USMC/FMF
USMC/FMF is offline
PostPosted: Wed Sep 17, 2008 12:15 pm    Post subject: Wiring Reply with quote
Just got a 74 Thing runner. I came across 3 wires that are hanging loose in the battery area. They exit from the main harness just before entering the engine compartment. They are solid brown, brown with white or grey circles running around the wire about every 1/4 of an inch, and finally a yellow wire with red strip in it. I have checked the search area and see that they connect to battery, brown being a ground. What are they used for??
Thanks, Pete
Ferretkona
Ferretkona is offline
PostPosted: Wed Sep 17, 2008 12:17 pm    Post subject: Reply with quote
That kind of sounds like the old VW diagnosis port.
74 181 Thing
2008 Ford Sport Trac V8 4x4
2008 Ford Escape V6
mattt
mattt is offline
PostPosted: Wed Sep 17, 2008 7:07 pm    Post subject: Reply with quote
Ditto and correct. They were hooked to the battery and allowed the diagnostic plug to check the battery. I used mine for another purpose, gauges up to the dash. I had to extend them up to the dash, but they all go back into the engine compartment.
USMC/FMF
USMC/FMF is offline
PostPosted: Wed Sep 17, 2008 7:47 pm    Post subject: Reply with quote
Thank you guys.....I will tape them up in a bundle and forget them.
