doubledripper Samba Member
Posted: Fri Aug 25, 2006 3:20 pm Post subject: Shifter differences |
does anyone have any pictures of stock shifter components?or does anyone know how many pieces are involved?
Moderator summary of later posts in this thread:
| Clara wrote: |
mid 60 through early 66 is different than 66-67 and will not work in the other years. Some people think the only change is at VIN 501 xxx, but there is another change in early 66 model year.
from the gallery:
http://www.thesamba.com/vw/forum/album_search.php?...t_dir=DESC
| hazetguy wrote: |
Many times people install random shifters and don't think about the consequences. A not uncommon complaint is that once the new shifter is installed, the shifting is extremely stiff or totally impossible. Or conversely, that the shifter ball does not even engage the front shift rod.
Chances are that a 66-67 shifter has been installed in an earlier bus, or an earlier shifter has been installed in a later bus.
On the left is a 60-65 shifter.
On the right is a 66-67 shifter.
Notice the different length of the lower part of the shifter. Installing the later shifter in an earlier bus will cause the stiffness or no movement.
Installing an earlier shifter in a 66-67 bus may cause the shifter to not even engage the shift rod.
The proper shifter must be installed in the correct application. |
| easy e wrote: |
Berg site sez:
Pre-60: 15.7mm ball and approx 22" tall.
60-mid 1966: 21.50mm ball and approx 7/8" from bottom of base to bottom of ball. Total length approx 25" floor to top of handle.
mid 1966-79: Length approx 25" from floor to top of handle. |
BarryL  Samba Member
Joined: November 01, 2004 Posts: 15402 Location: Casa de Oro, California
Posted: Fri Aug 25, 2006 7:14 pm Post subject: |
| Find one of Clara's posts. She usually has a link to all the parts numbers and pictures ever made. |
suebug  Samba Member
Joined: April 13, 2006 Posts: 1152 Location: The OC, SoCal, with my olympic cats
Posted: Fri Jul 24, 2009 11:01 pm Post subject: |
Yes, I did a search and this old and short thread was the closest I could find.
I have a Gene Berg shifter that came on my late '60 single cab. I don't know if anything has been changed underneath. I want to put on a stock shifter for now. How many Gene Berg shifters are there so I don't go and buy the wrong stock one now?
Thanks for any help. _________________ '67 Beetle
'67 Squareback
'66 Sundial
'60 Single cab
'70 Bitchen 3-speed Schwinn |
Damon22 Samba Member
Joined: January 03, 2006 Posts: 238 Location: New Forest, Ingerland.
Posted: Sat Jul 25, 2009 3:50 am Post subject: |
I think the ball socket changed to a larger size in 1956/7 My 56 has small socket and is RHD, so Berg had to make up a shifter for me. socket size is the same from then forwards. The early shift rod has a metal bracket that holds it to the underside of the floor. Later is different I think. Search on shift rod on the WW site, pics and info there.
http://www.wolfsburgwest.com/ |
bill may Samba Member
Joined: August 27, 2003 Posts: 14160 Location: san diego,ca
Posted: Sat Jul 25, 2009 7:23 am Post subject: |
| suebug wrote: |
Thanks for any help. |
1960-1965. 66 and 67 have longer distance between ball and base. _________________ Admin note: Bill Passed away - July, 2017
1965 panel bus-Kermit
"Camping is cheaper than therapy"
www.sv2s.com
www.steeringboxscrapers.net
SBS #100
http://www.thesamba.com/vw/forum/viewtopic.php?t=453617 |
BarryL  Samba Member
Posted: Sun Jul 26, 2009 6:45 am Post subject: |
| bill may wrote: |
| 66 and 67 have longer distance between ball and base. |
So they have a shorter throw? A lot of the ads say "'60 to '67"; will they work in a '66-'67 but just sit slightly higher in the socket. |
Clara  Samba Member
Posted: Sun Jul 26, 2009 7:37 am Post subject: |
| BarryL wrote: |
| bill may wrote: |
no, mid 60 through early 66 is different than 66-67 and will not work in the other years. Some people think the only change is at VIN 501 xxx, but there is another change in early 66 model year.
