Teeroy  Samba Member
Joined: April 20, 2003 Posts: 3884 Location: Eastern WA
Posted: Wed Nov 22, 2006 10:15 am Post subject: Cam bearing tang |
Going through my parts for my 1776 , I opened up my Berg modified Glyco double thrust cam bearings , and see that the tang is filed off both halfs of the thrust bearing . Is there enough crush on the thrust bearing to run it as is ? Or do I need to make a tang in the one half ? Can't seem to find my tech book at the moment . _________________ Pres. Rivercity VW Club www.rcvwclub.org
Founder Derr Wheat Panzers (DWP)
ARR #3
www.autosportsnorthwest.org |
gerg a.k.a. 6volt65
Joined: April 25, 2003 Posts: 5454 Location: Monroe, LA
Posted: Wed Nov 22, 2006 10:45 am Post subject: |
I just read in the Berg literature last night that they beleive the tang is not needed. _________________ Gerg
. . . I got 99 problems and my bus ain't one . . .
'65 Sunroof Beetle
'65 Vert
'60 Singlecab |
MConstable Samba Member
Joined: May 04, 2004 Posts: 1822 Location: Saint Charles IL
Posted: Wed Nov 22, 2006 10:50 am Post subject: |
New cases don't have the slot for the tang...everybody either files the tang off, or notches the case...usually the former. _________________ 1974 Thing |
Teeroy  Samba Member
Posted: Wed Nov 22, 2006 10:50 am Post subject: Cam bearing tang |
Yep , just found mine , says enough crush on the thrust bearing , to not need the tang . _________________ Pres. Rivercity VW Club www.rcvwclub.org
ARR #3
1961bluebug Samba Member
Joined: November 11, 2002 Posts: 1137 Location: Czech Republic, Europe
Posted: Tue Feb 10, 2009 12:41 pm Post subject: |
today I robbed thrust bearing halves from two sets of Kolbenschmidt type 1 bearings and the thrust halves doesn´t have a tang on them. So will I be OK running dual thrust cam bearing with no tang? I suppose engine case crush will hold them correctly, but wanna be sure.. _________________
|82x94|
1961 Deluxe beetle, 1971 type 181, 1968 T2a Baywindow, 1973 Type 147 "Swiss Fridolin"(sold), 1966 Deluxe sedan (sold), 1983 "Silver Bug" edition (sold), 1961 beetle (sold) |
Scott Novak Samba Member
Joined: October 12, 2004 Posts: 1586 Location: Minneapolis, Minnesota
Posted: Tue Feb 10, 2009 2:44 pm Post subject: |
Does anyone ever use Loctite sleeve and bearing retainer under their cam bearings, main bearings, or rod bearings?
Scott Novak |
gonebuggy Samba Member
Posted: Tue Feb 10, 2009 2:50 pm Post subject: |
| Scott Novak wrote: |
Scott Novak |
I wouldn't recommend that. It takes up "space" and will increase the bearing crush.
Alex |
Posted: Tue Feb 10, 2009 3:00 pm Post subject: |
all manuals recommend to install all bearings dry, so that is what I´m gonna do.. _________________
|82x94|
SRP1 Samba Member
Posted: Tue Feb 10, 2009 10:11 pm Post subject: |
Scott Novak |
Bad idea, it expands as it dries pushing the bearing into the journal, and minimizes clearances.
No tang on a single thrust bearing, crazy.
No tang on a dual thrust bearing, not in any engine I will ever build!
The bearings float enough as it is when the engine is at operating temp.
Did the Berg article happen to mention the type of cam gear being used for this, was it straight cut perhaps?
In theory the bearings are crush fit even on the mains, the only reason for the pins on the mains is to align the oil holes.
IMO though this is different for the cam bearings, they are crush fit, but those tangs are there to locate the bearing and keep it in place. |
venomous-67 Samba Member
Posted: Wed Feb 11, 2009 2:03 am Post subject: |
In Berg GB801 Tech book he states all bearings are crush from the case.
Glyco was the brand of bearing.
