebbbboom is offline
PostPosted: Sun Feb 26, 2006 3:56 pm    Post subject: Reply with quote
No. The Weber Progressive cannot be preheated, so you will have driveability issues.
The dual carbs only present problems if they are not assembled, set up and adjusted properly. Just learn the particulars, get a synchronising tool, trust me it is better to go this route than the one you are contemplating. A beetle engine and a type IV engine are quite different in this case.
Tram
Samba Socialist
Tram is offline
PostPosted: Sun Feb 26, 2006 4:48 pm    Post subject: Reply with quote
I agree with Boomer. Weber Progressives on Types 3 and 2/4 should be stamped out. It's a terrible option. The duals that were factory are far superior.
Bryan67 wrote:
Those who can- do.
Those who can't? Subaru.
Randy in Maine
Randy in Maine is offline
PostPosted: Sun Feb 26, 2006 5:16 pm    Post subject: Reply with quote
Yes you want to stay with the dual carbs. As stated above, the centermounted ones ice up and there really is no way around it. I would make sure that I really understood what there is to know about adjusting the dual carbs. When they work really well, it is very nice.
Been here?
http://www.thesamba.com/vw/forum/album_page.php?pic_id=67539
http://www.ratwell.com/technical/VacuumHosesCarb.html
http://www.thesamba.com/vw/forum/album_page.php?pic_id=65393
http://www.ratwell.com/technical/DualCarbs.html
http://www.thesamba.com/vw/forum/album_page.php?pic_id=66108
Quite helpful.
tristessa
tristessa is offline
PostPosted: Sun Feb 26, 2006 7:21 pm    Post subject: Reply with quote
Ditto most of the above.
That said, if you're missing several pieces or really have your mind made up to pull the stock dual Solexes, put a pair of 34ICTs or Kadrons on instead of the progressive. They don't cost *that* much more than the progressive kit and work a lot better.
Bus progressive kit: $400 (busdepot)
Bus Kadron kit: $480 (cip1, couldn't find it listed at busdepot)
Bus 34ICT kit: $430 (busdepot)
Gary Massin-Ball
Gary Massin-Ball is offline
PostPosted: Mon Feb 27, 2006 1:30 pm    Post subject: Reply with quote
These cb 34mm are great as well and have chokes and are only $369.95.
www2.cip1.com/ProductDetails.asp?ProductCode=C18%2D3286
widowmaker70
widowmaker70 is offline
PostPosted: Wed Mar 01, 2006 9:24 am    Post subject: Reply with quote
What is a good dual carb setup for a 70 bus with a stock 1600 upright in it? Will it help or hinder things? I also was thinking about not doing it because I would not be able to run the stock oil bath any longer right?
Thanks,
~Josh
~Widowmaker
70 Baywindow Campmobile 'Driver' (Whoosh)
70 Beetle (Under Construction)
Looking for Entire door handle for sliding door
View user's profile Send private message AIM Address Yahoo Messenger MSN Messenger Gallery Classifieds Feedback
Amskeptic
Amskeptic is offline
PostPosted: Wed Mar 01, 2006 9:30 am    Post subject: Reply with quote
Thanks,
~Josh
If you promise yourself to slow down and enjoy the gentle meanderings of a stock VW bus, the oem oil bath air cleaner will help your engine last longer.
Colin
www.itinerant-air-cooled.com
www.facebook.com/groups/324780910972038/
JGKoenig
JGKoenig is offline
PostPosted: Sat Mar 04, 2006 9:12 pm    Post subject: Reply with quote
Any suggestions on a good carb sync tool? Stock Solex duals.
Randy in Maine
PostPosted: Sun Mar 05, 2006 7:04 am    Post subject: Reply with quote
Buy the adapter for the Solex /Kads http://www.aircooled.net/new-bin/viewproductdetail.php?keyword2=TZE0021&cartid=0226200665506699
Here is that clutch adjusting gizmo while you are there http://www.aircooled.net/new-bin/viewproductdetail.php?keyword2=TZE0023&cartid=0226200665506699
