aquamanx Samba Member
Posted: Wed Jan 10, 2007 7:20 pm Post subject: 091 trans and type 1 motor |
Will a type 1 motor bolt up to a 091 (6 rib bus) trans?
How about the starter & clutch?
Are there any modifications that would need to be done?
Thanks Chris |
takotruckin SUPER Baja
Joined: August 14, 2005 Posts: 2378 Location: stuck in fresno, ca
Posted: Wed Jan 10, 2007 7:58 pm Post subject: |
well, i beleive you would need an 091 starter, and longer studs to hold the engine on. the easy way to do it (what i did) is to find an 002 bellhousing _________________ Member of the baja's that don't run club, for now!! |
Durf Samba Member
Joined: October 19, 2006 Posts: 245 Location: San Diego
Posted: Wed Jan 10, 2007 9:43 pm Post subject: |
| An 002 bell housing will work with an 091? I have a spare 002 bell housing and I have a friend with a broken 091 bell housing on his buggy. I took the 002 bell housing today and told him he could have it if it would work. We compared the two he didn't think it would work so I brought it back home with me. If it will work I'll take it back to him tomorrow. Hope I'm not hijacking the thread. |
Posted: Wed Jan 10, 2007 9:44 pm Post subject: |
yeah, it will bolt right on. make sure you use a new gasket _________________ Member of the baja's that don't run club, for now!! |
Durf Samba Member
Posted: Wed Jan 10, 2007 9:50 pm Post subject: |
| Thanks. That's good news. I did notice the top two mounting holes are a little different but that's not a big deal. |
Durf Samba Member
mattt Samba Member
Posted: Thu Jan 11, 2007 12:35 am Post subject: |
| You will have to shorten the input shaft on the trans roughly 1/2". Confirm that dimension first, try a VW trans shop. The T4 motors took a longer input shaft than the T1 engine. |
Jamnajar Samba Member
Joined: August 28, 2006 Posts: 542 Location: Saratoga Springs, UT
Posted: Thu Jan 11, 2007 3:00 am Post subject: |
| Dude you have to have an 091 starter?? I thought they all (bug, early bus, 002,091) used the same starters...you learn something new everyday... |
BugZyla.com Samba Member
Posted: Thu Jan 11, 2007 6:57 am Post subject: |
You do have to shorten the input shaft about 1/2 inch. The best way to guage this is to measure how far the input shaft sticks out of your stock t-1 trans and make the 091 shaft the same length. I just trim them with a cut off wheel and then put the small taper back on the end with a die grinder with a sanding pad on it. The taper makes it easier for the input shaft to go into the gland nut.
Im not sure about the 002, but the 091 starter is different. If you put a t-1 starter onm an 091 the starter wont engage the flywheel. _________________ Daryll http://www.azbaja.com P.R.
http://www.bugzyla.com
"Why is there Braille on a Drive Thru ATM?" |
ntsqd Samba Member
Posted: Thu Jan 11, 2007 9:00 am Post subject: |
I've used an Autostick starter in my glass buggy's 002 since about '88. _________________ OFf Road in So. CA? Want to continue to do so?
CORVA.org |
turboblue Samba Member
Joined: October 09, 2003 Posts: 4216 Location: Central Indiana
Posted: Thu Jan 11, 2007 9:07 am Post subject: |
| Jamnajar wrote: |
All but the 091 can use the Bosch SR15 (manual) or SR17 (autostick).
The 091 uses the Bosch SR87 if you have the original bellhousing in place. _________________ Gary
Turbo VW Sand Drag Buggy
"If you don't run into the Devil every once in awhile, you must be going in the same direction!" |
Posted: Thu Jan 11, 2007 3:03 pm Post subject: |
Let me see if Ive got this rite
1 longer bolts
2 cut the input shaft about 1/2"
3 use a 091 starter (Bosch SR87)
Then run the late model type 1 clutch & pressure plate?
Also after cutting the input shaft Im guessing I cant ever go back to a type 4 engine.
The reason I ask is building a sand rail and Ive got a 76 bus with the 2.0L and 091 trans (2.0L motor needs rebuild), I also have a fresh rebuilt stock 1600. So I was thinking Id use the 091 trans and 1600 motor till I have the time and $ to build the type 4 |
ntsqd Samba Member
Posted: Thu Jan 11, 2007 3:24 pm Post subject: |
It may not be "correct", but on my 002 with a 002 b/h I didn't use longer engine studs or bolts.
I just put an 002 b/h on an 091. The b/h to t/a case bolts were long enough to engage the 091 case an appropriate distance.
So I'm mystified by the call for longer bolts. _________________ OFf Road in So. CA? Want to continue to do so?
CORVA.org |
Posted: Thu Jan 11, 2007 3:31 pm Post subject: |
| ntsqd wrote: |
So I'm mystified by the call for longer bolts. |
Did you still have to cut the input shaft of the 091 when using the 002 B/H? |
Durf Samba Member
Posted: Thu Jan 11, 2007 3:45 pm Post subject: |
| aquamanx wrote: |
That's the only time you have to cut the input shaft from my understanding. The 091 bell housing is a tad deeper than the 002. The chassis mounting holes on top are a bit different too (not where bell housing mounts to engine).
002 Bellhousing:
stock type 1 starter
stock mounting studs/bolts
cut approx 1/2 inch off input shaft
091 Bellhousing:
starter for 091 (sr87)
longer mounting studs/bolts
no cutting of the input shaft |
Posted: Thu Jan 11, 2007 5:27 pm Post subject: |
| Durf wrote: |
| aquamanx wrote: |
002 Bellhousing:
091 Bellhousing:
Ok thanks that helps! I should be good to go with option 2
091 Bellhousing:
ntsqd Samba Member
Posted: Thu Jan 11, 2007 7:22 pm Post subject: |
| aquamanx wrote: |
Just to confirm, I've not yet cut it, but it is pretty obvious that it is too long. _________________ OFf Road in So. CA? Want to continue to do so?
CORVA.org |
mattt Samba Member
Posted: Thu Jan 11, 2007 7:35 pm Post subject: |
| AFAIK, regardless of which bell housing you use, the input shaft must be shortened to work with a T1 engine. The difference is in the gland nut between a T4 engine and T1 engine. You can use whatever clutch/pressure plate works with the flywheel on your particular engine. I think all T1's have a 200mm flywheel. |
ntsqd Samba Member
Posted: Thu Jan 11, 2007 9:23 pm Post subject: |
I would try a T1 in the 091 b/h b4 cuting it. The reason is that with the 091 b/h on my 091 t/a it looked about right, but with the 002 b/h on my t/a it was obvious that it was too long. _________________ OFf Road in So. CA? Want to continue to do so?
CORVA.org |
Posted: Fri Jan 12, 2007 8:17 am Post subject: |
| Quote: |
| AFAIK, regardless of which bell housing you use, the input shaft must be shortened to work with a T1 engine |
What about the 68-71 bus that came with the T-1 engine?
I think there are three versions of the 3 rib tranny.
Early 68 with the acorn bolts around the drive flanges.
Mid year 68-71 with the T-1 engine, smooth bell housing.
Later version 72-73 with the mounting bosses on the bell housing and the T-2/4 style engine. _________________ Gary
