Upper control arm bushing failure (pictures)
Page: Previous  1, 2, 3 ... , 16, 17, 18  Next
MrCarpy
MrCarpy is offline
PostPosted: Wed Sep 28, 2022 11:35 am    Post subject: Re: Upper control arm bushing failure (pictures) Reply with quote
ZsZ wrote:
The main problem is some brands are just boxing ones made somewhere unknown, then change supplier with time. Others who are manufacturing themself, change manufacturing plants with time.
And they have different suppliers/plants on different markets.
Like Lemforders were the best as they had the VW-Audi logo hand grinded and were made in Germany. Now they have no logo and are made in Turkey.
Meyle was good, then changed supplier, now it is crap.
The old OEM Lemforders lasted ~100k Kms, then I got Febi, lasted ~50k, Meyle ~2k, Now new Lemforders.
The spot weld did not penetrate into the bushing on the right side as the sleeve has some coating and made from some special steel recipe. Had welded in situ but they are still squeaking.
Thanks for the clarification Zoltan Smile
So it would seem to still stick with Lemforder 1st or Febi 2nd ?
1988 Vanagon GL Westfalia, Flash Silver
ALIKA T3
ALIKA T3 is offline
PostPosted: Wed Sep 28, 2022 11:40 am    Post subject: Re: Upper control arm bushing failure (pictures) Reply with quote
MrCarpy wrote:
ALIKA T3 wrote:
the only reason I went with stock style is to be able to grease them without touching the alignment.
ok your greasing them using the Zerk fitting correct?
ALIKA T3 wrote:
They're all cheaply made anyway...
It sadly seems so. Im on my second set in one year with very low millage.
Correct.
It's been a plague for over 15 years now until Powerflex came up with better products. They did however moved from stainless outer sleeve in one piece into a 3 piece design: steel outer sleeve and stainless inner sleeve+ stainless washer. I prefer the old design.
ZsZ
ZsZ is offline
PostPosted: Wed Sep 28, 2022 12:38 pm    Post subject: Re: Upper control arm bushing failure (pictures) Reply with quote
Due to the welding problems I lean to Febi 1st - however I dunno if they changed someting in the last 5 or so years I bought them last time.
Maybe with the grease zerks put in they are both fine.
Zoltan
1.9 MTdi 2wd Multivan (ex Caravelle)
Van since 2006, engine since 2008
DanHoug
DanHoug is offline
PostPosted: Sun Jan 08, 2023 5:19 pm    Post subject: Re: Upper control arm bushing failure (pictures) Reply with quote
doing UCA bushings along with BJs and TREs (Razz) on my 87. these Elastmetall are what came out with a loud snap under pretty high press pressure, yes the weld was removed. no way they would move in my bench vise. bushings were still tight after 250k miles but squeaky.
Elastmetall 202345 is the PN. doing a little web search reveals that Elastmetall is 'ZF Boge Elastmetall' so these are Boge bushings. putting in the Powerflex bushings from T3.
-dan
www.thefixitworkshop.com
ZsZ
ZsZ is offline
PostPosted: Sun Jan 08, 2023 11:48 pm    Post subject: Re: Upper control arm bushing failure (pictures) Reply with quote
BOGE is owned by ZF just like Lemforder. These were sold as the Lemforder bushings 10-15 years ago (see the small triangle logo) just the VW-Audi logo was groud off by hand.
Zoltan
ALIKA T3
ALIKA T3 is offline
PostPosted: Tue Jan 10, 2023 10:32 am    Post subject: Re: Upper control arm bushing failure (pictures) Reply with quote
Yes, it's Lemfoerder, the VW manufacturing code is actually on it: LME.
Boge would be BSO. Early vans had them, with a metal ring. Bomber! I took off a set from an 83 aircooled that I actually saved for the Syncro next time Laughing
DanHoug
DanHoug is offline
PostPosted: Thu Jan 12, 2023 4:54 am    Post subject: Re: Upper control arm bushing failure (pictures) Reply with quote
the Powerflex bushings are in on the passenger side, and man, does that upper control arm ever move smoothly now. it'll be interesting to see if there's a ride difference with that being able to move up and down so easily.
wanting to forestall rust and an immovable cam washer for this winter driver van, i slathered Bushing Snot on the cam washer, new bolt, and the frame socket the cam washer goes into. after tightening the nut "Guut-n-Tite" with a 3/8 ratchet i could still move the entire bolt and cams with a breaker bar on the Allen socket head. dang. did the Snot lube things too much? then i got out the torque wrench and found i was WAY low on torque and think i hadn't compressed the purple poly bushing nose that sticks out beyond the metal sleeve. torqued it to spec and the bolt head locked up tight with no movement even with a 1/2" breaker bar.
dunno what the Bushing Snot is but man, i don't think it is washing out soon. doesn't wipe off with a rag, GoJo doesn't dissolve it well, Windex doesn't touch it, brake cleaner got it off. some garage hilarity ensued when i picked up a thin paper napkin and couldn't get it off with the Snot on both gloved hands. is it a mix of Teflon and silicone grease?
-dan
revolution337
revolution337 is offline
PostPosted: Thu Jan 12, 2023 5:14 am    Post subject: Re: Upper control arm bushing failure (pictures) Reply with quote
I had a similar experience with the stuff. I must have went through and entire box of nitrile gloves during my front end rebuild. God forbid you get the stuff on your tools, what a nightmare to clean off. Brake clean was the only thing that seemed to have any effect on it.
