What to do?
kelroy
kelroy is offline
PostPosted: Sun Feb 03, 2008 9:43 am    Post subject: What to do? Reply with quote
What I have.
64 Pan,Swing Axle(axles level with motor,Fuel and Driver and Pass.) Front Beam and Avis Adjusters w/14X7 wheels, 205/70R14 tires.
Currently on Rear 14x7 G60-14 BFG Tires w/ adapters to 5 on 4/12( planning disc upgrade at sometime in future)
Want to fit Steel smoothies w/baby moons all around, 15x10 Rear w/ 28 or 29" Tall tires and 14x6 up front(no problem)Rears will not fit into fenders and I do not want to cut body. 1. How do I fit them in Question 2. How will this affect street abilities Question
Thanks for suggestions
Your Legacy should that you made it better than it was when you got it. Lee Iacocca
Yellermanx
Yellermanx is offline
PostPosted: Sun Feb 03, 2008 10:15 am    Post subject: Reply with quote
Complete body lift or tapered body lift to just raise rear. Converting to IRS, might be easier if the parts are readily available.
RaythO
RaythO is offline
PostPosted: Sun Feb 03, 2008 10:35 am    Post subject: Reply with quote
re-index your rear torsion bars, would look good with a bit of a rake IMO. by raising the rear alittle you will push the front /rear bias forward. should give you a better front brake and a bit harder steering. I don`t think it will be enough to notice though
Mid America Funfest, Effingham Illinois
May 31-June 1, 2008
THE buggy event of 2008. be there!!!!!
http://www.dunebuggyarchives.com/forum/forum_show.pl
kelroy
kelroy is offline
PostPosted: Sun Feb 03, 2008 12:48 pm    Post subject: Reply with quote
Yeller- Tapered lift was What I was thinking. How bad will the taller tires effect the overall speed and power in fourth gear?
Ratho- Really did not want to mess with suspension because of camber effect.
Any ideas to make a tapered lift?
I have tried a 1" wooden block for reference and it would allow proper tire clearance about 2". Gap naturally goes from 1" down to nothing. My idea would be to use composite decking material. Idea used per someone
on another forum.
From the motor that was in it, it seemed a little short for power and was a stock 1500. Working on a new heart for this season. Trying to figure out the "what if" before I begin.
I am running one caster shim behind the axle now and can go with another - planning to lower front some more(currently at mid way on the saw tooth adjuster.
Yellermanx
PostPosted: Sun Feb 03, 2008 4:36 pm    Post subject: Reply with quote
The "composite" deck material body lift is mine. It has been great with zero issues since it was finished. There are plenty of pictures in my www link at the bottom of this post. You may have to look for them.
My tires are right at 29" tall. I just have a 1600 and it accelerates and cruises real well up to 60 after that it labors. Your swing axle is geared a little lower so you should be better off than I am.
kelroy
kelroy is offline
PostPosted: Mon Feb 04, 2008 7:00 am    Post subject: Reply with quote
My apoligizes. I knew I had heard it somewhere but couldnt remember who or were Yeller. Thanks for the info on gearing and tires. Composite it is.
Yellermanx
PostPosted: Mon Feb 04, 2008 7:25 am    Post subject: Reply with quote
Don't forget to post pics. The stuff is fun to work with, however it makes tons of sawdust. Keep the shop vac handy.
63buggy
63buggy is offline
PostPosted: Thu Feb 07, 2008 9:42 am    Post subject: Reply with quote
i have the same buggy, and i do have the moon wheels on it. i do not remember the tire sizes but my rear tires fit fine at stock height with no rubbing. i actually want to lower the rear a notch or 2. mine is on a 63 chassy. i have 2 1/2 drop spindle and a select a drop in the front. it will not rub unless i slam it all the way down. i can't figure out how to post oictures but i can email them if needed.
