W125 vs. FK8
dubkrzy
dubkrzy is offline
PostPosted: Tue Jul 17, 2007 7:12 pm    Post subject: W125 vs. FK8 Reply with quote
I would like to get feedback on which cam to use on my new engine.
I'm building a 2275 with Tims stage 2 heads and 44 IDF's.
I don't have the rockers yet, so I can go with 1.1's, 1.25's, or 1.4's.
Compression ratio will be 8.5:1
It will go on a street driven 66 full bodied bug Very Happy .
Also, any idea on which clutch and pressure plate to use would be helpful.
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Tue Jul 17, 2007 7:15 pm    Post subject: Reply with quote
I have a 2180 with a FK8 and love it. Easy to drive at low rpm and has tons of torque and revs real quick.
I also have a set of Steve Tims Stage 2 heads. Carbs are 48 IDAs.
Clutch is a KEP Stage 1 with ACE Copperhead disc.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
dubkrzy
dubkrzy is offline
PostPosted: Tue Jul 17, 2007 7:18 pm    Post subject: Reply with quote
Glenn,
What cam did you have on your other motor?
Mr. 010
Glenn is offline
Scat C-35
My current is the best combo i've driven in a street car. Smooth enough for every day and plenty of power when you need it.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
dubkrzy
dubkrzy is offline
PostPosted: Tue Jul 17, 2007 7:22 pm    Post subject: Reply with quote
Does the 125 cause more wear on the valve train?
And what about clearance issues as far as the pushrod tubes.
And by the way did you looki into any of the web-cams.
Mr. 010
Glenn is offline
PostPosted: Tue Jul 17, 2007 7:23 pm    Post subject: Reply with quote
After speaking to a number of people, the K8 seemed thje best choice for what I wanted.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
dubkrzy
dubkrzy is offline
PostPosted: Tue Jul 17, 2007 7:28 pm    Post subject: Reply with quote
Alright, sounds good to me.
The reason I picked those two cams to choose from was because Greg Tims suggested one or the other for my combo. He didn't seem to have a preference on way or the other. So the only other question is what rockers are you using.
vwracerdave
vwracerdave is offline
PostPosted: Wed Jul 18, 2007 6:38 am    Post subject: Reply with quote
I would choose the FK8 and 1.4 rockers over a W125. More expensive and more work setting it up, but less overall wear on the valve train. You need to use the JayCee pushrod tubes.
Stage I with a Daikin Super disc.
Mr. 010
Glenn is offline
PostPosted: Wed Jul 18, 2007 6:46 am    Post subject: Reply with quote
I'm using CB rockers.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
turboblue
turboblue is offline
PostPosted: Wed Jul 18, 2007 7:40 am    Post subject: Reply with quote
There is a slight difference between a FK8 and a K8.
FK8 is an Engle cam
.382 lift at the cam with 298 advertised duration.
K8 is a CB cam. They use part #2288.
.378 lift at the cam with 308 advertised duration.
Gary
Turbo VW Sand Drag Buggy
"If you don't run into the Devil every once in awhile, you must be going in the same direction!"
Mr. 010
Glenn is offline
PostPosted: Wed Jul 18, 2007 8:28 am    Post subject: Reply with quote
FK8 is an Engle cam
I missed the F and misspelled "thje"
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
tkelley
tkelley is offline
PostPosted: Wed Jul 18, 2007 8:40 am    Post subject: Reply with quote
He wants only 8.5 compression, will the fk8
work well with that compression? Just asking.
Tom
turboblue
PostPosted: Wed Jul 18, 2007 9:02 am    Post subject: Reply with quote
Glenn wrote:
FK8 is an Engle cam
I see.
No harm, no foul....... Smile
Gary
67Beetle2017
67Beetle2017 is offline
PostPosted: Wed Jul 18, 2007 10:03 am    Post subject: Reply with quote
Tom
I have used the Norris 355S w/1.4s with 8:1. This was in my 67 bug. The power was good but I was looking for more response down low and in the mid.
Same engine with only a compression change.
When, compared to my other engine combo 10.5:1 w/Norris 355S w/1.4's(very similar to the FK-Cool vs 355S w/1.4s and 8:1 the power and snappy response was night and day. (both engines used 44IDF's at one point). Power was stronger through the whole powerband.
