dash lights
Page: 1, 2, 3, 4  Next
68nofussbus
68nofussbus is offline
PostPosted: Sat Sep 01, 2007 3:16 pm    Post subject: dash lights Reply with quote
does anyone know the part number for the light bulbs in the high beam,oil, gen,parking lights in the dash ? been to two stores and no luck, even showed them the size of bulb and they look in a book and try to give me a bulb thats 2 times the size of original- one guy even said that someone changed the bulb sockets- I dont think so . thanks-
vwjw
vwjw is offline
PostPosted: Sat Sep 01, 2007 3:22 pm    Post subject: Reply with quote
Try Sylvania 2723. A bit brighter then the originals but same physical size.
Dead 1
Dead 1 is offline
PostPosted: Sat Sep 01, 2007 8:56 pm    Post subject: Re: dash lights Reply with quote
go to ratwell's site
"I reject your reality and replace it with my own"
"The American Dream - true enough because you gotta be asleep to believe it"
71, 1776 cc.
EZ Gruv
King of Plaid
EZ Gruv is offline
PostPosted: Sun Sep 02, 2007 10:11 am    Post subject: Reply with quote
Go to Pep Boys and get the 2723s. Immensly brighter.
Before:
After:
Eric
1977 Deluxe Westfalia - 2.0L FI Type IV, Completely Original
Photographer for HotVWs, VolksWorld, AirMighty, VW Camper & Commercial, Hayburner, and more.
My Photography Page.
busfreak_71
Flat 4 Junkie
busfreak_71 is offline
PostPosted: Sun Sep 02, 2007 10:26 am    Post subject: Reply with quote
I had the same problem trying to find those bulbs, thesamba has saved me again. Very Happy Cool
'71 Tin Top Westfalia
'99.5 Bora TDI
'85 Jetta Coupe
'85 Mercedes 300SD
Resident Off-Grid hippie and diesel advocate.
rhinoman1947
rhinoman1947 is offline
PostPosted: Sun Sep 02, 2007 12:39 pm    Post subject: Reply with quote
Do the 2723's fit into the same wedge base sockets that the original lights were in?
EZ Gruv
King of Plaid
EZ Gruv is offline
PostPosted: Sun Sep 02, 2007 12:41 pm    Post subject: Reply with quote
Yes.
Eric
david_594
david_594 is offline
PostPosted: Sun Sep 02, 2007 1:39 pm    Post subject: Reply with quote
And 2721 is the proper 1.2 watt bulb for those who like things original(or just dont want 1 overly bright bulb).
1968 westy weekender
2000 jetta tdi
79 vespa p200e
EZ Gruv
King of Plaid
EZ Gruv is offline
PostPosted: Sun Sep 02, 2007 2:42 pm    Post subject: Reply with quote
There are 2 bulbs - 3 if you have a clock.
Eric
Monkeyknuckles
Monkeyknuckles is offline
PostPosted: Mon Sep 03, 2007 8:11 am    Post subject: Reply with quote
Has anybody tried the colored plastic covers that slide over the lightbulbs to change their color? I've seen them somewhere.
Nice green or blue lights in the dash. Smile
mygreenbus
mygreenbus is offline
PostPosted: Mon Sep 03, 2007 2:14 pm    Post subject: Reply with quote
I put the 2723s in our dimly lit dash and it is great! Might even tan while I drive!
dweller
dweller is offline
PostPosted: Mon Sep 03, 2007 8:20 pm    Post subject: Reply with quote
ahh, another thread to bookmark... building quite a library i am, saving on pen and paper notes that i usually lose anyway.
thanks for the bulb info.
dp
Olde Volks Place
Olde Volks Place is offline
PostPosted: Thu Sep 06, 2007 4:26 am    Post subject: Reply with quote
FYI it is only the BULB that you will change and NOT the plastic housing.
I searched and searched for the bulb/housing combo only to find out that I only needed to change the bulb. Very Happy
NAPA has them in stock.
68nofussbus
PostPosted: Thu Sep 06, 2007 7:17 am    Post subject: Reply with quote
went with the2723 bulbs to brighten up the bus, what sucks is when I put the new bulb in for the brake warning light - it barely lights up and the alt/gen light is really dim too checked the wire diagram and will be tracing wires today , try to fix one thing and screw up three . i love my bus even though it sometimes kicks my ars. oh yeah I put the old bulb back in and the same thing happens
drozdenko
drozdenko is offline
PostPosted: Thu Sep 06, 2007 12:54 pm    Post subject: Reply with quote
not to hijack a thread but in the process of putting new ones last week, I also checked my the female terminals on the back of the instrument panel.
i found a bunch of loose ones which then lead me to the fuse panel where i also found more. about 12 recrimps later my dash lights are nice and bright as well as my gas gauge works now.
you never know what you might find poking around.
'79 Westy 2.0L "Hiltrude"
‘74 Super Beetle Rallye Yellow
'00 Jetta TDI
'01 WE Jetta 1.8T (Sold)
'02 Passat GLS 1.8T (Sold)
'96 Jetta Trek (Sold)
'88 Gti-16V (Sold)
robmcd
robmcd is offline
PostPosted: Sat Sep 15, 2007 10:25 am    Post subject: dash lights Reply with quote
So the question for me is how in the heck do you get back there to change the dash light bulb or do you go thru the front, or should I just sell the bus?
busfreak_71
Flat 4 Junkie
PostPosted: Sat Sep 15, 2007 11:15 am    Post subject: Re: dash lights Reply with quote
You could go from under the dash to change them or you could remove the whole cluster by removing the red and blue air vent "knobs" (just the plastic bits) and the 4 screws that hold the cluster in place. Then ya gotta futz with it to get get the vent control arms through the gap in the plastic so you can get the cluster out. I hope all this makes sence Laughing
Dont sell the bus Exclamation
'99.5 Bora TDI
'85 Jetta Coupe
'85 Mercedes 300SD
Chris Vellat
Chris Vellat is offline
PostPosted: Mon Sep 17, 2007 9:55 pm    Post subject: Reply with quote
Don't forget the speedo cable...
fusername
fusername is offline
PostPosted: Tue Sep 18, 2007 5:42 am    Post subject: Reply with quote
or in my case onoly two screws, as the plastic snapped around the heater levers.... sure makes it easier, i reccomend the mod to you! Rolling Eyes
[email protected]
Need something custom bent up? shoot me an email, maybe we can make it work!
FORSALE: Thrust cut T4 and 1.9 main bearings
obnoxiousblue wrote:
Maybe Ben Pon's ghost comes and vomits NOS stampings for your bus, but not mine!
Malokin Martin
Malokin Martin is offline
PostPosted: Tue Sep 18, 2007 5:43 am    Post subject: Reply with quote
I don't know. I kind of like the old yellowish light. A bright blazing white light just doesn't seem right somehow...
Page 1 of 4