Mahle sell a double thrust set. |
Posted: Wed Feb 11, 2009 3:16 am Post subject: |
| SRP1 wrote: |
The bearings float enough as it is when the engine is at operating temp. |
| SRP1 wrote: |
| Did the Berg article happen to mention the type of cam gear being used for this, was it straight cut perhaps? |
Berg claimed that he had never had a cam bearing turn in over 24 years. He never used the tangs. He only used case crush to hold the bearings in place. Berg only sells the cam bearings sets with two thrust bearing halves. For triple valves springs or Chevy springs he recommended straight cut cam gears. Otherwise he used the stock cam gears.
Berg also did NOT recommend align boring cases. And if you did you also needed to stress relieve the cases which was more money than it was worth to properly. I believe another part of the operation is to remove the case studs and shave the mating surfaces flat.
With a fresh engine case I'm sure that the likelyhood of a cam bearing spinning is less than a used case that was pounded out of round enough to need align boring.
Scott Novak
Posted: Wed Feb 11, 2009 4:19 am Post subject: |
Tonight I´ll practice on leftower bearing shells on how hard is to create a tang and I´ll see. _________________
|82x94|
Joined: August 15, 2002 Posts: 4394 Location: Brew City
Posted: Wed Feb 11, 2009 7:38 am Post subject: |
| MConstable wrote: |
| New cases don't have the slot for the tang...everybody either files the tang off, or notches the case...usually the former. |
Do you mean for the other half of the double thrust cam bearing sets? Because all new cases have notches for stock cam bearings.
As for "tang vs no tang"; I have built engines both ways with no problems. |
Jimmy111 Samba Member
Joined: October 05, 2006 Posts: 2643 Location: Wyoming
Posted: Wed Feb 11, 2009 7:55 am Post subject: |
The Tang is to keep the bearing from spinning if the oil pump siezes up or if you have a lack of oil pressure when using a steel cam gear It doesent always keep it from happening. If the oil pump siezes the cam gear is slammed back against the bearing very hardand can turn the bearing. If the bearing turns even a little it will start to wear very quickly.
I would say if you have the tangs use them but if not you will probably not have any problem
All cases have at least one grove cut for the tang but I have seen them without any too.
No loctite. |
turboblue Samba Member
Joined: October 09, 2003 Posts: 4216 Location: Central Indiana
Posted: Wed Feb 11, 2009 8:53 am Post subject: |
| Quote: |
| Berg claimed that he had never had a cam bearing turn in over 24 years. |
Pretty doubtful he tore down every engine he had ever built to verify that. _________________ Gary
Turbo VW Sand Drag Buggy
"If you don't run into the Devil every once in awhile, you must be going in the same direction!" |
SRP1 Samba Member
Posted: Wed Feb 11, 2009 10:14 am Post subject: |
| Not everything Berg did was correct either, what purpose would there be in removing a tang that VW engineers felt needed to be in place. |
vw1964type1 Samba Member
Joined: May 29, 2008 Posts: 47 Location: South Africa
Posted: Wed Feb 11, 2009 10:29 am Post subject: |
OK, I didn't know the thrust bearings had tangs, I bought two sets of KS bearings for my build, None of the thrust bearings had tangs on. Should I be worried? I think not.
My dad has been my partner during the build and we both agreed that you could spend years debating this and that and never actually build an engine because you might become afraid of forgetting something or fitting the wrong part. I honestly believe that tang or no tang you will have bigger headaches to worry about should the bearings be able to turn in the case.
But that is just MHO and I have only built two type1 engines thus far. _________________ 2009 550 Spyder replica build in progress
2007 Mercedes ML550
2005 Mercedes SLK350 |
vugbug68 Samba Member
Joined: June 25, 2006 Posts: 2701 Location: sacramento
Posted: Mon Mar 02, 2009 11:06 pm Post subject: |
my Mahle dual thrust bearings have tangs on both bearings but my case only has a groove for one, (its a stock AH dual relief case)
Should I cut a groove in the case or file it off the bearing? _________________ 71 Super
66 Corvair
69 Baja Bug |
SRP1 Samba Member
Posted: Tue Mar 03, 2009 12:15 am Post subject: |
| File it off the one side. |
Posted: Tue Mar 03, 2009 7:33 am Post subject: |
I ended up cutting a small groove in the case, removing the tang would make the bearing real thin in that spot. also its much easier to file soft magnesium then a hard bearing. _________________ 71 Super
66 Corvair
69 Baja Bug |
