vanagon front seat removal instructions
ourv12
ourv12 is offline
PostPosted: Thu May 03, 2007 12:17 pm    Post subject: vanagon front seat removal instructions Reply with quote
Whats the best way to explain to a wrecking yard grease monkey how to remove the front seats on a GL model(no swivel base) without them destroying the seats? I myelf have never done it but Im buying some seats from this yard and dont want them to mess them up.
View user's profile Send private message Send e-mail AIM Address Classifieds Feedback
hiram6
hiram6 is offline
PostPosted: Thu May 03, 2007 12:35 pm    Post subject: Reply with quote
Slide forward using the pull-up lever on the side until it encounters the little slide-lock tab. Lift that up to clear, and continue sliding forward. The lock tab may hang up again, it does on my pass. seat. Continue until the set comes off the front of the rails. Anyone with a mechanical mind can figure it out as long as they know there is a locking tab. The tab is visible on the side of the seat rails.
1985 Westy, 1.9L automatic (Daisy)
1996 Mazda Miata
1998 Jeep Grand Cherokee 5.9 Limited
You can't lie around on the beach and drink rum all day.................unless you start first thing in the morning.
ourv12
ourv12 is offline
PostPosted: Thu May 03, 2007 1:24 pm    Post subject: seat removal Reply with quote
Thanks !!!!!!
kayakwesty
kayakwesty is offline
PostPosted: Thu May 03, 2007 1:45 pm    Post subject: Reply with quote
Mention to him, that the locking tab, is tri-angled shaped, and flips up, and then the seat will move forward...just in case he has never removed one before..it might help?
1984 Westy 2.0 Jetta ABA Motor/1.8 head converted to auto tranny, with 180,000 on body, 55K on engine and transmission
B.5.5 Passat Wagen with 30v V6-67000 Miles
DAS AUTO
CHANGE YOUR FUEL LINES!
A post without pictures is useless
http://www.kayakwesty.com
http://www.waldensridgewhitewater.com/
gator70
gator70 is offline
PostPosted: Wed Jan 28, 2009 5:31 pm    Post subject: Reply with quote
Does anyone have pics of the tab and flip up motion?
randywebb
randywebb is offline
PostPosted: Fri Oct 29, 2010 1:08 pm    Post subject: Reply with quote
FWIW for the future searchers:
on the passenger side, the tab is inboard & just in front of the triangular seat support (the hinge gizmo)
looks like the two sides are the same seats & can be swapped
1986 2.1L Westy 2wd Auto Trans.
DAIZEE
DAIZEE is offline
PostPosted: Fri Oct 29, 2010 2:31 pm    Post subject: Reply with quote
Yep Exclamation once you know about that small, inconspicuos piece, its really easy. Even I do it easily Smile
'09 2.5L Jetta 5 cylinder, 5 spd, super turbo, see thread in H2O Cooled Jetta, etc...
84 Vanagon GL Wolfsburg Westy WBX 4 speed (sold)
campism
campism is offline
PostPosted: Sat Oct 30, 2010 9:50 am    Post subject: Reply with quote
Found this in my archives, '87 Westy seat removal:
dhaavers
dhaavers is offline
PostPosted: Tue Jul 24, 2012 10:00 am    Post subject: Reply with quote
WTH - just spent an hour too long looking everywhere under the seat at the tracks, rails, etc. for this sucker...
STICKY, PLEASE?
Thanks, campy!
"The WonderVan"
kamzcab86
kamzcab86 is offline
PostPosted: Tue Jul 24, 2012 10:08 am    Post subject: Reply with quote
dhaavers wrote:
STICKY, PLEASE?
Added to the FAQ (72 Body – Seats).
~Kamz Anxious
2016 Golf GTI S
Merian
Merian is offline
PostPosted: Fri Feb 10, 2017 5:11 pm    Post subject: Re: vanagon front seat removal instructions Reply with quote
Why am I having so much trouble putting the driver's seat back in?
Do I need to pull up on the lever when putting it back in?
seems like the rail on the seat should sit on the front tabs of the seat rail (which are bent down) and then slide back into the rest of the tabs (not bent down) but I just can't get it to slide back into them...
Sad
I'm now on day 2 of this grease wrestling job...
it is really the passenger side seat that I moved over to the driver's side some years ago...
campism
campism is offline
PostPosted: Fri Feb 10, 2017 5:57 pm    Post subject: Re: vanagon front seat removal instructions Reply with quote
Is this in a Westy? If so, you probably have your swivel reversed. The bent-down tabs are at the rear to act as stops; they prevent the seat from sliding too far rearward. Once you align the rails on the seat with the fronts of the tracks the seat should slide rearward pretty easily, with the flats of the rails under the tabs on the tracks, until they get to the back and hit the stops (the bent-down tabs). If you do not have swivels I do not know what the problem is.
Merian
Merian is offline
PostPosted: Fri Feb 10, 2017 7:16 pm    Post subject: Re: vanagon front seat removal instructions Reply with quote
huh! yes, a Westy with swivels - I must have rotated the thing to get better access to the battery box
Thx Exclamation
