61 door recess question (Greg, Clara, Lind?)
rizzag
Now Wut?
rizzag is offline
PostPosted: Tue Jul 31, 2007 7:09 am    Post subject: 61 door recess question (Greg, Clara, Lind?) Reply with quote
Hey,
A friend of mine is working his 61 walk-thru camper and noticed that one of his front doors is recessed for the door handle and one is flat. I know this is a change somewhere in the 61 run and knowing VW his bus may even have come out of the factory that way! Does anyone know a month or vin number of this change? Maybe it changed when hinges went low?
Thanks,
Jeff
flossin, tossin, dippin, and trippin
Lind
Lind is offline
PostPosted: Tue Jul 31, 2007 8:03 am    Post subject: Re: 61 door recess question (Greg, Clara, Lind?) Reply with quote
rizzag wrote:
Hey,
Thanks,
Jeff
Gabe's bus takes the non-recessed doors. that bus is an august '60 bus, the change in the doors was a few months later.
one thing to keep an eye on is the location of the drain hole in the door versus the dogleg. the late '60/early '61 door has the later drain hole location. (not that it really matters all that much. most people don't even know this difference)
Wanted:
Clara Premium Member
Clara is offline
PostPosted: Tue Jul 31, 2007 8:18 am    Post subject: Re: 61 door recess question (Greg, Clara, Lind?) Reply with quote
The cab door handle recess changed at the same time they went from high hinge cargo doors to low hinge.
rizzag
Now Wut?
rizzag is offline
PostPosted: Tue Jul 31, 2007 8:53 am    Post subject: Reply with quote
Thanks you two, I will pass along the info.
Jeff
BUCIOBATISTI
BUCIOBATISTI is offline
PostPosted: Tue Jul 31, 2007 10:14 am    Post subject: Re: 61 door recess question (Greg, Clara, Lind?) Reply with quote
I AM as good as I thought. That's exactly what I told Jeff in a PM last night but I wasn't positive so I told him to ask you guys to make sure. I guess I shouldn't have doubted myself...
Please check us out on Instagram at @holygrailgarage
That's the best place to see the latest things we are up to as well as catch an occasional sneak peek of our latest car and parts listings!
rizzag
Now Wut?
rizzag is offline
PostPosted: Tue Jul 31, 2007 12:11 pm    Post subject: Re: 61 door recess question (Greg, Clara, Lind?) Reply with quote
Indeed!
