Front emblem mounting measurements
Page: 1, 2, 3  Next
MichellesGotABus
MichellesGotABus is offline
PostPosted: Wed Nov 14, 2007 2:56 pm    Post subject: Front emblem mounting measurements Reply with quote
Two questions:
1. What are the measurements to install the front emblem on an early bay (1970)? (mine were filled- with metal- in the resto process)...I checked on ratwell's site and his is for a later model bus that I believe took a smaller emblem.
2. Is there anyway to get this emblem on without removing the kick panels? Those things were such a pain to get in I dread removing going through that process again. I mean, can you secure the back of the emblem by reaching 'round another way? (Or just gluing it? How would that turn out?)
Thanks everyone.
-'70 VW Bus (hard-top camper: all the perks of a camper without the leaky top!)...shown in pic pre-restoration.
vwbusbusvw
Banned
vwbusbusvw is offline
PostPosted: Wed Nov 14, 2007 3:07 pm    Post subject: 211853615 VW EMBLEM CLIP Reply with quote
Your front emblem has 4 mounting posts. The nose of the bus has 4 holes. Stick 4 of these in the holes in the bus:
http://wolfsburgwest.com/cart/DetailsList.cfm?ID=211853615
Now, pop the emblem on.
1994 Dodge Neon w/supercharged 1500dp
OMVWC
stuped is stuped duse
MichellesGotABus
PostPosted: Wed Nov 14, 2007 3:13 pm    Post subject: Reply with quote
Um...did I not clearly state that my holes were filled in the resto process? I need the measurements to drill new ones. Then, yes, I can stick the four pegs in the four holes-- I think I could figure that part out.
visibleink
visibleink is offline
PostPosted: Wed Nov 14, 2007 3:31 pm    Post subject: Reply with quote
If you ask me, keep the "shaved" look.
Looks cool and less work.
Edit, this must be your bus.
Been on the samba so long I remember petting that dog to see VWs, WYHI, and green bug girl.
<-- Helga, she slammed her dub in '53 and adjusted valves with her teeth
cr@M
cr@M is offline
PostPosted: Wed Nov 14, 2007 3:57 pm    Post subject: Reply with quote
She asked for the dimensions of the holes, implying that she knows that she needs those clips, but doesn't how how big to drill.
And vwbusbusvw, yes the front emblem threads are common, but she's asking about the holes, not the things themselves, thus her on thread. And yes i agree if she had an emblem question she could have posted it there, but she didn't so let's let it go, answer her question, and continue our lives.
Michelle: If you have those clips you can measure them to find how big the hole should be if no one here knows the size. That's what i would do.
1972 Deluxe named Lucidity
1973 Transporter
"He who fights with monsters must see to it that he himself does not become a monster...
when you gaze long into the abyss, the abyss also gazes into you."
-Friedrich Nietzsche
vwbusbusvw
Banned
PostPosted: Wed Nov 14, 2007 4:01 pm    Post subject: Reply with quote
Reach inside the bus, and find a hole that has been filled with filler. Pop it out with a screwdriver. Now, take your emblem, and put a dab of paint on the end of the posts. Fit one post of your emblem into the hole that you popped out, make sure the emblem is level, and push it onto the nose, so that the paint marks where the other 3 holes are. Remove emblem, and pop out the other holes from the front. Now, go inside, remove Birkenstocks, wash hands, and reapply patchoulli spray. Working on them buses is dirty business.
OMVWC
stupidsongs2
stupidsongs2 is offline
PostPosted: Wed Nov 14, 2007 4:05 pm    Post subject: Reply with quote
And seeing out no one has actually answered her question yet:
What I did with mine was take the emblem, position it at a point on the bus where it looks good, and make a mark with a grease pen or something else that'll come off easy. Then I covered the four little attachment points with graphite, held the emblem where i had it before, tapped it with a hammer to get the graphite to apply to the body, and drilled where the resulting marks were.
I'd recommend drilling slightly smaller then the attachment points and just hammering in the emblem with a rubber mallet, but that's just cause of my strange fear of something falling off the front of my bus. Wink
Also much, much easier to make small holes larger than the other way around...
vdubyah73
vdubyah73 is offline
PostPosted: Wed Nov 14, 2007 4:06 pm    Post subject: Reply with quote
None of you read, she said the holes are filled with metal!
And I'm not going to pull my emblem off to get dimensions because the clips are a little tender, I get it off and it may not go back on.
Bill
burning down the house
73 bounty hunter, sold.
'77 transporter, junked had crotch rot.
