VolksWatson Samba Member
Joined: April 30, 2005 Posts: 177 Location: Tyler, Tx
Posted: Tue Dec 11, 2007 10:33 pm Post subject: whitewall tire paint |
Has anyone tried this? I have heard too many bad things about the inserts, so I am seriously considering this.
Just want to see if anyone has used this and what their experience has been.
VolksWatson |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16808 Location: State College, PA
Posted: Wed Dec 12, 2007 6:24 am Post subject: |
I had seen posts of poeple using Krylon fusion paint with good results. I plan on trying it myself before I spend a mint on Cokers. Do a search and you will find some posts with more detail on how to do it. _________________ D-Dubya Manx clone 1914. Ex wifes car.
Maxine 61 Cal-look bug - Ex-wifes car.
Buggeroff Argumentative Bastard
Joined: October 16, 2004 Posts: 1124 Location: Lake of the Ozarks, Missouri
Posted: Wed Dec 12, 2007 7:22 am Post subject: Re: whitewall tire paint |
| VolksWatson wrote: |
VolksWatson |
I am stuck with dial up so pictures are a pain, but, I painted my tyres with a white liquid co-polymer and was delighted with the results.
After thoroughly cleaning the tyres and removing the "nubs" of rubber I applied packing tape and very patiently used a scalpel to cut the tape around a moulding line. I applied three coats of the co-polymer per tyre to avoid bleed through and when dried, again followed the line with the scalpel to avoid tearing.
This stuff is very flexible, flows very well and good for - 30 to + 125.
It's best to have the tyres off the rims for the most desirable results. _________________ "Chris of the Ozarks"
Headlinerless 57 Ghia
Thread deleter extrordinaire. |
Ghiaddict Samba Member
Joined: November 20, 2002 Posts: 2632 Location: Now in Honea Path, SC
blarneyman Samba Member
Joined: February 06, 2005 Posts: 1621 Location: Everson/Bellingham, WA
Posted: Wed Dec 12, 2007 7:34 am Post subject: |
Here's a copy of a thread from another forum.
right theres 4 ways to do it, here they are:
1) buy white wall tyres, class if you live in america, we dont, so with the tyres i needed being £175+postage i decided this option was out the window.
2) buy white band tyres and grind the outer wall off.... white band tyres are cheaper than white wall tyres....but they actually have a white layer underneath the side wall, and gentle and careful use of a grinding disc at a low speed can remove the black wall and expose the white layer underneath.... last resort if you want a set of "real" white walls.
3) buy white wall tyre flaps... they are shit... if you hit a curb they are ruined, plus they eat into the side wall of your tyre if they arent applied properly ( you need to use rubber grease between the flaps and the tyres etc.
4) make your own.... well in good auld norn iron, the easiest way is too make your own... thats what i did
now.... how do you make your own? you use a white rubber paint, we use a special blend of rubber paint which also has titanium powder added to it to prevent the degradation of the "white" by sunlight.
step 1 :
clean the tyre wall with cellulose thinners...
next tape up the rim...
and then the edge of the side wall you are going to paint too.... i decided on wide as feck whites for the PBoD
paint the tyre....
first coat done on all 4 tyres, ill leave them 24 hrs to cure then do another coat, ill repeat this process maybe 4 or 5 times, just to give a really deep white wall, as the tyres im working with are brand new and they are the hardest to paint
_________________ 69 Beetle
70 Ghia(resto) |
Posted: Wed Dec 12, 2007 7:35 am Post subject: |
Completed project
70 Ghia(resto) |
topcarbon Samba Member
Posted: Wed Dec 12, 2007 8:00 am Post subject: |
| wow, looks great |
Gary Person of Interest
Joined: November 01, 2002 Posts: 17069 Location: 127.0.0.1
Posted: Wed Dec 12, 2007 8:22 am Post subject: |
blarneyman,
That looks really slick. If I hadn't seen it I wouldn't have believed it. _________________ West Virginia State Board of Education v. Barnette, 319 U.S. 624 (1943) |
OTO X58 Samba Member
Joined: March 27, 2004 Posts: 3211 Location: Santa Cruz, CA
Posted: Wed Dec 12, 2007 9:01 am Post subject: |
Wow. This look like the way to go. Looks great! When I get to tat point, I an definitely going to do this!
Thanks for the info!
Volkswatson |
70 140 Samba Member
Joined: September 22, 2002 Posts: 8471 Location: Ontario Canada
Posted: Wed Dec 12, 2007 9:19 am Post subject: |
| RoachGhia wrote: |
| Can we get an up-close picture of the final product? |
Here you go Roacho
Lee. Samba Animal Controller
Joined: December 22, 2003 Posts: 3079 Location: Denver, CO
Posted: Wed Dec 12, 2007 9:56 am Post subject: |
| RoachGhia wrote: |
x2
I've seen a lot of these tires done with paint. I'd be interested to see what they look like after 15,000 miles. I've never seen "after" pics. _________________ www.DenverWildlifeControl.com |
Posted: Wed Dec 12, 2007 2:48 pm Post subject: |
This is the only close up I could find.
70 Ghia(resto) |
