junkyardherbie Samba Stumbling Drunk
Joined: October 29, 2005 Posts: 91 Location: wherever i was when i fell down last
Posted: Wed Oct 10, 2007 5:49 pm Post subject: repro BRM clearcoat peeling? UPDATED results- |
has anyone else had problems with the clearcoat on the reproduction BRM's peeling/ flaking off? does anyone know of a good way to remove the clearcoat completely without damaging the wheels?
thanks!
JYH _________________ if i agreed with you, then we'd both be wrong
'65 Sea Blau Beetle
i used to drink alot. i still do, but i used to, too.
Last edited by junkyardherbie on Tue Mar 25, 2008 5:41 am; edited 2 times in total |
ratlookvw Samba Member
Joined: June 21, 2004 Posts: 1809 Location: midnight train to GA
Posted: Wed Oct 10, 2007 7:35 pm Post subject: peeling |
I think yours are peeling because your dog uses it for a toliet _________________ If the RV Hut is a rockin, don't come a knockn'
57 Panel, 66 highroof panel, 65 Notch, 59 Vert, 61 Vert, 1969 Fridolin, 'Reggie ' 66 RV, 65 Pipe Truck, 65 RHD T-34, 70 dbl slider panel, 1969 Deep sea green sunroof automatic square, the greypoop-on, and a shit load of wheels! |
KILLERWATT Samba Member
Joined: November 18, 2003 Posts: 3298 Location: Vero Beach
Posted: Wed Oct 10, 2007 7:38 pm Post subject: |
Oven cleaner will take it off, but it could go into the paint if you're not careful. |
Posted: Wed Oct 10, 2007 9:08 pm Post subject: Re: peeling |
ratlookvw wrote: |
I think yours are peeling because your dog uses it for a toliet |
^very insightful homie! I've got an idea.... i'll feed the damn dog the oven cleaner and let him go do the dirty work for me!
(thanks for the info, Al... i'm repainting them anyway so ill give that a try. just didn't want to hurt the polished parts!) _________________ if i agreed with you, then we'd both be wrong
'65 Sea Blau Beetle
i used to drink alot. i still do, but i used to, too. |
Posted: Thu Oct 11, 2007 5:19 am Post subject: Re: peeling |
junkyardherbie wrote: |
ratlookvw wrote: |
(thanks for the info, Al... i'm repainting them anyway so ill give that a try. just didn't want to hurt the polished parts!) |
If they're anodized the oven cleaner will strip that also off the aluminum. But you will be able to repolish the aluminum afterwards. |
sweetlokin66 Samba Member
Joined: November 15, 2006 Posts: 1220 Location: Luftwagenville, FLDuh
Posted: Mon Mar 24, 2008 7:04 pm Post subject: |
it took a while but I finally got around to stripping the BRM's. sweetlookin66 was right about what to use...
here are the results-
before...
PLUS THIS...
WAIT FOR IT.......
the next step....
the end result-
figure about 3 cans of stripper for 4 wheels ($7-8 bucks ea.) and about 30 min. per wheel. did I get wet (pressure washer)? YES. and the shit burns if you get it on you, but you'll live.
the problem areas- the paint doesn't like to come out of the lug holes, so you'll have to spend a little extra time in that area.
all in all great results without a lot of work. hope this helps someone....
advice: mask well, follow the directions on the can, and DON'T leave it on longer than the directions recommend. _________________ if i agreed with you, then we'd both be wrong
'65 Sea Blau Beetle
Keith Samba Member
Joined: August 15, 2005 Posts: 3634 Location: Brodheadsville, PA
Posted: Tue Mar 25, 2008 6:26 am Post subject: |
Damn!, I like the stripped look . I'd run 'em like that! |
Posted: Tue Mar 25, 2008 7:44 am Post subject: |
ovalteen wrote: |
I'm going to.
I had planned on painting them silver, now I don't have to! _________________ if i agreed with you, then we'd both be wrong
'65 Sea Blau Beetle
Last edited by junkyardherbie on Thu Mar 27, 2008 6:22 pm; edited 1 time in total |
Posted: Thu Mar 27, 2008 6:21 pm Post subject: |
okay i changed my mind. i painted them silver anyway. here are the results...
'65 Sea Blau Beetle
2true Samba Member
Posted: Thu Mar 27, 2008 6:42 pm Post subject: |
Looks nice both ways. |
MODIFIER Samba Member
Joined: December 09, 2006 Posts: 1560 Location: Summerville SC
Posted: Sat Mar 29, 2008 6:25 pm Post subject: |
looks like mine,
_________________ Happyasshell
USC USMC DAD OORAH!
ASE MASTER TECH BODY/PAINT and MECHANICAL
62 Beetle
63 Vert
64 Beetle
https://www.facebook.com/SmartFarmServices |
