James Dwan Samba Member
Posted: Wed Jun 20, 2007 7:51 am Post subject: Body replacement procedure? |
I have finished the chassis work and am ready to put the body back on. I have never done thios so any pointers and suggestions would be greatly appreciated!
Basically I am wondering about lining up the holes for the body bolts and the seal.
Should I pre-cut the holes in the seal and glue it to the outer rim of the pan?
I'll be underneath while they are lowering it to see if they line up
The PO didn't put it on right, holes not aligned and used caulk instead of a seal, so I took it off and noticed a bunch of rust issues and just got done with the POR-15
Looking to do this in 3 days from now  _________________ DAC
TCB
'59 23 Window Deluxe
'73/'77 Westfakia
'78 SuperVert
"Many dreams come true, and some have silver linings.
I live for my dreams and a pocket full of gold. Acapulco gold!" Robert Plant |
Rome Samba Member
Joined: June 02, 2004 Posts: 10774 Location: Pearl River, NY
Posted: Wed Jun 20, 2007 8:39 am Post subject: |
It's been almost 15 yrs since I remounted a body to a pan. I would recommend gluing the perimeter seal onto the pan beforehand. For the mounting bolt holes, just make "X" slits so that the bolt can slide thru and shape the hole as needed.
Remove the shift lever, engine and seats from the pan so that the body does not have to be lifted up so high. Remember to use the thick rubber spacers between the body, at the 2 front axle mounts and at each mount in the rear wheelwells. |
Posted: Wed Jun 20, 2007 12:53 pm Post subject: |
Thanks! _________________ DAC
TCB
'73/'77 Westfakia
'78 SuperVert
tspot100 Samba Member
Posted: Wed Jun 20, 2007 4:35 pm Post subject: body install |
| I got a great tip from someone on thesamba about keeping the belly gasket in place as the body is fitted. Some pop rivet, some glue... The suggestion I used was to use fishing line . Weave it up and down the pan holes to hold the gasket in place , then either leave it, or cut it and pull it out. |
SandSquid Samba Member
Posted: Wed Jun 20, 2007 5:13 pm Post subject: Re: body install |
| tspot100 wrote: |
what about rubber cement, you know.. the stuff we used to sniff back in first grade  _________________ --
V/R
SandSquid
1974 Super Beetle, ("Put-Putt")
1971 Super Beetle Convertable (a bare shell.)
1987 Volvo 745Ti 835k Mi. "Grouchy"
1988 Volvo 764Ti 380k Mi. "Speedy"
1988 Volvo 765Ti 160k Mi. "Road Trip!!!" |
conrad1468 Samba Member
Joined: December 20, 2003 Posts: 1019 Location: Jeannette, PA 15644
Posted: Thu Jun 21, 2007 5:59 am Post subject: |
what i did for my body to pan was... i didn;t want to use any glue so i put poked the hole in the seal for the bolts then i put the seal on the floor pan and put the bolts up thru the pan seal about half way then i lowered the body on the seal and the bolts were already there and then i just worked on each bolt a little bit at a time and once they were all started into the body i cranked them all down...
check out my gallery for the resto pics... good luck _________________ Fresh Air VW Car Club
New Pittsburgh, PA Car Club. 100% free!!!
club website link
http://groups.yahoo.com/neo/groups/FreshAirVWCarClub/info
thesamba link
http://www.thesamba.com/vw/forum/viewtopic.php?t=363031
Official website
http://www.freshaircarclub.com/
Look us up on Facebook, too |
Posted: Thu Jun 21, 2007 7:59 am Post subject: |
Excellent ideas! I'll cut the cross for each bolt hole to hold the bolt in place and lower the body on to it. I have some fishing line just in case.
Thanks again and if anyone is in the Dallas area Sat feel free to stop by for burgers and beer  _________________ DAC
TCB
'73/'77 Westfakia
'78 SuperVert
Posted: Mon Jun 25, 2007 6:50 am Post subject: |
Well the body replacement was a success. I laid the seal down and cut out a triangle on the inside of each corner to make the curve and stabbed a hole through each bolt hole. Then put the body bolt through it from underneath and it held the seal in place. We then lined up the rear two bolts and the front bolts. From then on it was easy! _________________ DAC
TCB
'73/'77 Westfakia
'78 SuperVert
trn Samba Member
Joined: June 13, 2008 Posts: 25 Location: Los Angeles
Posted: Tue Aug 19, 2008 1:28 pm Post subject: |
| James Dwan wrote: |
| Well the body replacement was a success. I laid the seal down and cut out a triangle on the inside of each corner to make the curve and stabbed a hole through each bolt hole. Then put the body bolt through it from underneath and it held the seal in place. We then lined up the rear two bolts and the front bolts. From then on it was easy! |
I'm replacing the body in the next week or so. This thread has helped with my questions, but I'm still wondering one thing: what is the detail where the two loose ends of the seal come together? Do you just overlap one end over the other? _________________ 1971 Bug in restoration: http://vw-restoration.blogspot.com |
trn Samba Member
Posted: Wed Aug 20, 2008 8:37 pm Post subject: |
| conrad1468 wrote: |
| good luck.. it's awesome when the body is back on... |
Thanks. I'm looking forward to it. All I intended on doing was replacing the seal because it was leaking, and I ended up in three months of project creep. It WILL be nice to have the body back on. _________________ 1971 Bug in restoration: http://vw-restoration.blogspot.com |
