46split Samba Member
Posted: Sat Oct 13, 2007 6:17 am Post subject: strato silver paint code ppg |
Does any one have the paint codes for strato silver in PPG ? |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32660 Location: Reading Pennsylvania
Posted: Mon Oct 15, 2007 12:20 pm Post subject: paint code |
Strato Silver 1954 - 1956
Paint code PPG / Ditzler
L227 31550
Just had to look in Samba technical / paint colors
Not everyone knows about the wealth of information that is online !
Dave |
Posted: Mon Oct 15, 2007 3:19 pm Post subject: |
Thanks so much i have tried to search but had no luck. awsome I'll post pics of before and after |
65Westy Samba Member
Joined: February 15, 2005 Posts: 219 Location: Central Ohio
Posted: Tue Oct 16, 2007 2:45 pm Post subject: |
When I was searching for the formula for Strato Silver, I took that PPG code to the paint store and they told me those numbers didn't mean a thing to them. I located a Glasurit dealer but when I found out the cost was over $600 per gallon I decided to go another route. The local NAPA store was able to match the paint from the glove box door with their computer. I think it turned out ok. Strato Silver tends to look different under various lighting conditions.
_________________ Craig
63 Beetle
72 Schnepp XL13 Vintage Formula Vee
72 Caldwell D13 Vintage Formula Vee
71 Super Beetle convertible |
gimmesomeshelter Samba Member
Joined: May 08, 2004 Posts: 1466 Location: San Carlos, CA
Posted: Tue Oct 16, 2007 3:21 pm Post subject: |
Hello-
How much does the actual cost of paint vary anyway?
Is cost a good indicator of quality?
Thanks,
Paul _________________ "I would rather have questions that can't be answered than answers that can't be questioned."
Richard Feynman |
thebucket Samba Stockbroker
Joined: April 06, 2004 Posts: 3734 Location: Houston Texas
Posted: Tue Oct 16, 2007 4:33 pm Post subject: |
63bug wrote: |
I'd step up and pay the 600. With reducer a gallon goes a long way.... _________________ ITMC-El Presidente
OG 55 bullet 3 fold....
http://www.thesamba.com/vw/forum/viewtopic.php?t=150858&highlight=thebuckets++++fold |
Posted: Tue Oct 16, 2007 4:51 pm Post subject: paint |
Hi again,
Keep looking, the paint is available. Most likely it will not be the newer base coat clear coat system but the old Single Stage, mix in the hardener type paint. I KNOW that is available.
I can get it locally without any problem here in NJ (and everybody thinks California is the place to be!!)
Many stores when they hear 1957 panic and write you off with very little effort put forth to help you. Heck, the larger percentage of the us population weren't yet alive in 1957!
Find a helpful auto paint store and give them your business!
If you cannot find it let me know, I'll verify that I can get it and give you details.
Typically a quart of Single stage with hardener and thinner will set you back about $ 100 Gallons typically cost less than 4 quarts.
Is it possible this paint has been outlawed in California with all of their emission laws on paint products???
Dave |
Posted: Tue Oct 16, 2007 7:26 pm Post subject: |
Hello again
We will be using base coat clear coat so im going to see if we can get them to match the ppg codes? If not i may use the glasuret for $600.00 a gallon I'll let you guys know
karl |
Posted: Fri Oct 19, 2007 1:29 am Post subject: paint |
Good Morning
OK people, these people have what you want at a reasonable price. They will ship to you.
Pick your color
pick your paint type preferences
Order
http://www.tcpglobal.com/autocolorlibrary/
Hope it works for you
Dave |
Kombi Samba Member
Joined: August 02, 2002 Posts: 562 Location: Edmonton, AB, Canada
Posted: Sat Oct 20, 2007 1:25 pm Post subject: |
46split wrote: |
Hello again
karl |
L227 is the VW code, you can use that code for dupont/Standox/PPG/Sikkens/RM/Glasurit etc...
What you must keep in mind is that every year literally thousands of formulas are added. Paint technology is changing and many older formulas contained led and or other products that are no longer used. So having someone spend days getting a color formula for a 50's beetle became somewhat low on the list of priorities.
L227 is still a valid code your best bet is a jobber that sells Glassurit/RM,
couldn't find it with sikkens, and Dupont doesn't have a formula for L227 unless you want to switch to waterborne. _________________ Air and Water are needed to survive,
you just can't live as long without air!
Air Riders, VW Club |
Kombi Samba Member
Posted: Fri Oct 26, 2007 11:18 am Post subject: |
Update
RM paint - L227 available in Diamont (Base Clear)
and Glasurit Line 55
Painting the exterior you'd need about 2.5 quarts of either paint.
So complete inside and jambs you'd be best to get yourself a full gallon and be safe. my 2 cents
Cheers! _________________ Air and Water are needed to survive,
VWwerks Samba Member
Joined: March 07, 2002 Posts: 207 Location: Wisconsin
Posted: Fri Oct 26, 2007 12:41 pm Post subject: |
PPG has the code for it, have a dealer call the PPG paint library. I had some strato silver mixed in their Omni line and it is cheap, $30 a quart for MBC base coat. I use Dupont Nason clear over it and it works perfect for an economical paint job. |
Posted: Sat Oct 27, 2007 10:14 am Post subject: |
thank you all for your responces. I had a hell of a week but i have found an exact match from BASF( BASF codes do not drop off like paint shops if they do not sell the color for a long period of time)which has the ability to cross refrence ppg and Sherwin-williams auto paint This link will cross refrence the L227 or the 31550 ppg code.
http://www.sherwin-automotive.com/formula/car_finder.cfm
I think all in for paint clear coat etc under 350.00.
i recieved a sample today and it looks like some of the strato silver cars on the samba, but it seems darker than others ( and has a very very slight green tint to it with silver) but definetly has blue in it. Hopefully when done it will look awsome. I'll send pics
Again thanks
karl |
Kombi Samba Member
Posted: Sat Oct 27, 2007 11:10 am Post subject: |
46split wrote: |
Again thanks
karl |
There are several reasons a color will look different.
The camera the picture was taken with, film/digital, the way the pictures were processed, the angle the light was shinning on the car etc..
Even the same paint same manufacturer can look different just depending on how it is sprayed.
If your painter holds the gun closer to the job, slows down his spray speed, drops the air pressure to the gun or even if the shop is colder the color will be darker.
The wetter the paint is put on the more likely the metallic (silver will drop to the back (reflecting less light) making it appear darker(bluer)
If your after a lighter color do all or some of the opposite.
It will look good a long as painting conditions are consistent.
Cheers _________________ Air and Water are needed to survive,
coad Samba Scapegoat
Posted: Sat Oct 27, 2007 2:16 pm Post subject: |
Samples can be misleading since they are mixing such a small batch that the machine simply can't dispense the tiny amounts of pigment accurately. I mean, you scale the formula down to where you're talking a 1/4 drop of something and all bets are off.
Spend the money and have them mix at least a pint if you really want to see what the paint is going to look like, especially with a crazy color like Strato Silver. |
