Modify Thing top instead of Bikini
richtrek
richtrek is offline
PostPosted: Wed May 21, 2008 10:52 pm    Post subject: Modify Thing top instead of Bikini Reply with quote
Have any of you customized your Thing top by modifying the rear window so that it can open and roll upwards similar to a Jeep top?
It seems like a neat modification in lieu of a bikini top.
pjmacua
pjmacua is offline
PostPosted: Thu May 22, 2008 1:59 pm    Post subject: Reply with quote
Not exactly what you're looking for but I think that it is nevertheless a good idea :
http://www.181spirit.com/portail_phpBB/index.php?p...pic_id=603
http://www.181spirit.com/portail_phpBB/index.php?p...pic_id=602
http://www.181spirit.com/portail_phpBB/index.php?p...pic_id=604
Regards
Pierre-J M.
77kafer
77kafer is offline
PostPosted: Thu May 22, 2008 4:15 pm    Post subject: Reply with quote
That is a nice mod to a standard top, is that zipper in and out or velcro.
The only thing I would worry about would be wind stress to the material around the rear window while driving at highway speeds.
Supposed to be 77käfer, but there are no umlauts on an american keyboard
Overheard on 27 June 07, one lady to another when they saw my Harli in a parking lot at West Point, "maybe he found it on the clearance aisle at the Volkswagen dealer"
pjmacua
pjmacua is offline
PostPosted: Fri May 23, 2008 2:21 am    Post subject: Reply with quote
Hello
The answer is velcro but a zipper should do the job.
http://www.181spirit.com/portail_phpBB/index.php?p...pic_id=601
I think that an upholstery store can go further and add a roll-up rear window or a removable one.
I would ask them to reinforce the vinyl at the rear with a double layer.
Regards
Pierre-J M.
77kafer
77kafer is offline
PostPosted: Fri May 23, 2008 5:00 am    Post subject: Reply with quote
Nicely done....
colorider181
colorider181 is offline
PostPosted: Fri May 23, 2008 10:11 am    Post subject: Reply with quote
Slightly off topic but, I've been looking into making my own bikini top from scratch. I like the Thing Shop's but I have a roll cage and think the straps and frame are unnecessary, plus my thing will probably never go on the highway, it will serve as more of a sun shade for me and my bulldog back in the dunes.
Anyone made one themselves? Any thoughts on material? I'm going for something like what Surfarii has on his.
Whatever I end up doing I will post the results/project here and on www.romtoc.com.
Pbotsonis
Pbotsonis is offline
PostPosted: Fri May 23, 2008 7:24 pm    Post subject: Reply with quote
I had the same porblem. So when I got mine done I put snaps on the roll bar and the top snaps to the roll bar. It works really well.
Captain Spalding
Captain Spalding is offline
PostPosted: Sat May 24, 2008 8:41 am    Post subject: Re: Modify Thing top instead of Bikini Reply with quote
richtrek wrote:
Have any of you customized your Thing top by modifying the rear window so that it can open and roll upwards similar to a Jeep top.
I think it's a great idea. You'd have to be careful about how you did it. My top is pretty tight, and if the center section were removed or rolled up, it would put a lot of stress on the parts of the back of the top that were still attached to the body. (I think that makes sense.)
ladder332
ladder332 is offline
PostPosted: Mon Sep 08, 2008 10:02 am    Post subject: Reply with quote
Great idea with those zip out sides.....
www.dasvolks.com
Long Island's only Vintage VW club
[email protected]
mpb181@aol.com is offline
PostPosted: Mon Sep 08, 2008 10:13 am    Post subject: Reply with quote
The problem is the exhaust fumes coming into the passenger compartment, ala carbon monoxide poisoning,
yellow73kubel
yellow73kubel is offline
PostPosted: Mon Sep 08, 2008 1:10 pm    Post subject: Reply with quote
I can't see where that would be a problem. Jeeps have no problem with it, and they have a very short rear deck (the exhaust does point down a little more though). The wind would keep the gases away, unless you are reversing for a long period of time.
colorider181 (yeah, I know this was 7 months ago): we have been looking at an idea for a bikini top on my Thing. I am thinking maybe 1.9oz or a little heavier ripstop nylon (military grade stuff can be found for $4.50/yd), with some nylon webbing or cord to strap it down to the same loops as the soft top, and somewhere up front (got to check out the possible points).
spaeth
spaeth is offline
PostPosted: Mon Sep 08, 2008 2:52 pm    Post subject: Reply with quote
I had a bikini top that came with one of my Things that simply used two snaps on the windshield frame and then it was fitted around the two locater pins on the top of the windshield frame. It then just stretched over the roll bar and then used to tow nylon straps that went back through the hoops in the rear that the top hold down straps go through. It was pretty much just a rectangle of top vinyl with two straps sewn to the rear corners. It worked great and would be really cheap to put together.
Craig