Well over a year has passed since my rebuild, and the excess "bushing snot" that oozed out during bushing replacement is still in place, doesn't seem to have dripped off or rinsed at all. I swear this stuff is made with witchcraft.
1982 Westfalia AEB 1.8t
2017 VW Golf Sportwagen
2001 Audi A4 4.2 V8 swapped
2000 BMW Z3 roadster
-Mark
do.dah
do.dah is offline
PostPosted: Thu Jan 12, 2023 10:30 am    Post subject: Re: Upper control arm bushing failure (pictures) Reply with quote
As I as doing mine, Chris recommended that stuff, and I said "SURE".
I started to put that shit on EVERYTHING that I wanted to stay lubed.
When I ran out, called Chris and asked if he had anymore, and he was mystified how I could've gone thru so much on just a bushing job. I told him I put that shit on a whole lot more than the bushings. He chuckled..
calo1956
calo1956 is offline
PostPosted: Thu Jan 12, 2023 10:45 am    Post subject: Re: Upper control arm bushing failure (pictures) Reply with quote
I tacked mine, because thats how they were from the factory, it sucks that yours are failing so quickly. I did mine about 7 yrs ago, and I guess I lucked out because mine are fine so far
Enjoy the ride....
72 bug
80 westfalia
ALIKA T3
ALIKA T3 is offline
PostPosted: Tue Dec 12, 2023 8:36 pm    Post subject: Re: Upper control arm bushing failure (pictures) Reply with quote
ALIKA T3 wrote:
No it's lack of greasing inside.
I added zerk fittings.
People have had good success with them in France on the forum.
Notice how the grease shot out the front side of the bushing here on above picture, it wasn't built properly....
I installed Meyle bushings recently, not my preferred choice as I hate this brand but they were free.
Dimensionally similar to stock ones, I don't understand why I had a
13 to 14mm gap to solve with eccentric washers. My UCA are straight, parallel, well lined up. ( I actually had to straighten one a bit)
I'm puzzled by this but made it work with 1 eccentric washer on one side and 2 one the other. The chassis width is 153mm here, it's constant on every van. My gap was 165mm at the Syncro UCA which I find a lot but it matched a stock 2WD arm.
Well, a year and half later, not a ton of miles, some offroad with this toy, I still have no play but today my daughter inspected the UCA's and she told me they looked wrong. I'm sure the failure is close....
I'll go back to PU , Whiteline this time until I can afford the beautiful billet parts from T3technique.
See how the nut appears off-centered?
shagginwagon83
shagginwagon83 is offline
PostPosted: Wed Dec 13, 2023 7:59 am    Post subject: Re: Upper control arm bushing failure (pictures) Reply with quote
If it makes you feel better in 2018 I invested in the BMS Billet UCA's and after my Baja trip (and years of average use) I had to spend $300 on a new set of heim joints. Ultimately there is a small nylon bushing inside those joint.
Brandon
Instagram @joannthevan
ALIKA T3
ALIKA T3 is offline
PostPosted: Thu Dec 14, 2023 1:44 pm    Post subject: Re: Upper control arm bushing failure (pictures) Reply with quote
Oh that's scary !!
I thought heim joints were cheaper than that !
I hope the T3TECHNIQUE ones are tougher 😲
shagginwagon83
PostPosted: Thu Dec 14, 2023 2:58 pm    Post subject: Re: Upper control arm bushing failure (pictures) Reply with quote
I thought so also - https://burleymotorsports.net/product/bms-new-gen-heim-joint-for-upper-control-arms/
Brandon
ALIKA T3
ALIKA T3 is offline
PostPosted: Thu Dec 14, 2023 4:09 pm    Post subject: Re: Upper control arm bushing failure (pictures) Reply with quote
Oh you bought them from BMS, that's why. Are they specifically modified or do they look generic ?
If it's generic, it's prolly marked up a lot.
Christopher Schimke
PostPosted: Thu Dec 14, 2023 4:21 pm    Post subject: Re: Upper control arm bushing failure (pictures) Reply with quote
Our joints are custom made specifically for us and run $45.99 each...if you ever need a replacement.
calsurf
calsurf is offline
PostPosted: Thu Dec 14, 2023 5:17 pm    Post subject: Re: Upper control arm bushing failure (pictures) Reply with quote
I found that plain WD40 works excellent in removing it. Great stuff both Snot and WD.
ALIKA T3
ALIKA T3 is offline
PostPosted: Thu Dec 14, 2023 10:52 pm    Post subject: Re: Upper control arm bushing failure (pictures) Reply with quote
Brake cleaner and ...rubbing alcohol work wonders!
ALIKA T3
ALIKA T3 is offline
PostPosted: Thu Dec 14, 2023 10:53 pm    Post subject: Re: Upper control arm bushing failure (pictures) Reply with quote
Thank you Chris!
now I need to cough up the money Razz
ZsZ
ZsZ is offline
PostPosted: Mon Mar 18, 2024 5:35 am    Post subject: Re: Upper control arm bushing failure (pictures) Reply with quote
Bought FEBI ones today.
It looks like they are not made in Germany any more. Different plastic ring and more rough surface. No info on where they are made.
But I can see why the Lemforders failed on me. These are taller by 1.5 mms
It seems like nowadays you need different thickness shims even on 2WD vans.
Zoltan
Page 17 of 18
