Tranny Leaks After Changing Fluid
BugCatcher1957
BugCatcher1957 is offline
PostPosted: Sun Apr 22, 2007 9:02 pm    Post subject: Tranny Leaks After Changing Fluid Reply with quote
I changed my tranny fluid on my 64 and now the drainage bolt nearest to the front of the car is leaking. Big mess on my garage floor. Dang. Looks like I might have to take the bolt out, let it drain, refill it and hope the second time is a charm ? I tightened the bolt and I still have the leak. Any thoughts? Thanks.
Seb67
Seb67 is offline
PostPosted: Sun Apr 22, 2007 9:28 pm    Post subject: Reply with quote
Maybe it's cross-threaded? How much of the bolt is sticking out of the case?
I just did this on my '64 too and didn't have any problems, so If you have any specific questions, I'll try to help.
1964 Type 1
KTPhil Premium Member
KTPhil is offline
PostPosted: Sun Apr 22, 2007 10:18 pm    Post subject: Reply with quote
Try teflon tape on the threads, but be sure none gets loose and into the case (leave a couple of threads bare at the end that screws in first).
BugCatcher1957
PostPosted: Mon Apr 23, 2007 4:54 am    Post subject: Reply with quote
I don't think that I cross-threaded the bolt, but if I knew what the problem was, I wouldn't have the leak. I am going do everything again and use the teflon tape (which I think is an excellent suggestion).
Hey Seb67, next weekend I will take a few pictures of my 64 and send you a copy.
Thanks.
Seb67
Seb67 is offline
PostPosted: Mon Apr 23, 2007 9:22 am    Post subject: Reply with quote
Just post 'em up in your gallery for all to see...
Are you sure it's leaking from the drain plug and not somewhere else? Is your tranny nice and clean or disgustingly filthy (like mine)?
1964 Type 1
BugCatcher1957
PostPosted: Mon Apr 23, 2007 11:00 am    Post subject: Reply with quote
I am not sure where the leak is, except it is marking its spot under the front drainage bolt. Generally the tranny is caked with crusted grime, except I cleaned it fairly well around the access bolts.
Nothing is easy.
Cusser
Cusser is offline
PostPosted: Mon Apr 23, 2007 12:21 pm    Post subject: Reply with quote
I'd also sugest teflon/PTFE tape. Actually, I'm quite surprised that thick 80-90 weight gear oil (that's what you used, right???) would be able to leak out past the threads. You didn't use ATF did you?
DrDarby
DrDarby is offline
PostPosted: Mon Apr 23, 2007 1:01 pm    Post subject: Reply with quote
Are you sure it isn't coming out farther up and running down the side of the case to the drain bolt area ?
Midwest Autosavers, Inc. Crystal Lake, IL
Seb67
Seb67 is offline
PostPosted: Mon Apr 23, 2007 1:44 pm    Post subject: Reply with quote
That's what I think is happening too. Get a pressure washer. Jack up the rear of the car. Remove both rear wheels and go to town on the whole transmission and rear undercarriage area. Then you will be able to see where the leak is coming from. If you can, get a pressure washer with a soaper attachment and fill it with simple green or something similar. Make sure you don't do this infront of your house - the mess will be legendary.
1964 Type 1
mailman
mailman is offline
PostPosted: Mon Apr 23, 2007 4:43 pm    Post subject: Reply with quote
I have no personal experience with this....but I have heard that over-filling the trans can ruin the seals. Could the fluid be running down from the end of the trans and just dripping off at the drain plug?
Changed the fluid in my (new to me) '64 last fall. The trans was a totally filthy mess to begin with, which would indicate previous leakage. I did the fluid change, and now I have obvious wet leakage.
