billmetric Samba Member
Joined: March 16, 2006 Posts: 1061 Location: Columbus City USA
Posted: Mon Oct 23, 2006 9:56 pm Post subject: split radio question |
ok, I have this here slightly hacked up pushbutton Telefunken face plate and no radio for it, I have been meaning to either weld it up smooth and cut it back out for a tape deck or something modern, or should I just buy a repro Bakelite block off plate and try cutting that up and try and find someone who needs the Telefunken faceplate? I think I would have a harder time fitting a new radio into a thick piece of Bakelite then I would into metal, what is the correct model number for the Telefunken "pushbutton" I didnt find it refered by any other name in a brief photo search?
heres one not hacked up:
_________________ There is an idea of a Billmetric; some kind of abstraction. But there is no real me: only an entity, something illusory. And though I can hide my cold gaze, and you can shake my hand and feel flesh gripping yours and maybe you can even sense our lifestyles are probably comparable... I simply am not there... |
Brezelwerks Samba Member
Joined: March 17, 2003 Posts: 1421 Location: Tyngsboro, MA
Posted: Tue Oct 24, 2006 5:40 am Post subject: |
Its a model ID52 radio actually, its been hacked pretty good, but pieces could be welded back. I have a few of these original faces as well and could trace a template of one so you know what to cut and weld back in. I'm actually making a run of these radios this winter which use these same original faceplates, mine will all use restored Sapphire I radios, and they will look identical to the original since I make all the trim parts for this radio. The vol/tuner holes are standard DIN spacing so a variety of radios will fit the hole. A few of my customers have also bought my reproduction blank pod plate to install a radio too, a common problem however is that the thickness of the plate sometimes is too thick to be able to put the top nuts on the vol/tuner shafts, there are work arounds but theres some work going that direction as well, good luck! |
RichOakley Samba Member
Joined: August 30, 2004 Posts: 1108 Location: Midlands, UK
Posted: Tue Oct 24, 2006 6:49 am Post subject: |
Brezelwerks wrote: |
Gary,
Any idea how much your 'new' radios will cost?
Cheers
Rich. |
Posted: Tue Oct 24, 2006 11:27 am Post subject: |
I'll have the first 2 of these hybrid (original metal faceplate) ID52 radios available in January, price will be somewhere around $900. Two full reproduction Becker Monza radios will be available late Nov for approximately $1100. As I continuously outfit the new shop here now and obtain more help over the winter I hope to also produce the Telefunken IA50 lightning bolt radio for early spring. We'll generally only likely produce a handful of each radio per year.
Gary |
Posted: Tue Oct 24, 2006 2:32 pm Post subject: |
I bought an IA50 from a junkyard in Germany for like 5 D-marks back in 1989, it was laying in a pile of other radios outside under a rotten tarp, it was a piece of crap but thats what it was, I still have one of the tubes out of it, the faceplate was good and the dial was fair, I traded it for a batwing horn button for my oval ... _________________ There is an idea of a Billmetric; some kind of abstraction. But there is no real me: only an entity, something illusory. And though I can hide my cold gaze, and you can shake my hand and feel flesh gripping yours and maybe you can even sense our lifestyles are probably comparable... I simply am not there... |
Posted: Tue Oct 24, 2006 8:01 pm Post subject: |
I am looking for a ID52 power pack for one of these if any has one. |
Rich's 50 Samba Member
Joined: February 18, 2004 Posts: 10781 Location: San Diego, CA
Posted: Tue Oct 24, 2006 8:30 pm Post subject: |
[email protected] wrote: |
me too |
Posted: Wed Nov 01, 2006 10:59 am Post subject: |
I have a couple of power packs but I'm not sure what they are for, probably oval ones, how do I tell what power pack is for what radio ? _________________ There is an idea of a Billmetric; some kind of abstraction. But there is no real me: only an entity, something illusory. And though I can hide my cold gaze, and you can shake my hand and feel flesh gripping yours and maybe you can even sense our lifestyles are probably comparable... I simply am not there... |
ldi.eduardo Samba Member
Joined: November 11, 2014 Posts: 2 Location: Guadalajara, Mexico
wimkever Samba Member
Joined: July 16, 2004 Posts: 413 Location: Holland (the Netherlands)
Posted: Tue Nov 11, 2014 3:04 pm Post subject: Re: I need help, whith dimensions of telefunken radio |
ldi.eduardo wrote: |
Hi !
I have the intention to make a modern replica of a preceding model. But I need help figuring out the width and height measurements .
I hope I can help with these measures.
Thank you
[img]http://www.volksgdl.com.mx/foro/index.php?action=dlattach;topic=33823.0;attach=2065;[/img]
No pics to be seen. Try again with the proper links.
And what do you mean by "I hope I can help with these measures"?
If you can help I wonder what your question is. _________________ a beetle is like a cocker spaniel, always funny but sometimes not listening |
Posted: Wed Nov 12, 2014 12:04 pm Post subject: |
Sorry!
but my english is pretty bad.
my problem to make a replic is get the messures of the original radio, height and width.
hope somebody helps.
thanks |
eurodub Samba Member
Posted: Wed Nov 12, 2014 1:06 pm Post subject: |
get an original split dash. the radio interferes with the ashtray and a corner on the dash _________________ 1960 1200 model 117 deluxe ragtop
1974 T2 Westfalia Campmobile
1976 MK1 Golf |
