JeffL Samba Member
Posted: Sat Nov 24, 2007 7:02 pm Post subject: Thanksgiving cranberry sauce and low light rotisserie Ghia |
How woud you like yours done:
Authentic?
Mild Custom?
Rat Rod?
We had some fun putting the body back on the rotisserie to scrape off the north east undercoat and get ready to paint the bottom.
Storing the pan was easy against the wall, I found out that the tunnel was full of tranny oil, well not any more as it poured out into the wheel on the bottom.
myinisjap Samba Member
Joined: November 13, 2007 Posts: 41 Location: california
Posted: Sat Nov 24, 2007 10:22 pm Post subject: |
Did you make that stand?
and where is it attached to? the bumper brackets? |
JeffL Samba Member
Posted: Sun Nov 25, 2007 11:50 am Post subject: |
myinisjap wrote: |
Yes I just used the standard bumper mounts. However, inside the front nose a made a brace the fits between the bumper mounts for extra strength. I have some support between the doors to keep the body straight.
If your mounts are not in good condition you would need to replace these first. I have seen a front mount that reaches up underneath and attaches by the brake fluid reservoir for strength.
The pivots are simply some front spindles I got at the scrap yard. I just measured to find the rotational center of the car and it works fine. I can leave the mounts attached to the car (kink of like ugly bumpers) and then attach the rotesserie to it when needed.
There are 6 casters to move the car arount and two long latterals to keep the car from spreading. This was you can stand on one side of the body and not get tangled up by the braces.
I really wanted to use a caliper E-brake to fix the rotation of the body but simply use a bar with holes and bolts to secure the position. |
noexit Samba Member
Joined: September 18, 2006 Posts: 329 Location: Tacoma, WA
Posted: Sun Nov 25, 2007 10:28 pm Post subject: |
I'm going to have to do something like that. Do you have mounts to put the pan on the rotisserie too? Seems like that should be easy enough as well. _________________ Rusty '62 L360 seeblau, L289 blauweiĆ Type 1 Karmann Ghia |
56GoldeGhia Samba Member
Posted: Mon Nov 26, 2007 9:19 am Post subject: |
Wow, the cut out of the roof looks like a job well done!
I hope you be able to finish the car soon.
Regards,
Rinie |
JeffL Samba Member
Posted: Mon Nov 26, 2007 9:41 am Post subject: |
noexit wrote: |
I'm going to have to do something like that. Do you have mounts to put the pan on the rotisserie too? Seems like that should be easy enough as well. |
I never thought of doing mounts for the pan but that is a great suggestion. |
JeffL Samba Member
Posted: Mon Nov 26, 2007 9:47 am Post subject: |
56GoldeGhia wrote: |
Regards,
Rinie |
Thanks for the compliment. As life would have it, I am moving in about 6 months. So, I will have to pack up the Ghia and move again most likely storing it for a few more years. I want to get the under side and pan done before moving. I'm not sure if that is possible as I travel every week. I'd like to move and the get it painted. I've had the car for 15 years now (pretty scarry, but I've done all the work myself and had a dozen cars and some restoration in between). I am determined to finish it! |
Posted: Mon Nov 26, 2007 10:02 am Post subject: |
Well, I have to be honest. My car is finished for 80% and all the parts are there to make it complete and I still can't find the time to finish it. I am maybe 3 months away from finishing it.
So I know what you mean Jeff, when you say you have the car for 15 years. It is sometimes difficult to find the time but at least the cars have a good home. |
58lolight Samba Member
Posted: Mon Nov 26, 2007 9:25 pm Post subject: |
What is your goal for the car?
I am curious what your plans for the car are. I have three cars and have a blurry vision of what I want to do with all three.
Rich |
Kman07 Samba Secret Service
Joined: August 29, 2007 Posts: 413 Location: Campbell River, The great north...of the border
Posted: Mon Nov 26, 2007 9:41 pm Post subject: Re: Thanksgiving cranberry sauce and low light rotisserie Gh |
JeffL wrote: |
Authentic?
Mild Custom?
Rat Rod?
