Bus reduction boxes
miketrains03
miketrains03 is offline
PostPosted: Tue Jun 20, 2006 6:58 pm    Post subject: Bus reduction boxes Reply with quote
How does this give lift to a bug?
What parts are needed?
What are the steps involved?
I searched and theres really no good post about this explaining it well.
BTW, my book is in the mail
subybaja
subybaja is offline
PostPosted: Tue Jun 20, 2006 7:22 pm    Post subject: Reply with quote
Try searching on "RGB" for Reduction Gear Box.
Also search for "Bugzylla". He sells adapters.
It gives you lift just like a Hummer axle, by using gears to drop down from the normal axle location.
Check this thread for some pics:
http://www.thesamba.com/vw/forum/viewtopic.php?t=171966&highlight=rgb
Insanity: /ɪnˈsænɪti/ -noun: repeatedly voting for the same party and expecting different results.
Vote Libertarian
BugZyla.com
BugZyla.com is offline
PostPosted: Tue Jun 20, 2006 7:25 pm    Post subject: Reply with quote
http://www.thesamba.com/vw/forum/viewtopic.php?t=134181&highlight=reduction
Go to http://www.bugzyla.com and click on the pics link for more.
Daryll http://www.azbaja.com P.R.
"Why is there Braille on a Drive Thru ATM?"
subybaja
subybaja is offline
PostPosted: Tue Jun 20, 2006 11:15 pm    Post subject: Reply with quote
Whups. Embarassed Sorry.
Vote Libertarian
UKbillybob
UKbillybob is offline
PostPosted: Wed Jun 21, 2006 1:31 pm    Post subject: Reply with quote
This has the bugzyla adapters and 35" rears. Also got thing spindles on the front.
panzerfuska
panzerfuska is offline
PostPosted: Wed Jun 21, 2006 3:14 pm    Post subject: Reply with quote
awesome looking beast. how about a picture from the front?
subybaja
subybaja is offline
PostPosted: Wed Jun 21, 2006 10:42 pm    Post subject: Reply with quote
Damn! That's ninja!
Looks like time for some of those high-rise fenders!
I test-drove a RGB baja once, with maybe 30"s on the back. It topped out about 45, but it got there quickly! I guess you don't have that problem...
Vote Libertarian
Hebster52
Hebster52 is offline
PostPosted: Thu Jun 22, 2006 3:13 am    Post subject: Reply with quote
This is how it would look like using later bus reduction boxes on a bug.
~Kris~
"The Hebster52" my Hebmuller replica build
The 912ST
The KidVRod project
The 356 Pre-A replica,SOLD
The 1966 Kommanderwagen, SOLD
UKbillybob
PostPosted: Thu Jun 22, 2006 3:14 pm    Post subject: Reply with quote
Cheers guys. The big tires run fine because of the reduction boxes.
Pic from front as requested.
miketrains03
PostPosted: Thu Jun 22, 2006 4:57 pm    Post subject: Reply with quote
so all i would need are adapters and the boxes themselves??
what kind of gear reduction are we talking? im going to probably put 31"s on the back, so that should offset the boxes. i do need to be able to drive highway speed.
Billet_Bus
Billet_Bus is offline
PostPosted: Fri Jun 23, 2006 7:41 pm    Post subject: Reply with quote
Remember reducs also reverse everything so you need your ring and pinion switched or do a bus box with bug nosecone.
I have big nut reducs and 30x9.5 tires so my gearing is back to pre-reducs
I have some bugzilla adapters and i like the ones Hebster52 has in his picture much much better.
www.Full-Race.com
Anything else is just half fast.
CTD Fabrication
David58bug
David58bug is offline
PostPosted: Sat Jun 24, 2006 6:59 am    Post subject: Reply with quote
Hebster52. Do you have a source for those adapters? I have the Bugzilla ones and wish I didn't.
miketrains03
PostPosted: Sat Jun 24, 2006 2:47 pm    Post subject: Reply with quote
thanks for all your help guys.
i think after seeing what's involved, im going to do a body lift on the bug i have now w/ a nice baja kit and some goodies as my daily driver and go for a 69'+ model to go nuts w/ the suspension down the road.
turkish
turkish is offline
PostPosted: Sun Jun 25, 2006 11:36 pm    Post subject: Reply with quote
Just curious, is thereanyway to have 1:1 gears made for the redux boxes? I know that they are specifically made to reduce the gear ratio, but I just want the 3" of lift and I don't want to go with IRS. Also, how well do they stand up to power? I've got a 300hp TIV motor coming soon which is also the reason I don't want IRS.
HamburgerBrad
Je suis Napoléon!
HamburgerBrad is offline
PostPosted: Mon Jun 26, 2006 1:02 am    Post subject: Reply with quote
none of the reduction boxes were ever built to have a ratio of 1:1. they were meant for more ground clearance and the extra torque in hauling around the extra steel in the busses as well as up to 1 ton of a load. as far as power they're able to withstand, i personally can't help you there. a friend of mine is building a high power type 1 for a bus with reduction boxes but also with a well built trans.
OGST | CU05 | OGJHC
1970 baja|1953 oval
Wanted: two beat up, ugly, curb rashed 6" phone dial wheels
Tim10
Tim10 is offline
PostPosted: Mon Jun 26, 2006 5:19 pm    Post subject: Reply with quote
Turkish...
Without going into repetitive details... your combo of power and tranny will not work.
Sounds like you're a rancho IRS candidate.
T.
Dub Infested- PART WI$H LI$T-CLICK
turkish
turkish is offline
PostPosted: Fri Jun 30, 2006 11:52 am    Post subject: Reply with quote
What I'm worried about is how well the CV's and whatnot will hold up to hard launches as I plan to use the car for some strip use. When I got off-road I don't really romp it hard, I'm more of a trailrider than a romper so I don't need all the suspension travel that IRS gives but I do want the strength of swingaxle. I'm also doing this kind of on a budget. The T4 I'm getting is a zero mile block with quite a few worked over parts($1600 into heads alone by Competition Engineering and a cam to match) for $600 off a friend of mine. Exhaust for the turbo will be made by another friend and the turbo to go on that will be supplied by yet again another friend who owns a turbo shop out in Tempe, Arizona. I was just hoping I could use the redux boxes to getmyself some more ground clearance due to the design of the TIV exhaust.
