ivsamhell Samba Member
Joined: June 12, 2006 Posts: 858 Location: hesperiaCA
Posted: Mon Mar 12, 2007 8:23 pm Post subject: 61 turnsignal switch |
ok my turn signal switch works (61 6-wire spade connectors) but the arm is broken off, anyone know if i can mix match some parts from a later one(3 wire)?
or anyone have a beige(or whatever that ivory color is) one they want to part with |
scottyhoffo Samba Member
Joined: July 01, 2004 Posts: 253 Location: San Diego, CA USA
Posted: Wed Mar 14, 2007 1:15 am Post subject: |
I seem to recall a post a while back about this... I may be wrong but if
I remember correctly the answer was no, because the internals were a lot different - something like that.
I need a new switch for my '61 for the same reason. One of the PO had simply stuck a small bolt through the two broken pieces making for a very short turn signal lever. Quite ghetto indeed. _________________ Scott Hoffman
1961 Beetle sedan
"You've been Volkswagened- passed by 40 hp!" |
LXS Samba Member
Joined: February 15, 2007 Posts: 101 Location: East Los Angeles
Posted: Wed Mar 14, 2007 1:28 am Post subject: |
Tell me about it! Join the "I need a '60-'61 turn signal switch" club I'm the "founding member", welcome to the club! I'm president, and I seen you met my sergent at arms, Scotty H! LoL |
bill may Samba Member
Joined: August 27, 2003 Posts: 14160 Location: san diego,ca
LXS Samba Member
Posted: Wed Mar 14, 2007 7:48 am Post subject: |
| bill may wrote: |
| i used an arm off a 63 3wire to replace the arm on my 60 euro ragtop. |
How did you wire it up to use the brake and turn signal lights? Or did you use the 62 and newer taillights? |
Posted: Wed Mar 14, 2007 9:35 am Post subject: |
| scottyhoffo wrote: |
I need a new switch for my '61 for the same reason. One of the PO had simply stuck a small bolt through the two broken pieces making for a very short turn signal lever. Quite ghetto indeed. |
i dunno wounds pretty nice......
Posted: Wed Mar 14, 2007 9:38 am Post subject: |
| bill may wrote: |
thats exactly what i had in mind, run into any problems on that? |
LXS Samba Member
Posted: Thu Mar 15, 2007 4:06 pm Post subject: |
| bill may wrote: |
| reread my post- i used only the arm. you pull the clip and the arm comes off. i used the stock 1960 tailights. |
O ok, nevermind then I miss read and thought you used the whole turn signal switch. I've got a 62-newer turn signal switch, so I can't make it work like you did.  |
Posted: Sat Mar 24, 2007 1:29 pm Post subject: At least yours doesn't look like this... |
Better late than never - figured y'all would get a kick out of this:
That's my car's PO hack job. _________________ Scott Hoffman
1961 Beetle sedan
LXS Samba Member
Posted: Sat Mar 24, 2007 1:58 pm Post subject: |
| WoW!!! and OUTCH!!!! |
akokarski Samba Member
Posted: Sat Mar 24, 2007 2:09 pm Post subject: |
you can use 3 wire switch with 4 relays. Not pretty but it will work. actually you might get away with 2 relays, I have 4 because I am using my front park lights as turnsigs.
Anton |
LXS Samba Member
Posted: Sat Mar 24, 2007 3:15 pm Post subject: |
| akokarski wrote: |
Anton |
How did you wire this up? I've got the 3 wire signal switch, and don't have any brake lights (which is really scarry when big trucks are speeding behind me!!!) or turn signals. Any help and/or info would be great! Thanks! |
Posted: Sat Mar 24, 2007 3:28 pm Post subject: |
| LXS wrote: |
| akokarski wrote: |
Anton |
http://www.nls.net/mp/volks/htm/flashrly.htm
http://www.nls.net/mp/volks/schem/flashrly.jpg
it might look a little crazy but after looking at it for a few minutes you will see that it's just 4 relays. one for each corner. brake circuit is on and get's interrupted when switch is flipped. same idea for the front.
Anton |
fluxcap Samba Member
Joined: February 07, 2006 Posts: 1969 Location: Newnan GA
Posted: Sat Mar 24, 2007 5:07 pm Post subject: |
No need for relays. If you have a 3 wire switch just go to the auto parts store and get a trailer convertor. It's for cars with independent (two separate bulbs) towing a trailer with common (one bulb) lights. you run your brake light wire and rear turn signal wires through it, and it does the work of the 6 wire switch. I just wired one in on my 62 which has the earlier snowflake taillights. Here is a pic of the convertor. I wired mine up front so I could easily change it when I get a 6 wire switch, but you can just as easily wire it in the rear out of sight. It works perfect, took about 3 minutes to install and is priced cheap (10 bucks).
_________________ Eric - 1966 camper bus
"It's like, how much more black could this be, and the answer is none.......none more black." |
Posted: Sat Mar 24, 2007 6:07 pm Post subject: |
Fluxcap,
where did you find this? I haven't been able to find this unit when I did my lights wiring. Although i would still end up running 2 of those. one for the front and one for rear....
Anton |
Posted: Sat Mar 24, 2007 6:23 pm Post subject: |
I got mine at autozone. But I think most autopart stores will carry them. I've even seen them at walmart. Just look in the trailer light/wiring section. Unless you have something custom planned for your front blinkers, you should only need one. _________________ Eric - 1966 camper bus
LXS Samba Member
Posted: Sat Mar 24, 2007 6:28 pm Post subject: |
I'll DEFINATLY look into getting that converter! Thanks for the info!
Edit: So just one converter will work for both front and rear turn signals and brake lights, right? Just want to make sure...I've got nothing "fancy" planned.  |
Posted: Sat Mar 24, 2007 6:41 pm Post subject: |
Mine had 5 "input" wires and 4 "output" wires.
The inputs were:
Brake light - this is the wire coming OUT of the master cylinder brake switch
Left signal - this is the left signal wire coming off of the turn signal switch
Right signal - this is the right signal wire coming off of the turn signal switch
Running light - I cut this wire off of the convertor (there is no need to run your running lights through it.)
Ground - I also cut this wire off since the actual ground is created by the contact piece on the light mounting bracket.
The outputs were:
Left - this wire goes to the left rear bulb (duh)
Right - this wire goes to the right rear bulb (duh again)
ground - cut it off
running light - cut it off
Here's a closeup.
Posted: Sat Mar 24, 2007 8:16 pm Post subject: |
LXS, yes, one will do the job. _________________ Eric - 1966 camper bus
