Wheel lugs "too short"???
DINK
DINK is offline
PostPosted: Sun Mar 11, 2007 8:36 pm    Post subject: Wheel lugs "too short"??? Reply with quote
I have stock alloy wheels on my Syncro. The lugs come up a bit short. Any idea why? Could it be that the camper came with steel wheels and they require a shorter lug?
Thanks
66 Panel < 40,000 mi.
73 Std. Sedan
GBNF: 64 21 Window, 64 Deluxe, 73 Westy, 79 Bay, 84 GLI, 91 GL, 04 GLI, 87 Syncro Westy
msinabottle
msinabottle is offline
PostPosted: Sun Mar 11, 2007 8:48 pm    Post subject: Happens all the time... Reply with quote
Have a look at loogy's 'The DEFINITIVE Wheel and Tire Thread.' I'm going to all studs on Winston, you can read the details there.
Best!
'Winston,' '84 1.9 WBX Westy
many ways, but never, never, never in silence."
hiram6
hiram6 is offline
PostPosted: Mon Mar 12, 2007 7:27 am    Post subject: Reply with quote
I'd bet that it originally came with the steelies. If factory equipped with the alloys. it would have had the correct longer studs/lugs.
1985 Westy, 1.9L automatic (Daisy)
1996 Mazda Miata
1998 Jeep Grand Cherokee 5.9 Limited
You can't lie around on the beach and drink rum all day.................unless you start first thing in the morning.
vanmike
vanmike is offline
PostPosted: Mon Mar 12, 2007 4:58 pm    Post subject: Reply with quote
Do you have the proper bolts and nuts for the alloy wheels?
There is no difference in length of the studs, the taper of
the alloy nuts/bolts is much steeper than the steel wheel bolts/nuts.
DINK
DINK is offline
PostPosted: Mon Mar 12, 2007 9:31 pm    Post subject: Reply with quote
I have the proper nuts. It did not have them when I bought it. The bolts may have been replaced at some time.
73 Std. Sedan
vanmike
vanmike is offline
PostPosted: Tue Mar 13, 2007 5:43 pm    Post subject: Reply with quote
checked ETKA,
for steel wheels 020 112 1 14x1.5 20x for syncro, 10x for 2wd
alloy wheels 255 601 143 20x for syncro, 10x for 2wd
rear axle studs 211 501 627A 34.5 long same for syncro or 2wd
" " " 211 501 627 41 long listed for syncro only if equipped with 16 inch wheels
front stud for syncro 251 405 591 no length listed
DINK
DINK is offline
PostPosted: Tue Mar 13, 2007 8:46 pm    Post subject: Reply with quote
How much should it cost per stud to have these replaced?
73 Std. Sedan
DINK
DINK is offline
PostPosted: Sun Mar 18, 2007 4:35 pm    Post subject: Reply with quote
Wheels from a bay window fir perfectly.
Since I've got Audi 15 inchers to go on someday, the VW alloys are now available.
Any trading stock out there?
e.g.
good 15" load rated tires in exchange for aluminum alloys, steel wheels and some 14" Yokos...
73 Std. Sedan
mightyart
mightyart is offline
PostPosted: Sun Mar 18, 2007 6:04 pm    Post subject: Reply with quote
I've never messed with vanagon alloys but the lug nuts for steel wheels are very differant from lugs for alloys:
Alloy lug nuts:
notice how they go into the wheel holes.
steel lug nuts:
they are tapered at the bottom to fit into the thin steel wheel holes which should be tapered to.
So if you are trying to use steel nuts on much thicker alloys the studs might seem to short, plus it doesn't hold them very well.
