WagenKult Samba Member
Joined: October 26, 2004 Posts: 169 Location: Antelope Valley, Ca
Posted: Mon Aug 28, 2006 12:12 pm Post subject: Is my alternator charging too much? |
While driving home from a VW meet yesterday I noticed my volt gauge was up to almost 16 volts. It has never done that before. Usually stays at around 14 volts. It's a 75 amp alternator and I was on the freeway cruising at 65-70 mph. On surface streets it dropped to just above 14 volts. Anybody with thoughts on this? _________________ Vintage Air-Cooled VW Garage & Vintage Parts |
the.fordhams Samba Member
Joined: February 11, 2004 Posts: 482 Location: Charlotte, NC
Posted: Mon Aug 28, 2006 5:36 pm Post subject: |
Alternators should regulate themselves to an output in the region of 14 to 14.4V - hot or cold. At idle they may just charge, anything above idle they hit 14V or so and then go on reulating to this voltage with higher rpm. Spinning faster should not change the output and will merely make the alternator's regulator run hotter.
Alternators fail in a number of ways but the more common I think is for one or more of the diodes in the regulator to fail - this leads to a higher (read ugly) voltage output spikes. Basically any more than 14v or so is not good for the battery. Most service shops have a battery tester that also does start / charge type tests. They'll probably do a test for free.
Is the battery hot after a long run? Do the lights vary / pulse / flicker at night above about 1500 rpms? Have you got blown bulbs? Is the battery able to crank well enough? All potential signs of a bad alternator.
Good luck,
Al _________________ 63 OG Turkis Bug Patina air ride
65 OG Safari Beige Notch project
65 OG Pearl White SO42 Patina
67 SO42 project
03 Eurovan Weekender
08 Touareg 2 V6
WANTED :
Bob King VW dealer Wilmington NC dealer tag surround and any Literature for 03 Weekender |
Posted: Tue Aug 29, 2006 8:06 am Post subject: |
| the.fordhams wrote: |
Is the battery hot after a long run? Do the lights vary / pulse / flicker at night above about 1500 rpms? Have you got blown bulbs? Is the battery able to crank well enough? |
Thanks for the response Al. I didn't check to see if the battery got hot. No lights flicker or are blown. The bug recently got a complete rewire. The battery cranks great. The alternator is pretty new as well. I guess i'll just keep an eye on it and if it persists, i'll get it checked out. _________________ Vintage Air-Cooled VW Garage & Vintage Parts |
L572 Samba Member
Posted: Tue Aug 29, 2006 9:12 am Post subject: |
It is also not unheard of to have a dash gauge that doesn't read quite right... You might want to check the voltage off the alternator with a handheld VOM meter. You could also apply a known voltage to the gauge to see what it reads.
Good luck.
L572 |