Dubless, but have a CPR built stroker waiting for a new to me Beetle
'93 Fleetwood Bounder 34'
vwbusbusvw
Banned
PostPosted: Wed Nov 14, 2007 4:09 pm    Post subject: Reply with quote
Didn't notice metal instead of filler. Same process as above, just use a drill to make the first hole. Should be easy to find inside.
OMVWC
brenthughes
brenthughes is offline
PostPosted: Wed Nov 14, 2007 4:52 pm    Post subject: 1968-72 front emblem mounting measurements Reply with quote
Here are the dimensions from my '68.
The measurements involving mounting holes are taken from the center of the hole.
I'm guessing it would be easiest to center the emblem by dividing the the 2-11/16" grill center measurement and 6-3/8" pin to pin measurement in half. Maybe use a plumb line if you can level the bus itself.
A 15/64" drill bit fit snug in my mounting holes, made thinner by a couple layers of paint. However, I believe a 1/4" bit will be too large.
My only advice would be to punch your marks, start with fresh, small bits and move up to the 15/64" size.
Good Luck!
Brent Hughes
68 Beetle
68 Double Cab
Haptic Garage on YouTube: https://www.youtube.com/c/HapticGarage
vdubyah73
PostPosted: Wed Nov 14, 2007 4:59 pm    Post subject: Reply with quote
Good Luck!
Brent Hughes
You're a nice guy Mr. Hughes, Looks like you just took the photo tonight and put some time in drawing it up.
Bill
katkat
katkat is offline
PostPosted: Wed Nov 14, 2007 5:06 pm    Post subject: Reply with quote
YAY! another VW woman!!! I have the same issue on my 77. The holes were filled in and I hate to make new holes in the paint job...My emblem has been in the glove box since we bought it!
Cat,
77 Baywindow
63 Airstream Overlander
Liveonjg
Liveonjg is offline
PostPosted: Wed Nov 14, 2007 5:17 pm    Post subject: Reply with quote
Wow, a thread that so eloquently displays the good, the bad, and the ugly that The Samba has to offer.
Way to go brent! Always nice to see someone go the extra mile to help out a fellow bus owner.
-John
Keep it acoustic.
77 FI 2L Westfalia - Ripple
77 FI 2L Westfalia - Althea
62 Dual Carb Single Cab - Lou
barrysmith
barrysmith is offline
PostPosted: Wed Nov 14, 2007 5:32 pm    Post subject: Reply with quote
Good Luck!
Brent Hughes
outstanding, Mr Hughes! I would rather be a post whore than a crabby ass Twisted Evil
vdubyah73
PostPosted: Wed Nov 14, 2007 5:37 pm    Post subject: Reply with quote
-John
Which one am I? Ugly? Very Happy
Liveonjg
Liveonjg is offline
PostPosted: Wed Nov 14, 2007 5:38 pm    Post subject: Reply with quote
-John
Why you askin' me, I just got here?
-John
Keep it acoustic.
MichellesGotABus
PostPosted: Wed Nov 14, 2007 8:56 pm    Post subject: Reply with quote
Thanks to all of you who contributed helpful information on this! I really appreciate it. That pic with the measurements was just perfect BrentHughes, thanks.
bus kid
bus kid is offline
PostPosted: Wed Nov 14, 2007 9:19 pm    Post subject: Reply with quote
Hay Michelle,
I'll be installing my emblem on my 1969 deluxe this weekend . PM me and we can drill, mount and glue our emblems together. Laughing
EXCELLENT job Brent Hughes Exclamation
1969 Deluxe you'll hear me!
[img]
Big Blue runs on gas not Friendship,
so pay up or get out!
brenthughes
PostPosted: Thu Nov 15, 2007 7:51 am    Post subject: Reply with quote
You're welcome, MichellesGotABus. And thanks everyone for the positive responses. My 15 minutes or so of doodling is nothing compared to the amount of information I get from this community.
Sincerely,
Brent Hughes
68 Beetle
68 Double Cab
82-T/A
82-T/A is offline
PostPosted: Fri Nov 16, 2007 6:37 am    Post subject: Reply with quote
Hey Michelle,
How were the holes filled when the Bus was restored? If it was like mine, they filled them with a skim-coat of bondo and plastic. The BEST thing to do to eliminate you from having to drill NEW holes, would be to look at the panel from the inside and see if you can see those holes. On mine, there was a dab of bondo sticking out, I simply knocked it off with a plastic chizel (from the inside of course) and it punched out the hole for me. That will eliminate you from having to measure and drill new holes.
Unless your Bus originally had a spare tire mounted on it... in which case I don't think you would have ever had holes.
Hope that helps...
Todd,
(Fun cars)
2002 Ford Crown Victoria LX-P74
1987 Pontiac Fiero SE / V6
1973 Volkswagen Type-2 Transporter
Page: 1, 2, 3  Next
