visket Samba Member
Posted: Fri Jul 25, 2008 9:25 pm Post subject: '70 Clutch Lever Removal |
Hi -
I bought a longer clutch lever so my wifee-poo will stop complainin' about the pedal pressure. If I could 'splain to her how neato a Kennedy Stage 1 is for the 1915 motor, I'm sure she would appreciate the additional effort to push the clutch in... I can't, so she won't.
Anywho - I got the circlip, which was a bit stuck, off of the shaft, and the cable as well, and the spring too. The lever isn't budging. I have the press-on (not clamp-on) version. I tried a bit of screwdriver leveraging, liquid wrench, and propane (which is a REAL BAD idea, seeing as you are about 6 inches from the gas line, but what the heck?).
Any real good ideas on this?
Thanks -
Mike |
Joey Samba Member
Joined: August 12, 2005 Posts: 5366 Location: Nova Scotia - Canada
Posted: Sat Jul 26, 2008 4:30 am Post subject: |
I would try the heat again but just try to heat the lever and not the shaft. If you don't want to save the old lever you may be able to cut it off using a Dremel tool (and lots of cut off discs). _________________ Joey
‘60 Kombi - '74 Bus - '79 Panel - '65 Beetle |
68Bug-lite Samba Member
Joined: July 31, 2005 Posts: 1087 Location: Tustin, CA
Posted: Sat Jul 26, 2008 8:11 am Post subject: |
Borrow or buy a cheapo two-jaw puller.
Bruce Samba Member
Joined: May 16, 2003 Posts: 17296 Location: Left coast, Canada
Posted: Sat Jul 26, 2008 10:45 am Post subject: |
I recently heard of a guy using a tie rod puller. _________________
visket Samba Member
Posted: Sat Jul 26, 2008 6:40 pm Post subject: |
Ach du lieber -
The two arm puller had nothing to hold on to. The tie rod puller looked promising, but didn't do anything - at least with the hammer I used. I don't want to ruin the bell housing, so that's about the extent of how hard I'm going to hit it. Read: just sort of a 4 pound dead-blow.
I heated the middle of the lever to get the heat to travel down the shaft, hit it with PB Blaster, and hit the "bottom" with the propane torch before I pickle-forked it, so I am pretty convinced I ain't going to get the job done.
Ya know, this is one of those things that I just gotta suck it up, and bring it to the local VW (of which I have two great shops) dude.
I have it soaking (again) tonight in PB Blaster, and I'll give it another try tomorrow. After that, it's going in.
Chalk up one failed "simple mod" in 2008...
keifernet Samba Search & Rescue
Joined: May 11, 2002 Posts: 19395 Location: Samba Center for Behavioral Science
Posted: Sat Jul 26, 2008 7:09 pm Post subject: |
Air chisel... |
visket Samba Member
Posted: Sat Jul 26, 2008 9:56 pm Post subject: |
Yikes! No "air" !!
Note to self: If I were young again, I would purchase a NICE upright air compressor for all of my automotive/other household needs. Since I was stoopid when I was young, I now have electrical stuff that is less reliable and less powerful then air tools.
Air = Good.
In any event, THAT's why I'll wind up bringing it to my local mechanic... |
Posted: Sun Jul 27, 2008 2:07 pm Post subject: |
Well... realizing that not everyone has an air compressor and or a plethora of air tools... too bad...the air chisel takes care of many many "things" like that which need just the right amount of persuasion... I have used the air chisel to remove a stuck clutch arm at least 50 or more times on transaxles in and out of the car. |
