Beaboy Samba Member
Joined: April 16, 2007 Posts: 307 Location: Jacksonville, Florida
Posted: Sun Dec 30, 2007 9:10 am Post subject: PTFE Additive? |
I've used a PTFE additive in all my cars and trucks every 50K miles since they were new (truck just clicked over 200K, wife's Mazda just turned 145K, daughter's pickup is currently at 93K) with absolutely no primary engine work ever required and still getting the same fuel mileage as when I bought them.
My question - Has anyone used a PTFE additive (i.e. Slick 50) in their type 1? I've finished my restore and as of this Wednesday, it will be my daily driver, so I'm wondering if I can continue using this product or similar in a bug.
Thoughts? _________________ '69 Standard Beetle |
Beaboy Samba Member
Posted: Sun Dec 30, 2007 9:13 am Post subject: |
Oops. Probably should mention that it's a '69 type 1 w/ a 1970 1600 single port engine, mostly stock. _________________ '69 Standard Beetle |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 80319 Location: Sneaking up behind you
Beaboy Samba Member
Posted: Sun Dec 30, 2007 9:35 am Post subject: |
Interesting reads, Glenn. Guess my engines are the only ones that work well with the stuff. That said, I'll run my '69 without it.
Thanks. _________________ '69 Standard Beetle |
propflux01 Samba Member
Joined: June 03, 2006 Posts: 501 Location: Central Arkansastan
Posted: Sun Dec 30, 2007 9:46 am Post subject: |
Snake oil _________________ A 55-gallon Drum and a Shovel Can Solve Many Problems..... |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15604 Location: Deep in the 405
Posted: Sun Dec 30, 2007 12:58 pm Post subject: |
I read a 10 year study by a major university engineering Dept on oil additives. There final result was that they could not prove they did any good. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Bruce Samba Member
Joined: May 16, 2003 Posts: 17655 Location: Left coast, Canada
Posted: Sun Dec 30, 2007 2:02 pm Post subject: |
Polytetraflouroethelyene, aka Teflon. Dupont is the trademark holder of Teflon, and the supplier to Slick 50. Dupont says teflon in an engine oil suppliment does not work. That should tell you something.
A few years ago, Dupont decided to stop the fraud by Slick 50, by cutting off supplies to them. Slick 50 took Dupont to court, and some ignorant judge sided with them, forcing Dupont to continue to supply Slick 50 with teflon. _________________
| overheard at the portland Swap Meet... wrote: |
| ..... a steering wheel made from a mastadon tusk..... |
fonz15 Samba Member
Joined: April 15, 2004 Posts: 107 Location: los angeles, CA
Posted: Sun Dec 30, 2007 3:45 pm Post subject: |
| not to steal the thread but i have a question about LUCAS oil additives, are those any good, anyone use them?? is it a ptfe additive? |
grimace007 Samba Member
Joined: August 30, 2006 Posts: 2673 Location: swampville, florida
Posted: Sun Dec 30, 2007 4:54 pm Post subject: |
do NOT use lucas in any motor you want to keep
i used a little less than a half qt. in my old 69.
within 100miles my motor locked up.
from what i understand lucas froths up and decreases the oiling to bearings which would explain why my #3 rod bearing got welded to the crank _________________ Brian
68 sedan
Dallas Air Coolers
| perrib wrote: |
Hey It is The Samba where well thought out rational answers can take a while and getting side tracked is normal. I was just lucky this time.  |
| cr@M wrote: |
No one has any personal responsibility these days. This country is sue happy. Intelligence is no longer a requirement, just an accessory. |
