Ymirvanman Samba Member
Posted: Sat Jan 19, 2008 12:36 pm Post subject: removal of windshield washer nozzles |
Was trying to clean the ice out of the nozzle with a toothpick and broke a piece off in the nozzle (ouch!).
Can anyone help me with the removal of the nozzle so I can get the wood out?
Harlan |
Perales Samba Member
Joined: May 07, 2007 Posts: 2046 Location: Nova Scotia
Posted: Sat Jan 19, 2008 1:01 pm Post subject: |
Do a search, this was discussed recently. _________________ -- 1987 Westfalia automatic (Captain Vino) |
McVanagon Samba Member
Joined: February 19, 2007 Posts: 1684 Location: Northern part of the Virginia
Posted: Sat Jan 19, 2008 1:51 pm Post subject: |
I just did this two weeks ago, but it was to replace them...
1) Buy new ones. They are really cheap. http://www.busdepot.com/details.jsp?partnumber=211955993
2) With a big pair of vicegrips, grab a hold of them and slowly pull them out by wiggling and bending. They will be ruined once you get them out.
3) Switch them.
4) Keep toothpicks in the kitchen.
Be extra careful not to scratch the paint. Be extra careful not to drop the hose into the hole, you'll need to remove the dash to get them out.
I used a heat gun to heat up the tips of the hoses in order to swap nozzles, since the hoses were hard and stiff. _________________ '69 Mike
'85 GL
'87 Wolfsburg Hardtop |
K58 Samba Member
Joined: July 01, 2006 Posts: 1173 Location: Santa Barbara
Posted: Sat Jan 19, 2008 2:19 pm Post subject: |
the nozzles don't react well to cleaning and will just get plugged again
Replacing is the best option because once you have the old ones off it's going to be a biatch to get them back on so you might as well get new one's
I use a sewing needle to adjust/clean |
RGS Paul Samba Member
Joined: April 20, 2007 Posts: 684 Location: Los Alamos, NM
Posted: Sat Jan 19, 2008 4:04 pm Post subject: |
I hate to steal a thread but...
Does anyone know of a source for the nozzles that have two sprayers in them instead of one? I saw them here:
http://www.busman.be/pagina10.html
and wondered if anyone knew of a more local source? Or if someone is by chance going to be in Belgium...
Thanks,
Paul |
hilllaguna Samba Member
Joined: April 10, 2006 Posts: 49 Location: Laguna Niguel, CA
Posted: Sat Jan 19, 2008 10:56 pm Post subject: |
Grabbing them with the mini vice grips is the right idea. Put some duct tape on your paint before you pull on them in case the pliers/grips slip off them in the process. Turn a quarter of a turn and pull. If you have a hemostat, clip the hose and leave the hemostat on till you are done. This keeps the tube from slipping back in while you are putting the new ones on. This is a MAJOR pain if it happens. _________________ 1990 Vanagon GL full camper with GW 2.4 and tons of mods |
binger59 Samba Member
Joined: December 09, 2007 Posts: 237 Location: Oswego, NY
Posted: Sun Jan 20, 2008 4:33 am Post subject: |
I took out the tank and pump and blew air from a compressor in the tube. It clean out the lines and has work good ever since. Before I did this the passenger side didn't spray at all. Hardest part was aiming the spray with a needle.
1984 westy |
tclark Samba Member
Posted: Sun Jan 20, 2008 9:51 am Post subject: |
anyone ?? those looks like a nice simple upgrade ?? |
Dogpilot Samba Member
Posted: Sun Jan 20, 2008 1:33 pm Post subject: |
I would look at a few cars in a parking lot as I strolled by. Perhaps that way you can find which model make and year used them. Then look locally for a source. On my cars with two holes, it just means I have twice as many maladjusted streams of water. _________________ Geology with a Syncro rocks!
98 Disco I
08 Range Rover SC
08 VW Rabbit S
1951 O-1G |
shaun0008 Samba Member
Joined: December 14, 2004 Posts: 58 Location: San Francisco
Posted: Mon Jan 21, 2008 8:24 am Post subject: |
Bernd Jager of the the Syncro Spazalist in Germany sells washer nozzels that have three sqirters each. I have a set on my Westy Syncro and they work well, though it did take awhile to ajust them. I believe they are from a MB Sprinter that are modified by filing the bottom of the sqriter to go around the bump on the Vanagon You can check them out here
http://www.syncro-bernd-jaeger.de/ENGLISH/Spezialitaten/spezialitaten.html |
CHARLIE-DONT-SURF Samba Member
Joined: November 16, 2007 Posts: 335 Location: Cow County, UK
Posted: Mon Jan 21, 2008 11:55 am Post subject: |
tclark - i ordered some from busman a couple off weeks ago , they should be here soon. will have a look for VW/AUDI part number etc on them.
i have had a look at VAGCAT and think i know what model they came from (euro only model if im right) but not 100% sure and dont want to give you wrong info.
will let ya know as soon as ive had a look at my mates in the car park (parking lot i think you call it ) and compared them to my new ones
tclark Samba Member
Posted: Tue Jan 22, 2008 5:52 am Post subject: |
CHARLIE-DONT-SURF 10-4
i also heard some noise that
good ol' Beetle used a single dual-nozzle unit |
Ryan Alfonso Samba Member
Joined: March 23, 2007 Posts: 101 Location: Half Moon Bay, CA
Jamos Samba Member
Joined: July 08, 2005 Posts: 766 Location: Lake Tahoe, CA
Posted: Sun Jan 25, 2009 7:18 pm Post subject: |
I removed mine using the quarter-twist with vice grips as described above...
Got them out and then removed the tank to clean it and remove some pinched line.
I blew air through them and all seemed good.
Now that it's all back together, the system works, but I have to hold the stalk back for like 10 seconds before any fluid actually appears from the nozzles.
The pump is strong...so it seems like the only other option would be to replace all the hoses with new?
Anyone know how the tubing splits off from the driver's side? Is it just a T? _________________ '86 Wolfy Westy Weekender
2020 Audi Q5 |
zuhandenheit Samba Member
Posted: Sun Jan 25, 2009 7:37 pm Post subject: |
| Jamos -- you might just have a pinched hose. I had the same problem when I didn't position the pump properly, which twisted and pinched the hose. |
r39o Samba Polizei
Posted: Tue May 26, 2009 10:39 pm Post subject: |
| CHARLIE-DONT-SURF wrote: |
What was the result from this? _________________ "Use the SEARCH, Luke" But first visit the Vanagon FAQ!