I suspect the seals are leaking, but I'm going to be changing out the trans before long, so I'll just keep an eye on the fluid level for now.... Sad
'64 Bahama Blue Beetle / steel sunroof
'64 Bahama Blue Beetle Sedan (future ragtop)
BugCatcher1957
PostPosted: Mon Apr 23, 2007 4:55 pm    Post subject: Reply with quote
I used 90 wt gear oil, and I filled it on the side filler hole until it started to drip down the side. I believe this is the proper procedure. I didn't think it was possible to over-fill the tranny because you can't fill it higher than the fill hole. As to where the leak is, I will give it a careful inspection after cleaning it the best I can (I can't power wash it at my house) and if it doesn't reveal anything, I will do it again. Good thing I don't make a living at this, because if I did, I would be broke.
If it leaks all over my garage again, then who knows what after I scream.
Dangermouse
Dangermouse is offline
PostPosted: Mon Apr 23, 2007 6:11 pm    Post subject: Reply with quote
There are three small access holes up on the right hand side which should normally be plugged. If one one the plugs/caps has deteriorated or is missing, fluid can leak down from there and look like its coming from the drain plug.
BugCatcher1957
PostPosted: Mon Apr 23, 2007 7:18 pm    Post subject: Reply with quote
After crawling around on my back with wire brush in hand, I am no longer sure the leak is coming from the drainage bolt. Let's assume that after I scape 43 years of crude off the right side of tranny and find that one or more of these access points is the source of the problem, then what? Also, what if it is a seal, does that mean a different tranny?
Sad
Dangermouse
PostPosted: Mon Apr 23, 2007 7:22 pm    Post subject: Reply with quote
If its one of the small (I think 6-8mm) holes, then I had some success with just sealing it up with silicone.
KTPhil is offline
PostPosted: Mon Apr 23, 2007 8:07 pm    Post subject: Reply with quote
"Access holes"? Aren't those the threaded plugs to hold the detent balls for the shift rods?
Dangermouse
PostPosted: Mon Apr 23, 2007 8:24 pm    Post subject: Reply with quote
Yeah, those. What you said... Very Happy
Leak all over the place, they do.
So, what's a detent ball then Shocked
KTPhil is offline
PostPosted: Mon Apr 23, 2007 8:38 pm    Post subject: Reply with quote
They make the shift forks "snap" into position when you shift:
Dangermouse
PostPosted: Mon Apr 23, 2007 10:03 pm    Post subject: Reply with quote
Aha!
(So, not to hijack the thread or anything, but if one of my detent plugs had been missing for a period of time, is there then a chance that I could also be missing a detent ball and detent spring too? Can't say that I've ever felt the transmission snap into position...)
Anyone know if replacement plugs are available from anywhere?
KTPhil is offline
PostPosted: Tue Apr 24, 2007 7:56 am    Post subject: Reply with quote
I bet a local VW tranny shop has a bunch of them. If you have no local shop, and if you know they are missing and have a tranny number, I can ask at my shop when I pick up my rebuilt unit in about two weeks.
BugCatcher1957
PostPosted: Sun Apr 29, 2007 4:49 am    Post subject: Reply with quote
The weekend is here, and there is nothing like spending a Saturday night bonding with my VWs. I was able to poke around more and I believe my leak is coming from a missing plug protecting the detent ball and spring. All three plugs are missing and it looks like bottom plug is the primary source of the leak. Thanks for everyones counsel in helping me find the problem.
As suggested by Dangermouse, I did my best to plug the holes with silicone. While I did my best to clean the area (which is not easy with the tranny still in the car), time will tell whether the silcone will seal the hole. No spot under the car this morning, but I have not refilled the tranny yet. I spent considerable time searching the site for a discussion on the issue but I didn't find much. I am somewhat suprised others don't have an issue since it OEM plug was just a piece of plastic which seems vunerable after +40 years.
Anyway, I would like to get a permanent fix on the problem. KTPhil, can you keep me in mind when you talk to your transmission guy. Here is Michigan, there are no local VW tranny shops. I, of course, will be happy to reimburse you. If there is an alternative solution, I would welcome everyones input.
Thanks again for your help.