Cam change:
I used the Norris 407S w/1.25's (very similar to Engle W125) in 8:1 configuration with good results. I noticed the 407S pulled harder in the bottom to midrange where the FK-8 pulled more in the mid top end.
10.5:1 configuration w the 407S produced very good midrange. The engine was great for being help at a constant rpm then stabbing the gas and go. I felt at the time the 407S produced a better overall powerband for my combo.
NOTE: I was using stock gear ratios. the 407S recovered better between gear changes than the 355S.
Moved engine to my bus to make was for my Berg clone 2110 w/FK-8:
Note 10.5:1 with the 407S produced pinging in the bus that was not present in the bug, so I opted to lower the compression to 8:1.
The engine I was using was a 78X90.5. This was the only engine I had at the time that had both 8:1 and 10.5:1 (with same heads) and both 407S and 355S cams. For the 8:1 configuration in the bus I stayed with the 407S w/1.25's.
Sorry not an actual 2275 or Engle FK-8 or W125 but that is the closet actual experience I had resembling a back to back comparison. all done in a period from (1982-87)
I have used the actual FK-8 in my Berg 2110 (1992) clone engine (10.5:1) and the power was like Glenn said.."Easy to drive at low rpm and has tons of torque and revs real quick." I was using a Berg5 with that combo.
In my experience, the FK-8 likes to see a slightly higher compression.
If you are you using stock gear ratios?
IMHO I would choose the W125 w/1.25's with an 8.5:1 engine.
Hope this helps.
Tkisner
Tkisner is offline
PostPosted: Wed Jul 18, 2007 11:42 am    Post subject: Re: W125 vs. FK8 Reply with quote
You shouldn't just choose a compression ratio you want to run on a motor. You should match it to the octane you intend to run what camshaft the motor has etc. etc.
tkelley
tkelley is offline
PostPosted: Wed Jul 18, 2007 11:51 am    Post subject: Reply with quote
Thats what I was thinking Tkisner, also 8.5 compression
on a w125 seemed off. I know a w120 loves 9.0.
I haven't used an fk8, so I wasn't sure.
Tom
dubkrzy
dubkrzy is offline
PostPosted: Wed Jul 18, 2007 6:34 pm    Post subject: Reply with quote
Thanks guys,
After reading the responses, i guess i am not sure if greg recomended K8, or FK8.
So with 8.5:1 compression (so I can use 87 octane gas), which cam would run better.
I want it to idle nice and have crisp throttle response.
right now i have a stock gearbox, but I am replacing it with a tranny from Rancho that has a 3.88:1 R&P.
rterfert
rterfert is offline
PostPosted: Wed Jul 18, 2007 6:52 pm    Post subject: Reply with quote
Have you looked into the
Engle Fk-10
Makes A Lot Of Power....Same basic lift with more duration.
The Fk-10 is .385" Lift At The Cam and 310 Degrees of Duration
With 1.4:1 rockers You Get A .539" Lift At The Valve.
The Fk-8 is .382" Lift At The Cam and 298 Degrees of Duration.
Both are Designed For Use With 1.4:1 Rockers,
I was going to use the engle Fk-10 in my 2275cc VW and am now going water cooled.
dubkrzy
dubkrzy is offline
PostPosted: Wed Jul 18, 2007 7:00 pm    Post subject: Reply with quote
Actually, I have a brand new Engle w-130 in the box.
Would it be too much cam for my combo?
Lag_Smurf
Lag_Smurf is offline
PostPosted: Wed Jul 18, 2007 7:02 pm    Post subject: Reply with quote
Glenn wrote:
Clutch is a KEP Stage 12 with ACE Copperhead disc.
I am building little motor myself. Also using Steve Tims stage 2 heads and 48 IDA's with an FK8. I talk to Greg Tims and told him my combo and 9:1 C/R. The side he would go 8.5:1 over 9:1. Also plan on 1.4 rocker arms.
Would like to know more about this KEP Stage 12 sounds a little to much. LOL
I like KEP Stage 1. It is all about being 1st. lol
WWW.VOLKSTALK.COM www.reliablevdub.com/ www.tvwdra.org Steve Tims Heads www.qualitatvw.com www.speedshots.net
www.tvwdra.org/sponsors/lyle_cherry.htm www.tvwdra.org/sponsors/images/b_quick_racing.gif
