| Does the 'super tin' work? |
| YES |
40% |
[ 12 ] |
| NO |
30% |
[ 9 ] |
| Not worth the effort |
30% |
[ 9 ] |
| Total Votes : 30 |
mrlimbo Samba Member
Joined: April 28, 2004 Posts: 289 Location: Adams, MA
Posted: Fri Sep 08, 2006 6:02 am Post subject: Super tin opinion |
Hi gang,
I'm just looking for opinions about the so called 'super tin'. You know that tin that can be mounted under the cylinders. I think it was stock on the type 3 engine. I'm just curious if it actually works or if its just a band aid for a poorly sealed engine.
I was thinking of putting a set on my 67 bus. Its basically stock and I've made sure that all the tin, seals and even the thermostat are in place and working. The engine doesn't run hot, but if the tin is worth the effort, every little bit helps. Thanks for your time. _________________ -Jim DiGennaro, Samba lurker, Disc Jockey and LiMBO freak www.LiMBObus.org
'67 Kombi- April, its not original and I don't care.
'87 Vanagon GL (daily driver)
'01 Jetta Honey's car
Looking for a Vanagon weekender or Escorial green camper. |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 80280 Location: Sneaking up behind you
Posted: Fri Sep 08, 2006 6:35 am Post subject: |
Super Tin = Type 3 ?
Type 1 should use Type 1 tin.
Type 3 should use Type 3 tin.
If it was better VW would of used it on Type 1s. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
Alan_U Samba Member
Joined: July 10, 2004 Posts: 1762 Location: Vancouver, BC Canada
Posted: Fri Sep 08, 2006 8:14 am Post subject: |
I put some taiwan special cool tin on my 2332. On my other new 2332 longblock on the engine stand I put some swap meet special original OE cool tin. Cost a whole $1 at the swap and with some quick sandblasting and rattle can its like new again.
I couldn't put the type 1 sleds on my engines because.......just because. _________________ 11.92sec pump gas true daily driver. Who says it cant be done.
No more time for VW's....... |
Posted: Fri Sep 08, 2006 11:24 am Post subject: |
| Glenn wrote: |
| Super Tin = Type 3 ?. |
VW used it on the type 3 engine, they called them 'deflector plates' part number 113-119-451. Long obsolete from VW. (I found the part number on an old microfische dated 1982) I figure some yahoo must have tried it on a type one, saw they worked to help cool a poorly sealed engine and then as a way to sell them called them 'super tin'.
| Glenn wrote: |
| If it was better VW would of used it on Type 1s. |
My thought exactly. I just thought if it actually dropped the engine temp even just a few degrees, it might be worth the effort. _________________ -Jim DiGennaro, Samba lurker, Disc Jockey and LiMBO freak www.LiMBObus.org
keifernet Samba Search & Rescue
Joined: May 11, 2002 Posts: 19395 Location: Samba Center for Behavioral Science
Posted: Fri Sep 08, 2006 12:06 pm Post subject: |
| Some R & D done showed that they actually made the cyls hotter on a type 1 upright engine. |
pdub Samba Member
Posted: Fri Sep 08, 2006 12:21 pm Post subject: |
| Plus on offroad cars they just collect more crap in them and then you really run hot. Off road guys use the smaller "stock" ones as they dont collect as much junk and they are small enough to pull/wash out out the weeds, leaves and mud etc. |
gt1953 Samba Member
Joined: May 08, 2002 Posts: 13957 Location: White Mountains Arizona
Posted: Sat Sep 09, 2006 7:18 am Post subject: |
Has any one here, engine builders or whom ever actually invested the time and tried "the tins" on the same engine in a vehicle same conditions and have a comparison so we can all refer to the post and put this to bed once and for all. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
Midwest aircooled Samba Member
Joined: June 19, 2001 Posts: 330 Location: St.Louis, MO
Posted: Sat Sep 09, 2006 2:10 pm Post subject: |
You need to look at the entire picture of how the engine is set up. If your running all the stock Type 1 tin such as the three piece lower tin that screws to the cyl shrouds and heat boxes, as well as the small lower deflectors that screw to the cyl tins below the breast plate, its not going to be any better than that. On the other hand, if you have a large engine running a merged header with no space for all the original lower tin, the type three tin helps to direct air around the cylinder for more even cooling now that you dont have the original Type 1 tin to do it. In those cases I would be willing to bet its an improvement over having nothing but the stock small cool tins.
Just my .02
Jason _________________ 1972 Bug 2332cc turbo, all under the decklid and 400+ rwhp, street driven!
Featured in Hot VWs Dec 2010
1957 Oval window Rag, Cover car, summer issue Volksamerica Magazine
Midwest Air-Cooled & Machine
Facebook.com/midwestaircooled |
Glenn  Mr. 010
Posted: Sat Sep 09, 2006 2:30 pm Post subject: |
| vwjunkie53 wrote: |
Just my .02
Jason |
Berg GB933S is a 1-5/8" with #1 and #3 pipes moved it. It clears all the stock tin and thermostat. You can use 73 Thing tin to close off the gap left from no heater boxes. _________________ Glenn
Member #1009
#BlueSquare
Eaallred Samba Member
Joined: May 18, 2003 Posts: 5756 Location: West Valley City, Utah
Posted: Sat Sep 09, 2006 8:24 pm Post subject: Re: Super tin opinion |
| mrlimbo wrote: |
I was thinking of putting a set on my 67 bus. . |
If you want to know how to maximize the cooling on a splitty bus, do a search on "engine bay vacuum". _________________ Eric Allred
You have to remember something: Everybody pities the weak; Jealousy you have to earn. |
Posted: Sat Sep 09, 2006 9:07 pm Post subject: |
I didn't say it was best for every combination. In some cases, such as mine, I'm running a 1-3/4" large flange pheonix header and there is no room for tin other than stock type 1 or the type 3. I'm running comp eliminator heads and 10:1 compression on the street without melting down, so it must working...
jamestwo Samba Member
Posted: Sat Sep 09, 2006 10:13 pm Post subject: |
Agree. Type 3 tin is better then just the batwings on a type one. if running a merged header, the type 3 tin is cheap and effective.
| vwjunkie53 wrote: |
Just my .02
Jason |
_________________ hEY, lOOK, i'M WRONG HALF THE TIME, AND THE OTHER HALF i'M NOT SURE WHAT THE HECK i'M TALKING ABOUT. MY POST ARE FOR MY OWN ENTERTAINMENT VALUE ONLY. |
Posted: Sun Sep 10, 2006 8:22 am Post subject: |
Thanks for the tips. These links were very helpful. My suspictions are confirmed. I'm not actually having a cooling issue with my bus, I just thought that if the 'super tin' improved cooling at all, I'd try it. Now I know not to waste my time. Thanks again. _________________ -Jim DiGennaro, Samba lurker, Disc Jockey and LiMBO freak www.LiMBObus.org