I don't know about Berg shifters.
from the gallery:
| hazetguy wrote: |
Often if you do a gallery search you will find that hazetguy posted useful reference pictures and comments about the parts. Thanks Jon! _________________ The Obsolete Air-Cooled Documentation Project http://oacdp.org/ |
Posted: Sun Jul 26, 2009 7:48 am Post subject: |
| Clara wrote: |
from the gallery:
| hazetguy wrote: |
a Berg Shifter will have same distance as 60-65 on left and 66/67 on right. the 60-65 has same distance as beetle but have longer shaft-this why the hood rodes use a 60-65 bus shifter so the shift knob is up high. _________________ Admin note: Bill Passed away - July, 2017
www.sv2s.com
SBS #100
Clara  Samba Member
Posted: Sun Jul 26, 2009 7:51 am Post subject: |
| bill may wrote: |
a Berg Shifter will have same distance as 60-65 on left and 66/67 on right. |
How can a berg shifter have the same distance as the two shifters which are different?
Or do you mean they have two versions, one that fits 60-65 (and beetle), one for 66-67? _________________ The Obsolete Air-Cooled Documentation Project http://oacdp.org/ |
Posted: Sun Jul 26, 2009 8:11 am Post subject: |
| Clara wrote: |
| bill may wrote: |
Or do you mean they have two versions, one that fits 60-65 (and beetle), one for 66-67? |
2 versions. berg beetle shifter is not berg bus shifter. vw bus shifter is not vw beetle shifter.
sorry i confused you when i said hood ride,hood riddence use 60-65 bus shifter in beetle so the shift knob can be seen sticking way up in the air. _________________ Admin note: Bill Passed away - July, 2017
www.sv2s.com
SBS #100
EverettB  Administrator
Joined: April 11, 2000 Posts: 71789 Location: Phoenix 602
BarryL  Samba Member
Posted: Sun Jul 26, 2009 1:07 pm Post subject: |
| bill may wrote: |
| 2 versions. knob can be seen sticking way up in the air. |
So two bus versions?
Yeah, Clara and Hazetguy, that's a huge difference. |
Clara  Samba Member
Posted: Sun Jul 26, 2009 1:17 pm Post subject: |
| bill may wrote: |
| Clara wrote: |
| bill may wrote: |
sorry i confused you when i said hood ride,hood riddence use 60-65 bus shifter in beetle so the shift knob can be seen sticking way up in the air. |
so you are saying Berg has two versions, one for beetle and one for bus (also used Rat Fink style on beetle)
Which years bus does their bus version fit?
through mid 60?
mid 60 to early 66 is what it sounds like?
early 66 through 67?
so the Berg version does not fink mid 60 and back, or early 66 through 67, ya? _________________ The Obsolete Air-Cooled Documentation Project http://oacdp.org/ |
Posted: Sun Jul 26, 2009 4:36 pm Post subject: |
| Clara wrote: |
| bill may wrote: |
| Clara wrote: |
| bill may wrote: |
through mid 60?
so the Berg version does not fink mid 60 and back, or early 66 through 67, ya? |
GB 6748 60-65 bus fits chassis number 835 008 through 216 028 111
GB 6750 66-79 fits chassis number 216 028 112 to the vanagon
GB 6750R for right hand drive buses. shifter is bent opposite way and has right hand drive handle.
they used to make a version for early 60 and down,and may be obtainable by asking. _________________ Admin note: Bill Passed away - July, 2017
www.sv2s.com
SBS #100
johny__utah Samba Member
Joined: September 02, 2008 Posts: 439 Location: Arizona/California
Posted: Tue Aug 11, 2009 11:32 am Post subject: |
| Everett, do you know where i can find a metal shift rod bushing and spring for my 56 panel? Thanks
joe cool Samba Member
Joined: August 20, 2006 Posts: 1262 Location: Yolo County CA
Posted: Sat Aug 08, 2015 7:26 pm Post subject: |
You can make a later shifter work in an earlier bus by shimming
Necessity is the mother of invention |
BarryL  Samba Member
Posted: Sun Aug 09, 2015 7:37 am Post subject: |
| Good idea. You bring the shift/stop plate up with it, right? You aught to market a solid spacer block. |
Rustyscrew Samba Member
Posted: Sat Sep 26, 2015 11:24 pm Post subject: |
| Ok I see that there are different shifter levers. I have one of each but only one spring. So my question is the shifter spring interchangeable between the 2 shifters? |
BarryL  Samba Member
