Removing the alternator while engine is still in car
Page: 1, 2, 3, 4, 5  Next
Boonies
Boonies is offline
PostPosted: Sun Aug 13, 2006 9:24 am    Post subject: Removing the alternator while engine is still in car Reply with quote
So today I will replace the dying alternator and I dont want to remove the engine. Got a good idea on how to remove it while the engine is still in. Just looking for any good tips or suggestions that anyone has.
thanks
Countyblues
Countyblues is offline
PostPosted: Sun Aug 13, 2006 9:28 am    Post subject: Reply with quote
its not to hard to do it, just remove the deck lid losten the strap and the two side screws and you should be good to go
Boonies
Boonies is offline
PostPosted: Sun Aug 13, 2006 9:36 am    Post subject: Reply with quote
Two side screw you are speaking of are on the fan shroud correct.
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Sun Aug 13, 2006 9:37 am    Post subject: Reply with quote
It's a real B!TCH to get the fan shroud off with the engine in.
But you can remove the alternator and leave the shroud in... here's how.
Remove the wires, fan belt and half of the pulley. Reach around the front of the engine and put a 36mm socket with a 3" extension and a breaker bar on the fan nut. Use a large adjustable wrench in the remaining half of the pulley and crank the nut loose. Now remove the alternator strap and the 4 bolts holind thebacking plate to the fan shroud. Tilt the alternator so you can gain access to the 2 10mm nuts and remove them. now pull the alternator out.
To reinstall, just doeverything in reverse. Make sure the fan nut is tight or it might come loose.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
John M.
John M. is offline
PostPosted: Sun Aug 13, 2006 9:39 am    Post subject: Reply with quote
Yep. Worked like a charm for me.
Countyblues
PostPosted: Sun Aug 13, 2006 9:40 am    Post subject: Reply with quote
that is very true it can be done that way also and yes I was talking about the two screws on the shroud.
Boonies
Boonies is offline
PostPosted: Sun Aug 13, 2006 11:20 am    Post subject: Reply with quote
Thanks for the tips guys.
Mr. 010
Glenn is offline
PostPosted: Sun Aug 13, 2006 11:23 am    Post subject: Reply with quote
Don't forget the in the front on the "Hoover Bit". And you have to disconnect the thermostat.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Boonies
Boonies is offline
PostPosted: Sun Aug 13, 2006 11:24 am    Post subject: Reply with quote
And this "Hoover Bit" is???
Mr. 010
Glenn is offline
PostPosted: Sun Aug 13, 2006 11:26 am    Post subject: Reply with quote
It's that small piece of tin that missing on 95% of the engines. It closes off the gap between the oil cooler and the fan shroud.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Boonies
Boonies is offline
PostPosted: Sun Aug 13, 2006 12:28 pm    Post subject: Reply with quote
What should you torque the 36mm nut to?
volkenstein
volkenstein is offline
PostPosted: Fri Aug 25, 2006 3:40 am    Post subject: Torque value Reply with quote
40-47 ft/lbs.
71 RHD AS Super - "Klaus"...
Wisdom of youth, energy of old age...
View user's profile Send private message Send e-mail Yahoo Messenger Classifieds Feedback
sepulvedac
sepulvedac is offline
PostPosted: Tue Sep 05, 2006 12:07 pm    Post subject: Reply with quote
Glen, I tried your method but the nut in the back did not budge. Colud not get it loose to save my life. I did exactly what you said and nothing! I used a 12'' adjustable wrench at the front and the 36mm with the breaker bar in the rear. could not use the 3" extension because the firewall would not le me use it.
Any other suggestion besides taking the whole thing out? Then again, that posses another problem, what can I use to hold the a;lternator so it would not move while loosing it. I do not have a vise-grip.
Carlos
View user's profile Send private message Yahoo Messenger MSN Messenger Gallery Classifieds Feedback
John M.
John M. is offline
PostPosted: Tue Sep 05, 2006 12:23 pm    Post subject: Reply with quote
Carlos
There is a slot on the upper pulley to stick a large flat bladed screwdriver in. That will keep it from moving while loosening the fan nut.
Current: 1972 Beetle - 96V EV
Previous:
1966 Beetle - Sea Blue - 1300SP
1966 Beetle - Sea Blue - 1600SP
1974 Beetle - African Red - 1914CC
sepulvedac
PostPosted: Tue Sep 05, 2006 12:59 pm    Post subject: Reply with quote
Did that. The nut do not want to get loose. And I am a heavy guy, 240lbs of pressure should have done the job, but nothing.
John M.
John M. is offline
PostPosted: Tue Sep 05, 2006 1:30 pm    Post subject: Reply with quote
The only other way to get it off would be to pull the engine.
That nut should only be torqued to 44ft lbs. Somone in the past must have used an Impact Wrench to tighten it down.
Previous:
sepulvedac
PostPosted: Tue Sep 05, 2006 2:02 pm    Post subject: Reply with quote
I was thinking about that. It is too tough to get loose. I should turn counterclockwise to get it loose, right? Shocked
Boonies
Boonies is offline
PostPosted: Tue Sep 05, 2006 2:10 pm    Post subject: Reply with quote
Just loosen the fan shroud and you can wiggle it up to a position where you can get the alternator out with the fan on it. If someone has used a numatic wrench to put it on then getting it off could be a real PITA.
The Old Speed Shack
sepulvedac
PostPosted: Tue Sep 05, 2006 2:22 pm    Post subject: Reply with quote
Still, if I take the fan shroud, I am going to need something else to hold the whole thing and balance it. Hard to do it by myself. And the mechanic I know wants to charge me $120. Her says it take 2 hrs and it is too difficult to R&R. Oh, well. I will keep charging my battery until I find a better way to do it.
Boonies
Boonies is offline
PostPosted: Tue Sep 05, 2006 2:45 pm    Post subject: Reply with quote
I did it by my self with some small blocks to hold up the shourd while i took out the alternator. Really not that hard at all. Just have every thing ready to come out when you loosen the shroud... and take off your carb.
The Old Speed Shack
Page 1 of 5
