Jake Raby Samba Member
Joined: August 23, 2003 Posts: 7437 Location: Aircooled Heaven USA
Posted: Fri May 18, 2007 6:05 am Post subject: 8 week mini-series on cooling systems on 4th Dimension Radio |
Thats right! Beginning with today's show (5/18/07) and spanning for the next 8 weeks the entire 4th Dimension Radio podcast will be on the very myth infested topic of "cooling"...
In these shows we will be going over every aspect related to cooling from myths to testing date, cooling essentials, cooling tips and even detailed information about the cooling system test work that we did here in the lab and on the road.
Here is the tentative schedule for this mini-series on 4th Dimension Radio:
5/18- Cooling essentials for both Type 1 and Type 4 engines. In this show we'll go over the things that must exist before any engine can best utilize it's cooling system.
5/25- Engine temperatures. In this show we'll go over the minimum and maximum acceptable running temperatures for TI and TIV engines as well as the acceptable engine temperature variances between cylinders/ heads. This show will be full of information that is not posted on any website, book or other reference material.
6/1-Cooling fan differences- Radial Vs. Axial.. This show will go over the two different types of cooling fans used and their strengths and weaknesses and why they work better in different applications.This show will basically be "911 Vs. Stock/DTM cooling" more than anything else.
6/8 -Does my larger engine than stock engine have to run hotter than a stocker?? This is a hugely misunderstood topic!! In this show we'll bust the myth as it relates to larger engines running higher temperatures.
6/15-Cooling the Type 4 engine equipped with the "stock" pancake cooling system. In this show we'll go over the way the stock system functions, this show will be geared mostly toward buses and 914s and we'll divide the show down the middle and go over the most critical questions and information concerning both applications.We will cover stock and performance base engines as well.
6/22- Type 4 upright conversion detailed information. In this show we'll go over the function and characteristics of the various Type 4 conversion cooling systems including the DTM, 911 style shrouds and the Cali conversion.
6/29-Cooling the Type 1 engine. The Type 1 engine is the target of many aftermarket solutions aimed at providing better cooling for the engine. Find out why most of these don't work as well as stock! We'll be going over our cooling system evaluations and their results in this show as well as covering the things that must exist for any cooling system to be effective on the Type 1 engine.
6/29- The Aircooled Technology DTM cooling system. This show will go over the Type 1 and Type 4 DTM, it's entire history, it's development and how the DTM has proven to be the best cooling system solution available. This show will cover the Type 1 and Type 4 shrouds universally.
These shows are a must listen!! Even if you don't typically listen to our Radio Shows make sure to listen to this mini-series!! _________________ Jake Raby
Raby Engine Development
www.rabyenginedevelopment.com
"I've never given anyone Hell, I just told them the truth and they thought it was Hell" |
gerg a.k.a. 6volt65
Joined: April 25, 2003 Posts: 5454 Location: Monroe, LA
Posted: Fri May 18, 2007 6:37 am Post subject: |
Sounds good Jake.
Can you FF to 6/29? LOL  _________________ Gerg
. . . I got 99 problems and my bus ain't one . . .
'65 Sunroof Beetle
'65 Vert
'60 Singlecab |
vwdmc16 Samba Member
Joined: January 12, 2006 Posts: 1734 Location: sacramento, CA
Street Bug 29 Samba Member
Posted: Fri May 18, 2007 2:25 pm Post subject: |
| I want to do the type 4 convertion to my shroud,, |
Posted: Fri May 18, 2007 3:00 pm Post subject: |
| Street Bug 29 wrote: |
After you hear my info on that mod you might change your mind...
This is the only series we'll be doing thats this in depth, the others are a max of two shows in duration.. _________________ Jake Raby
Droolman Samba Member
Posted: Fri May 18, 2007 3:26 pm Post subject: |
Was I wrong in the fact that ART took you out of the race a few weeks ago using EMPI products including fanshroud? You doing a piece on that. _________________ 1967 blue bug
1965 drag bug |
One Owner Samba Member
Joined: August 09, 2005 Posts: 247 Location: Nahville,TN
Posted: Sun May 20, 2007 12:03 pm Post subject: |
| Droolman wrote: |
| Was I wrong in the fact that ART took you out of the race a few weeks ago using EMPI products including fanshroud? You doing a piece on that. |
We didn't have any temperature issues... Clutches and bent valves are what took us out
BTW- We were not racing any other car, not Art and not the Chevelle that was in the episode, we were being challenged by the host of the show and were not lined up against any other car when we lost the competition....
Art did kick some serious ass in the challenge, I'll be the first to admit that. He and his crew did a great job! _________________ Jake Raby
redhot Samba Member
Posted: Sun May 20, 2007 1:02 pm Post subject: |
Jake: where can I find some of your old shows?
I think there was one on carbs, but couldnt find it when I followd the link on your webpage. |
Posted: Sun May 20, 2007 1:50 pm Post subject: |
We pull and archive them every so often.. They will all be available for sale (at a very good price) through my store soon... Maybe in just a couple of weeks they'll be available.
Someone may have saved the show you need and I certainly don't care if you guys share them amongst yourselves.. _________________ Jake Raby
redhot Samba Member
Posted: Mon May 21, 2007 2:03 pm Post subject: |
Thank you for a great effort in enlightening me and probably a lot of others!
Well: if anyone have them, please PM me  |
synapticburn Samba Member
Joined: August 23, 2004 Posts: 51 Location: Houston, tx
Posted: Sat May 26, 2007 10:45 am Post subject: |
Loving the 4th dimension show. I listened to the first episode on cooling as I was replacing a huge steam to air heat exchanger at work, and it's nice to hear someone discuss the concepts and science behind a lot of this stuff.
I can only get the last 6 shows to download, and couldn't find any on the site yet. There are compaines that will create and distribute the cd's for you, I know of another podcast that does just that and the price is very reasonable. PM me and I can pass along the info if you need it. _________________ Ronnie
'66 bug, 2275cc slowpoke (no name yet)
'98 GMC sierra (grandpa truck)
'05 Vstrom |
Posted: Tue May 29, 2007 2:31 pm Post subject: |
Yep! This one is another good one! _________________ Jake Raby
Posted: Tue Jun 05, 2007 10:23 am Post subject: |
Gotta hear this one!! I go over a lot of the 911 cooling shortcomings! _________________ Jake Raby
BugUser Samba Member
Joined: March 02, 2007 Posts: 29 Location: Stuttgart/Germany
Posted: Mon Jun 11, 2007 2:49 am Post subject: |
| One Owner wrote: |
The 4th Part is available
-Ray |
Somehow, all archived IVth Dimension Radio broadcasts on www.richchristensen.com seem to be broken?!? |
WideFive SBS Hit Squad
Joined: August 20, 2002 Posts: 1147 Location: Litchfield, Ohio
