Kadron floats
travis1488
travis1488 is offline
PostPosted: Sat Jan 13, 2007 8:31 pm    Post subject: Kadron floats Reply with quote
How do you check the float levels, and what do you do to adjust them if needed?
A.J.Sims
Banned
Location: LowBugget.com 982 N Batavia A4 Orange Ca 92867
A.J.Sims is offline
PostPosted: Sun Jan 14, 2007 12:32 am    Post subject: Reply with quote
if you have the dark gaskets than you will use .06" of shims under the needle valve.
If you have the stock style than .04" shims under the needle valve.
Do not try to bend the float.
P.S the pin sits on top.
here is a link with some pics and info.
[url] http://lowbugget.com/main_jets.html[/url]
Have tech questions? Need real help? Give us a call.
www.Lowbugget.com
982 North Batavia A4, Orange Ca 92867.
68 drag bug 1915cc 10.50's @130mph
66 fastback 2387cc turbo street car
67 baja 2054cc turbo.
travis1488
PostPosted: Sun Jan 14, 2007 9:53 am    Post subject: Reply with quote
Are you talking about the pin that holds the float in the carb body?