Well I think I'll have mine done mild custom please but keep it toward the authentic side, Don't go Rat Rod on me!  _________________ | My 1969 Rebuild | My Pictures |-VVWC- |
layinrocker67 wrote: |
does anyone one this site ever help anyone or do you all just talk shit |
Rome Samba Member
Joined: June 02, 2004 Posts: 10665 Location: Pearl River, NY
Posted: Thu Nov 29, 2007 2:47 pm Post subject: |
Moving, Jeff? Ugh. My preference would be an authentic resto of the body (full trim; stock color) and interior, but with updated mechanicals like Porsche 356A or B brakes, 356 wheels and a somewhat stronger engine like a mild 1776 Kadron-carbed single port. Try to find some low Porsche Knecht air filters to adapt to the Kads, and paint the engine stock to make it look like "old speed". Also a '67 tranny for nicer highway cruising with that engine.
Have you welded in 3-point safety belt mounts for safety? Hmm?
Is that a stock, original front sway bar?!
Keep with it; looks like it'll be a grand car when done.
Roland from NY |
70 140 Samba Member
Joined: September 22, 2002 Posts: 8471 Location: Ontario Canada
Posted: Thu Nov 29, 2007 3:04 pm Post subject: |
Why would you need the pan on a rottisserie? Once you pull the transmission and beam off it will practically lay flat on the floor. Work on one side and flip it over... |
noexit Samba Member
Posted: Thu Nov 29, 2007 5:35 pm Post subject: |
70 140 wrote: |
Because I don't really like sitting on the cold concrete while working on my car. _________________ Rusty '62 L360 seeblau, L289 blauweiĆ Type 1 Karmann Ghia |
JeffL Samba Member
Posted: Thu Nov 29, 2007 7:06 pm Post subject: |
58lolight wrote: |
Rich |
I plan to keep it stock accept for several accessories: Webasto Sunroof, 1956 dated 356 rims, Aero side mirror, Rometsch steering wheel, Petri full circle horn ring, 3/4 package tray, and Judson supercharger with scoop. I also have a 45 rpm record player that ties into the radio that I might mount. The car came from the dealership with an Automatic radio that has Volkswagen silk screened on the face. The car did have seat belts mounted too that I will reinstall (sorry not a 3 point mount suggested in another post ). The original wood slat would cover up the sunroof so I might not use it. I have a modern tach that was fitted into an early clock with an early speedo needle. If I can't ever come up with a real tach I will install it.
The car only had 65,000 miles when I got it from the original owner. I have the original keys and bill of sale. |
JeffL Samba Member
Posted: Thu Nov 29, 2007 7:11 pm Post subject: |
Rome wrote: |
Roland from NY |
Yes the sway bar is original, what looks odd about it?
I do have original seat belts buy they are only two point mounted in the pan. |
Posted: Thu Nov 29, 2007 7:50 pm Post subject: |
Jeff,
I am planning the same kind of resto for your old car if I can ever get the body nice enough.
Rich |
JeffL Samba Member
Posted: Thu Nov 29, 2007 9:06 pm Post subject: |
58lolight wrote: |
Jeff,
Rich |
Keep plugging away at it, I just hope I get mine done before they take my license away due to old age. |
Rome Samba Member
Posted: Fri Nov 30, 2007 1:24 pm Post subject: |
"Yes the sway bar is original, what looks odd about it? "
Jeff, I'm only used to seeing the stock 'straight" swaybars on Beetles. I was not aware that the ones on early Ghias had those additional 2 bends in them at the two vertical centerposts of the axle beam. |
70 140 Samba Member
Posted: Fri Nov 30, 2007 2:26 pm Post subject: |
noexit wrote: |
70 140 wrote: |
Because I don't really like sitting on the cold concrete while working on my car. |
Time for a heated slab.
Seriously though. Leaning the pan up against a wall or laying it on the floor are options you don't have with a body (which IMO is a good reason for a rotisserie) The wall or the floor will be a lot more stable, and again IMO, easier to work with. |
65ghia Samba Member
Joined: May 29, 2001 Posts: 224 Location: Hayward ,CA
Posted: Fri Nov 30, 2007 6:39 pm Post subject: |
my 58 ghia has that same front dimpled sway bar |
